Pentax Quality Control Strikes Again
Started Apr 23, 2015 | Discussions
KentG Veteran Member • Posts: 4,638
Re: Pentax Quality Control Strikes Again
Throwing out the old Roman aquaduct subject, you are correct as the dirt in the foreground is much weaker on the left side.
Kent Gittings
 KentG's gear list:KentG's gear list
Pentax K-5 IIs Pentax K-S1 Pentax K-1 Pentax smc D-FA 50mm F2.8 Macro Pentax FA 150-450mm F4.5-5.6 +3 more
RichRMA Veteran Member • Posts: 4,073
Did Tokina make this one too?
Rampant narcissism + bad photography = "selfies"
OP Joseph Tainter Forum Pro • Posts: 11,082
I am not certain that the DA 16-85 is a Pentax design. Maybe it is, maybe it isn't. It doesn't matter. The problem comes in sloppy manufacturing, and Pentax certainly manufactures the optics.
Tokina never made optics for Pentax. It was the other way around.
Joe
Joe
Thanks, so the only thing they share is the optical design.
Joe
For the joint Pentax-Tokina lenses, that is correct. It is my understanding that Pentax manufactured the optics for Tokina for the joint lenses.
Of the joint lenses, Tokina designed the 12-24. Pentax designed the other ones.
Pentax has historically gotten long wide-to-tele lenses from Tamron. Tamron often uses a 62 mm. filter size, which Pentax has never used for its own lenses. So I suspect that the 18-135 is a Tamron design (even though Tamron doesn't offer a lens of its own like this). The DA 16-85 has a 72 mm. filter size, which Pentax has also never used for its own designs. That makes me wonder if this lens is by either Tamron or Tokina. On the other hand, Pentax had never made a lens with a 55 mm filter size. Then they made the DA 20-40, which has this filter size. So it might be that Pentax is venturing into filter sizes that it hasn't used before. It really doesn't matter. The DA 16-85 is reportedly a fine lens, whoever designed it, if you can get a good copy. I'll keep trying.
Joe
DAVID MANZE Veteran Member • Posts: 5,871
awaldram wrote:
DAVID MANZE wrote:
awaldram wrote:
DAVID MANZE wrote:
I just got a DA 16-85. As with any new Pentax lens, I immediately took it out for a brick wall test. Sure enough, it is optically decentered, with bad weakness on the right side.
That's my second bad Pentax lens (out of two new lenses purchased) since last summer.
It's going back.
Joe
I think Joe your version of acceptable is not the same as Pentax's , This isn't meant as a criticism just a fact.
Joe's lens was not tested optically........they don't check every lens optically just an occasional sample! . there's just a quick mechanical check.
...........so it comes off the line and goes into the box ...
So how would Pentax have known whether it was good or not?......
You perhaps are not aware how manufacturing works in the modern age
Perhaps I know a little more about it than you think. Maybe you could pinpoint where the optical errors are coming from?
because it's in lens element element cementing.
Here's a link to a latest little device, this would help I think.
https://www.youtube.com/watch?v=rffVOoOLVqE
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 28mm f/2.8D +16 more
They're probably using some 15 year old in an open-air factory in Vietnam to cement the optics.
Jim King
Jim King Veteran Member • Posts: 8,582
(snip)
I believe that this is potentially  a fine lens.  I was lucky; I hope that you will be too, with your next copy.
Jim King - Retired Colormonger - Suburban Detroit, Michigan, USA; GMT -4h (EDT)
Pentaxian for over 50 years.
There is hardly anything in the world that some man cannot make a little worse and sell a little cheaper, and the people who consider price only are this man's lawful prey.
- John Ruskin
A fanatic is one who can't change his mind and won't change the subject.
- Sir Winston Churchill
A fanatic is one who redoubles his effort when he has forgotten his original aim.
- George Santayana
The difference between genius and stupidity is that genius has its limits.
- Albert Einstein
 Jim King's gear list:Jim King's gear list
Pentax K-3 Leica M10 Pentax MX-1 Fujifilm X30 Leica M9 +141 more
Nikon's 16-85 is an exceptional lens, someone should compare the Pentax to it.
Gosman Contributing Member • Posts: 925
I've been told that I over analyize photography too much.  Now I have met someone that is worst than me!  I buy good lenses and if they look good and sharp in the middle and everything else looks decent, I'm OK with it.  I do use the LensAlign system to set my camera to the lens.  But decentering and Off balance?  Come on.
Gosman
awaldram
awaldram Forum Pro • Posts: 13,270
How that different from Pentaxs' jig
http://www.cloudynights.com/topic/345452-separation-of-a-doublet-and-re-cementing/
Dave's clichés
 awaldram's gear list:awaldram's gear list
Pentax K-x Pentax Q Olympus PEN E-PM2 Pentax Q7 Pentax K-3 +17 more
awaldram wrote:
DAVID MANZE wrote:
awaldram wrote:
because it's in lens element  cementing.
Good one Andrew!
I think the answer is that the rhythm of the music is faster with the Pentax jig and the glue's dry when the music stops!
Dave's clichés
Qwntm Veteran Member • Posts: 6,165
It's going back.
Joe
Dang. My recent experience has been the opposite. I'm 3 for 3. My 15mm HD, 20-40 HD and 70 HD were perfect right out of the box. And I tested them pretty hard too. All bought in the last few weeks.
Edward
www.youtube.com/photouniverse
www.edwardthomasart.com
www.pbase.com/edwardthomas
 Qwntm's gear list:Qwntm's gear list
Fujifilm X100S Pentax K-5 IIs Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF) +8 more
It's going back.
Joe
Edward, I have those same three lenses, and mine were all good--except my DA 70 needs +7 focus adjustment on every camera.
Joe
It's going back.
Joe
Fixed focal lenses tend not to have the same problems, but you did well with the 20-40HD!
The more the zoom range the more demanding the lens alignment, if I remember rightly you were returning some a while back.
Dave's clichés
