SarahBK
Regular Member
'Crystals' inside my Canon EF 100mm Macro USM Lens
Apr 28, 2015
Hello all,
I've been a long reader of this forum and have joined a short while ago to be able to comment on articles. I thought today I'd create a forum post in order to get some advice regarding a topic the internet, including this forum, seems to have no answer for.
Some months ago, on a flight back, I was using my Canon EF 100mm Macro USM lens to take photos of these snowflake-like crystals that were forming in between the glass of the plane's windows. The following is one of the photos I took:
The crystals that formed in between the two layers of glass of the plane window during the flight.
Once I got back home and was checking to make sure my lenses were all ok, I noticed very similar looking crystals on the inside of my lens, mostly around the peripheries. They were definitely not there before, and I was never in freezing cold weather (home temperature was above 30 degrees celcius, and I'd left Scotland which was above 15 degrees celcius). People I have spoken to suggested it's fungus, but I doubt fungus would form within a day and look like that - but to be very honest I've never seen lens fungus before.
Here is a picture of what they look like today, months after they formed, and they haven't really changed. They are difficult to see unless angled against the sun, and I couldn't get any closer since that's my only macro lens, so excuse the quality. You can make out their shape though:
The crystals on the inside of my Canon 100mm macro lens.
Not clear from the picture is exactly where they are - but I can tell at what level they are when I handle the lens. Hence, I tried to illustrate this on a diagram I found showing the lens' elements. They seem to be on the element right behind the front one.
(picture courtesy of: http://www.markusehrenfried.de/photography/canonef100mmf2.8.html)
Although it seems to defy the laws of physics, I'm convinced they are water-based crystals (you would expect them to melt instantaneously if they were ice...). What confirms this wacky idea is two things:
a) They look exactly like those crystals that formed in between the glass of the plane window (and coincidentally, between two layers of glass in my lens too)
b) When i take the lens out into the sun, tiny droplets of humidity form around the crystals - signifying there is moisture in there.
So my questions to you are:
- What do you think those crystals are? Have you ever seen anything like them?
- What can I try do to remove them? (Probably taking it for servicing would be the best idea; although I did take it to the Canon distributor in my country from whom I bought the lens and they had no idea what they were. Servicing would probably be ridiculously expensive and would take a long time).
I'd appreciate your suggestions, ideas and advice. While they don't seem to be affecting image quality currently, I presume it's because I use it on a crop sensor so perhaps these crystals are too peripheral to be a problem. I do hope to use this lens on a full frame in the future, where they may actually become problematic...
