Samsung 45mm vs Rokinon 85mm?
Started Apr 20, 2015 | Questions
causey Regular Member • Posts: 143
Re: Samsung 45mm vs Rokinon 85mm?
I can't make 'absolute' recommendations, but I can tell you what I'd do if I were you.
The 85mm is a bokeh/ effect lens. It isn't a street/ action lens. You can use it for portraits, landscapes, flowers, etc. Much nicer isolation and bokeh than the 45mm.
I hear the 45mm has fast AF: it's a much more versatile lens than the 85mm. Good for portraits, landscapes, streets... Still, for street photo, it doesn't have the best FL. If you want a good AF lens for streets and everyday use, the 30mm is the way to go. 45mm will be a bit too narrow in many circumstances, and for portraits 85mm is nicer than 45mm, IMO.
Besides, there are countless legacy fifty lenses with great bokeh, which you can use with a cheap adapter. I recommend Pentax M 50mm 1.7 (f1.4 is better, but more expensive), Chinon 50mm 1.8, Sears/ Ricoh 50mm 1.7. There are lots and lots of nice and cheap 50mm in m42 mount--but generally heavier than the ones in Pentax mount.
In fact, this is what I have: the 30mm/2, the Rokinon 85mm/1.4, and a Mamiya/Sekor (m42) 55mm/1.8.
OP dgrogers Veteran Member • Posts: 7,243
causey wrote:
Please check the second paragraph of the reply I wrote right after you asked me.
I'm sorry.  Thank you.  I thought it was more about DOF and focal length so I skipped over it (I've grown tired of DOF arguments since I've heard them over and over again, and yes, I think you are right).
 dgrogers's gear list:dgrogers's gear list
Olympus E-1 Samsung NX20 Olympus OM-D E-M10 Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +4 more
I hear the 45mm has fast AF: it's a much more versatile lens than the 85mm. Good for portraits, landscapes, streets... Still, for street photo, it isn't the best. If you want a good AF lens for streets and everyday use, the 30mm is the way to go. 45mm will be a bit too narrow in many circumstances, and for portraits 85mm is nicer than 45mm.
Thanks.  It seems the the 45mm is a great overall lens that doesn't quite excel at any one thing but is competent in many areas whereas the 85mm Rokinon excels at one thing but isn't very useful at others.
Fair generalization?
No problem. I've just posted a few lines you might find helpful... See my second post to your previous reply.
Yes.
You might want to look at pics taken with each lens:
samyang 85mm: https://www.flickr.com/search/?sort=relevance&text=samyang%2085mm
NX 45mm: https://www.flickr.com/search/?sort=relevance&text=nx%2045mm
Yes.
That was a great idea.  Thanks.
I'm leaning towards the 85mm Rokinon now.  It just seems to have a bit more of that wow factor.
ttbek Veteran Member • Posts: 4,869
Kaziklu, sorry, but the shot on the right obviously has more distortion. The distortion that Samsung corrects for is not the same kind of distortion that we are observing here.
They correct optical distortion, in particular radial: http://en.m.wikipedia.org/wiki/Distortion_(optics)
They do zero about perspective distortion (which is why the reason the rule exists), and nor should they: http://en.m.wikipedia.org/wiki/Perspective_distortion_(photography)
As a result, the central portion of the image is more exaggerated in the image on the right, solely because you have to stand closer to get the same kind of tight framing. If you stand where you would with the 60 (but using the 30) and crop to make the same framing, that would give you the same perspective distortion.
 ttbek's gear list:ttbek's gear list
Canon PowerShot SX10 IS Canon EOS 5D Samsung NX300 Canon EOS Rebel SL1 Samsung NX30 +37 more
Sounds like the 45 will be good for you. If you're further back then the distortion won't really be a concern and the fast AF on the 45 is great for that.
Wow factor = capacity to isolate the subject. The Samyang is a great lens in this regard. Nice tone gradation and superb bokeh. It compares well with glass several times more expensive. I'm sure you'll want a wider prime eventually, when you have funds available, and the 30mm will complement the 85mm better than the 45mm.
Here is a series I took with this lens on a Pentax K-30 @ f1.8:
http://stefanlc.blogspot.com/2013/07/oh-la-la-lelegance.html
jennyrae Senior Member • Posts: 2,690
I have no experience of the 45mm, although I just want to share my experience with the Samyang/Rokinon/Bower 85mm. despite the beautiful bokeh and amazing light gathering of that lens, I seem to struggle of using it, not because it is manual focus, but the minimum focusing distance can be a pain. it is very long which somehow limits it's flexibility and usefulness. you get within less it's mfd and expect that you will lose your shot and opportunity. when using that lens, expect to shoot long always. this is the reason why I sold my copy and bought the Samsung 85mm instead. aside from the AF capability, the mfd can be shorter and does not make you lose some shots whenever your subjects are close next to you. also, the bokeh is nice.
with the 45mm, it's a very versatile focal size and bokeh seems to be good and from the reports, have an extremely quick AF. but if you are really after an amazing bokeh, you have to go with either 85mm that I mentioned or you can buy any 85mm adapted for the NX.
zipcode Regular Member • Posts: 312
I have the Samyang but not the 45 mm. I can say that it has the most absolutely ridiculous longitudinal chromatic aberration I've yet seen on a lens (aka bokeh fringing), but it's the only 85 1.4 I have so maybe it's normal for this type of lenses. The bokeh is very smooth, I would even say boringly smooth, which seems to be the rage these days. Also difficult to use because the focusing ring is very very stiff (very). This seems to vary and maybe nowadays it's not so bad anymore. I'll have to open mine one of these days and lube it, it's almost unusable.
Do not expect to use it indoors, the focal length is too long (unless you leave in a mansion). Sure, you could use it maybe for head and shoulders shots, but for those the problem will be that an 85 1.4 is quite useless (dof is too thin to get anything in focus), you can get plenty of background blur with a fast 50 at such close range and still have more versatility.
Kaziklu Senior Member • Posts: 1,301
Yes but it isn't to the level people suggest. (she is also closer which pushes it further. I didn't have a perfect like to like example)
Which is why I said to some Extent.
there is distortion in both. 85 would be better than either of course, but the 30 isn't so bad. The 45 will be better and on APS-C perfectly acceptable for the kind of shooting the OP is asking.
if I were doing headshots/portraits the 60, 85 or 50-150 would be better.
the Samsung 20 would be bad. but 20 to 30 is actually a large jump. after that the jumps are fairly minor a ff 70 to 135 is noticeable but really only side by side for most people. So for the purpose of the thread it isn't a huge deal.
 Kaziklu's gear list:Kaziklu's gear list
Samsung NX20 Samsung NX1 Samsung NX 30mm F2 Pancake Samsung NX 18-55mm F3.5-5.6 OIS Samsung NX 50-200mm F4-5.6 OIS +1 more
