Which lens is good in Focus speed?
Started Apr 20, 2015 | Polls
ms18
ms18 Veteran Member • Posts: 3,530
ef-s 55-250mm f/4-5.6 is ii vs ef 50mm f/1.4 usm
There is a event coming up on this saturday for children. Which is not sports but some activities such as musical chair. It is an out door event so light won't be a problem. I will be shooting with my T2i. I want to reduce out of focus shots when kids perform activities. I can get near to them so focal legnth is not a issue. Solely on focus performance which lens do you recomend? If focus speed are same I would like to go with prime..
 ms18's gear list:ms18's gear list
Fujifilm X-T20 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +1 more
POLL
0% 0  votes
ef 50mm f/1.4 usm
100% 3  votes
  Show results
ms18
OP ms18 Veteran Member • Posts: 3,530
BUMB (nt)
No text.
Lemming51
Lemming51 Forum Pro • Posts: 15,278
or bump
It looks like you already own these two lenses.  Seems you should be telling us if one AFs faster or more accurately than the other.
Unapologetic Canon Apologist
 Lemming51's gear list:Lemming51's gear list
Canon EOS 40D Canon EF 50mm F1.8 II Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF 70-200mm f/2.8L USM Canon EF-S 55-250mm f/4-5.6 IS STM +5 more
ms18
Re: or bump
I used 50mm for portraits only (Specially less light situations) .. No experience in sports and outdoors...
M H S
M H S Contributing Member • Posts: 748
Re: Which lens is good in Focus speed?
70-300L
Fastest and most accurate focusing lens I have ever used.
 M H S's gear list:M H S's gear list
Sony RX100 II Panasonic LX100 Canon PowerShot G7 X Canon EOS 30D Canon EOS 550D +18 more
diness Veteran Member • Posts: 3,758
Re: or bump
But isn't it pretty easy to just test them side by side? They are two pretty different lenses.. I would probably be choosing one based on something other than focus speed personally. Focal length and max aperture is going to be a much bigger difference between these two than focus speed.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
