OP
SHood
Re: Shutter shock issues on the 5DS
schmegg wrote:
SHood wrote:
This should not come as a surprise as all high density sensors are having this issue, especially with longer lenses.
http://www.dpreview.com/articles/3639917149/cp-2015-nikon-interview-we-learned-from-the-d600-episode#comments
"all high resolution offerings from all brands exhibit deleterious interactions between mirror/shutter vibrations and optical stabilization systems (our initial tests of the Canon EOS 5DS show that it is no exception)."
"Because that's what we see with the venerable 70-200 F2.8L II IS on a 5DS at 200mm with IS on shooting through the OVF (at all shutter speeds between 1/125s and 1/2s)."
Meh.
It's reasonably well known amongst capable photographers that to get the very best from these pixel dense sensors you need to employ technique AND the best glass.
Still, even if you don't, you'll still be no worse off than someone using the same techniques and exposures with a lower pixel density. And this is an important point that tends to be not mentioned or glossed over by some!
Nice sensationalist headline it may be, but, in actual fact, it's really nothing much at all to worry about, just something to be aware of and allow for when the very maximum resolution that the sensor can provide must be obtained. (and frankly, that's nothing new either!)
I am glad that dpreview is investigating this further as many photographers are still not aware of this issue or think that it won't impact them. Dpreview plans on posting an article on it in the next couple of weeks that should go into further detail.
Here are a few more comments from dpreview in the comments section.
"But I'm glad you brought this up - there needs to be more awareness of it. We're shortly publishing a comprehensive piece showing what you describe - and it's not just limited to that particular lens, nor to that body/brand."
"The fact that most people think it's 'not typical' is exactly why I'm glad this was brought up by the OP- b/c it is typical if you're shooting hi-res FF w/ IS lenses at long focal lengths at those shutter speeds."
"I'll give you a concrete example- recently I asked a well-known wildlife photographer if he'd encountered this issue. He said 'no', but was kind enough to send me some full-res files. I saw it immediately, but probably only b/c I'd been looking for vertical shake extensively recently from doing all these tests. Yet he'd missed it in thousands of his own shots.
IOW, if you don't know what you're looking for, you'll often see this in the real world as just a shot that requires more sharpening, or slightly misfocused, or slight motion blur, or combination thereof. And remember, it's mostly within that particular shutter speed range, which isn't exactly a range wildlife photogs use."
