The E-M5 II, IBIS, an electronic shutter and a Kookaburra
Started Apr 29, 2015 | Discussions
cainn24 Veteran Member • Posts: 4,892
12
There's nothing remarkable about these shots. The composition is average, the lighting is challenging, the context is typical and the detail resolution is mediocre. I've seen plenty of much better captures of this native Australian bird. But what really blew my mind was just how many images I decided to keep that were shot at shutter speeds that were perilously low for the focal length I was using.
The following shots were all taken with the 75-300 II, handheld, utilising short strategic electronic shutter bursts in 10fps mode:
1/50s, 234mm
1/60s, 264mm
1/50s, 234mm
1/25s, 300mm
1/25s, 300mm
1/25s, 300mm
The last 3, which are probably my favourites, almost defy belief.  I'm no stranger to pushing the limits of handheld birding in low light, but the combination of IBIS and the electronic shutter has expanded the range of conditions in which I feel comfortable pushing my luck to remain at low ISOs to an extent that I wasn't expecting.
I'm impressed, and I'm ecstatic to finally be free of all this shutter shock nonsense.
Olympus E-M5 II Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II
TN Args
TN Args Forum Pro • Posts: 10,687
Re: The E-M5 II, IBIS, an electronic shutter and a Kookaburra
Thanks, yes, I like the shots, and the stability  The kooka has such a cheeky expression.
I was showing off the IS to a friend last weekend in a darkish home theatre room, and got a very steady shot with a 40mm (80 eq) lens at 0.4 seconds. That's 5 stops better than the handheld rule. With mechanical shutter and 0s antishock. Even surprised myself!
Arg
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
David 247
David 247 Veteran Member • Posts: 3,322
Well they look pretty good to me.  Challenging conditions yes, but I am seeing a lot of feather detail in these.   Nicely done overall.
- David
"The only good camera is the one you have with you when opportunity provides inspiriation."
http://lightweaver.zenfolio.com
https://www.youtube.com/user/davidwendelrobinson
Through David's Eye (blog): http://www.throughdavidseye.com
 David 247's gear list:David 247's gear list
Panasonic FZ1000 Olympus E-M5 II Olympus 12-40mm F2.8 Pro Olympus 9mm F8 Fish-Eye Body Cap Lens Olympus 40-150mm F2.8 Pro +5 more
Oli4D Contributing Member • Posts: 530
Interesting, thanks for sharing!
Could you maybe explain why this works better with electronic shutter then lets say mechanical shutter with anti shutter shock setting?
I'm no expert... why is electronic shutter better in this case?
thanks a lot
Oliver
 Oli4D's gear list:Oli4D's gear list
Panasonic Lumix DC-G9 Olympus E-M5 III Olympus 12-40mm F2.8 Pro Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 +7 more
TN Args
Slightly higher max fps speed
Complete absence of even slight shutter-induced vibration
Minimum delay after shutter button press to shutter actuation
Arg
tt321
tt321 Forum Pro • Posts: 13,854
Yes. With the EFC, the second curtain is still mechanical which still needs to reset before you take the next shot. In high fps situations this could impact the next shot.
Totally mechanical movement-free needs still more care to insure, as aperture and focusing are mechanical movements. Shooting at max aperture and with MF would remove those two, leaving only hand motion which the IS should be competent enough to deal with.
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
And obviously you enjoy a good relationship with the Kookaburra
Good job, Cain. Those shutter speeds are kind of ridiculous; imagine them only a few years ago with no stabilization. Just unthinkable.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
boxerman Senior Member • Posts: 1,946
Long focal length stabilization
Long FL stabilization is most critical to me. Those once-in-a-lifetime safari shots are what I'm after. E-M5 with monopod was quite good, but still occasionally fell short. Seeing genuine 4 stops IS at long focal lengths warms my heart. I'm happy, too, to get low-light moderate FL stabilization. But it's not a life-altering experience.
Thanks much for this demonstration. My next big game hunting is next March. E-M1 II, if it's out, or I may have to "settle" for the E-M5 II. Now I know "settling" for E-M5 II would be just fine in this critical (for me) department.
The BoxerMan
 boxerman's gear list:boxerman's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +4 more
SteveOttwa Regular Member • Posts: 387
Those are great pictures...amazingly sharp, considering. The birds must be very still too.
Is that a gum tree the kookaburra is sitting in (they do seem merry).
 SteveOttwa's gear list:SteveOttwa's gear list
Nikon D5500 Olympus E-M5 II Nikon D7500 Olympus M.Zuiko Digital ED 75-300mm 1:4.8-6.7 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +5 more
OP cainn24 Veteran Member • Posts: 4,892
I did some handheld tests when I first got my Mark II and noticed that at low shutter speeds my keeper rate was consistently higher when using the fully electronic shutter during a burst (as opposed to the EFCS) so that was the conclusion that I [tentatively] reached also.
Kookaburras do tend to be still when they're perched on a branch.  They are certainly not a fidgety bird.
At least 3 of those shots involved a gum tree, yes.  Not sure if they were that "old" though
