Is 24mm wide enough on a walk about lens for crop bodies?
Started Apr 29, 2015 | Polls
brian1366 Contributing Member • Posts: 514
This comes up in threads all the time. People asking about the best walk-about lens for their new 7D/xxD/Rebel camera.
Of course the right answer is "depends on how you shoot". This poll isn't to determine which zoom lens choice is right or wrong. It is to gather statistics on what people's preferences are.
It will be interesting to see what more people prefer (or perhaps its 50/50): 24mm+ zooms or wider.
If your walk about lens is a prime or telephoto, sorry, this isn't an all encompassing poll. This is focused on standard zooms only.
 brian1366's gear list:brian1366's gear list
Canon PowerShot S110 Canon EOS 600D Canon EOS 70D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM +5 more
POLL
I prefer the 24-105mm or 24-70mm as my walk about lens on a crop sensor body
12% 6  votes
I prefer a lens that is 18mm or wider as my walk about lens on a crop sensor body
88% 44  votes
  Show results
Canon EOS 7D
OP brian1366 Contributing Member • Posts: 514
Re: Is 24mm wide enough on a walk about lens for crop bodies?
I also should have added: This isn't a poll about which lens you own.  Obviously there are more affordable <=18mm lens option than the 24-105 and 24-70 lenses. I expect there are more people using 18-xx lenses than 24-xx because of this.
If you are answering the poll, preferably you have use one of the 24-xx lenses.
arty H Senior Member • Posts: 1,546
The simple answer is not so simple. It depends on what you want to photograph. A 24-105L is great on a crop for event, like craft fairs or a Renn festival. It is good for people photos. If what you want is a lens for architecture, it may or may not be suitable, depending on where you are. I'd want something wider in Rome, but it might be fine in Paris.
Walk about where?
Walk about where?
Hi Arty,
I'll clarify: This poll assumes you own one general purpose standard zoom lens, what focal length would you want?  For many people this one lens covers indoor & outdoor event photography, travel and landscape.
Tom-C Senior Member • Posts: 1,415
The 17-40 was my usual walk around lens for the years I used crop cameras (10D, 30D, 7D).
Now that my primary camera is a 5D3, the 24-105 gets the most use with the 17-40 a somewhat distant second place.
But it obviously depends on the preferences of the photographer. A friend's walk around lens for his 7D is the 100-400.
Tom
 Tom-C's gear list:Tom-C's gear list
Canon EOS 5D Mark IV Canon EOS R5
Rexgig0
Rexgig0 Veteran Member • Posts: 7,399
EF-S 10-22mm on 1.6x; 24-105L on 1.3x
EF 16-35/2.8L is good on both.
I wear a badge and pistol, and make evidentiary images at night, which incorporates elements of portrait, macro, still life, landscape, architecture, and PJ. I enjoy using both Canons and Nikons.
 Rexgig0's gear list:Rexgig0's gear list
Canon EOS 7D Mark II Canon EF 135mm F2L USM Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM Nikon AF-S Micro-Nikkor 60mm F2.8G ED +54 more
ed rader Veteran Member • Posts: 9,068
no. it gives you NO wide angle...nt
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
bigfatron Contributing Member • Posts: 777
I had a 24-105L as a walkabout lens on a 7D but almost always carried a 10-20 in the bag.  It is however wide enough on a full frame body that I'll only take the 12-24 that replaced the 10-20 out if I want insanely wide.
 bigfatron's gear list:bigfatron's gear list
Canon EOS 5D Mark IV Canon EF 100mm f/2.8 Macro USM Canon EF 24-105mm f/4L IS USM Canon Extender EF 1.4x III Canon EF 35mm F2 IS USM +3 more
ms18
ms18 Veteran Member • Posts: 3,530
I would use 24mm Prime
I know that was not your question. I use prime for these reasons
1) Mastering one focal length
2) Light weight
3) More light (Typically)
If I can or have to carry zoom then that would wider than 24mm. Because for those things I"m interested never been over 50mm. Any way for wildlife I need more than 300mm.
For any one who can carry a zoom and afford to pay. This is the weapon of choice for APS-C
Sigma 18-35mm f/1.8 DC HSM Art
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
irm Veteran Member • Posts: 3,105
I walked around with a 10D/40D and 16-35 f2.8 for many years and then a 7D with a 17-55 f2.8, now a 6D with a 16-35 f2.8 and a 24-70 f4.
I gave had the 24-70 f 2.8 and the f4, they are not a range that excites me, not long enough for isolating subjects, but good for indoors.
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 10D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +9 more
Alan GT Regular Member • Posts: 337
If I walk around a city with a 18-something or 17-something zoom on a crop body I find afterwards I have taken very few shots at 24mm and quite a lot at 18mm or 17mm. However I quite often just use my 24mm pancake lens as a walk about lens, and I find I have no problem using it. I think that 24mm is sufficiently wide that it is easy to adapt.
Alan
Xenol Forum Member • Posts: 96
Depends...
I use my 24-105 as my main go-to lens, and I'm thinking about upgrading to the 24-70 f4, that being said, for most of the things I shoot normally (portraits, animals ect) I don't really need longer than 35mm. However, when I do need to go a bit wider, 24mm doesn't cut it - hence my 10-18 which fills in the gap.
The lenses in Canon's lineup which would go wide enough for me normally don't go long enough to be conveniant (17-40L, 17-55 2.8 ect) . So it's really a matter of how you like to shoot.
 Xenol's gear list:Xenol's gear list
Canon EOS-1D Mark III Canon EOS 60D Canon EF 85mm F1.8 USM Canon EF 70-200mm F4L USM Canon EF 24-105mm f/4L IS USM +1 more
Re: Depends...
Surely if you "don't really need longer than 35mm" then a 17-40L would be perfect for you?!
bigdaddave Senior Member • Posts: 1,163
Canon make the 24mm EF-S pancake for just that purpose, so yes
Personally my 10-18 is glued to the end of my Rebel, superb, light, sharp all round walkabout lens IMO
rjjr Forum Pro • Posts: 14,769
When I use a Canon for a small walkaround kit I use either my SL1 with the 24/2.8 EF-S STM and carry the EF 40/2.8 STM just in case, or I use my EOS-M with the EF-M 22/2 STM for an even more compact kit.
