metz 44 on nx1?
Started Apr 24, 2015 | Discussions
kattoufcy Regular Member • Posts: 181
metz 44 on nx1?
Will the metz44 flash work on a new nx1?
I am about to get an nx1 and just want to make sure. Currently I use a nx20.
thanks
/J
Samsung NX1 Samsung NX20
Jeffrey Behr
Jeffrey Behr Veteran Member • Posts: 3,874
My Metz 44 AF-1 works just finely on my NX1...
...in my brief tests.  Exposure is spot on.
Damned amateur fotografer trying to get a little more active again.
http://community.webshots.com/user/jeffreybehr
 Jeffrey Behr's gear list:Jeffrey Behr's gear list
Fujifilm X-H2 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 16-80mm F4 Fujifilm XF 10-24mm F4 R OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR +4 more
AxelHawk Regular Member • Posts: 217
Re: metz 44 on nx1?
thanks
/J
If it's for samsung, it should work.
 AxelHawk's gear list:AxelHawk's gear list
Samsung NX500 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS Samsung NX 16mm F2.4 Pancake +2 more
Jeff Style Contributing Member • Posts: 953
Re: metz 44 on nx1?
It works fine. It is a fare bit overpriced for how it is made and feature set but if you want TTL and good power you don't have many options.
It is easy to operate and exposes properly and consistently.
 Jeff Style's gear list:Jeff Style's gear list
Samsung NX300 Sony a7 III Sony a6400 Sony a7 IV Samsung NX 30mm F2 Pancake +7 more
brianric Veteran Member • Posts: 8,980
Re: metz 44 on nx1?
Considering it is 40% of the price of the Samsung ED-SEF580A I would say it's a bargain.
 brianric's gear list:brianric's gear list
Sony RX100 Panasonic Lumix DMC-G1 Panasonic Lumix DMC-GX8 Sony a6400 Sony a9 II +6 more
Re: metz 44 on nx1?
A bargain in the sense of "if you don't have many choices, you take the lesser of two evils"
It has a plastic foot, only does 4 manual power increments, and you can't change the batteries without taking it off of the camera first. For $200? That's not a bargain, that's price gouging. There is a vacuum in the Samsung speedlight segment and Metz adds a premium to the price because of it. They have you over a barrel and they are going in dry. You can catch a rebate every now and then and save $40 or so and get a little lube, but the 44AF at $160 is still MUCH more expensive than what you would get with say, Yongnuo, if they decided to jump into the NX fray.
Re: metz 44 on nx1?
Price gouging? Really? Someone forcing you to buy it? This isn't a necessity like food or shelter. Go buy the Samsung model for $499.
Nevada Landscapes
Nevada Landscapes Regular Member • Posts: 227
Re: metz 44 on nx1?
Anyone know if the Metz 44 for Pentax works on the NX1?  I see some flashes say for Pentax and Samsung.  I ask because the Pentax version of this flash seems to be cheaper.
 Nevada Landscapes's gear list:Nevada Landscapes's gear list
Sony RX10 IV Sony RX100 VII Sony a7R IV Sony a7C +1 more
tecnoworld
tecnoworld Veteran Member • Posts: 7,232
Re: metz 44 on nx1?
Nope, two different systems. It worked on older samsungs.
 tecnoworld's gear list:tecnoworld's gear list
Samsung TL500 Samsung NX100 Samsung NX200 Samsung NX300 Samsung NX1 +15 more
