Olympus 14-150 II f4 vs Panasonic 14-140 II f3.5
Started Apr 18, 2015 | Discussions
TN Args
TN Args Forum Pro • Posts: 10,687
Re: Any more info on this, especially with regards to shutter shock and sharpness?
jbancroft1957 wrote:
I'm particularly interested to hear if the Olympus suffers from shutter shock as the Panasonic does (on some bodies).
Lenses don't suffer from shutter shock. They don't have a shutter. Only a lens-body combo can have such a problem, so if you want to discuss a lens, and shutter shock, you have to say with which body every single time. And make no assumptions that it applies to any other bodies unless specifically tested with the other bodies.
Arg
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Sony a7R III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
TN Args
Re: Change in optics for new Olympus 14-150mm
Henry Richardson wrote:
TomFid wrote:
They only tested the Mk I, but as I understand it, the optical design didn't change.
According to this post and link to an article the optical design did change:
http://www.dpreview.com/forums/post/55603475
I saw that too, but OTOH the Olympus company info shows exactly the same optical layout (with a slight change in labeling of special elements) and exactly the same MTF curves.
I eventually concluded that it is most likely a surface coatings update, and possibly, at most, a minor re-profile of one or two lens elements, unless they have adopted new names for the same lens technologies.
Arg
OP ElliotV Contributing Member • Posts: 642
The Tamron had some defects in the coating and so I returned it. I brought three lenses I already owned: the Olympus 12-40, the Panasonic 20, and the Olympus 40-150 f4. The only lens I have used ten days into the trip is the Olympus 12-40.
 ElliotV's gear list:ElliotV's gear list
Fujifilm X-T5 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
OpticsEngineer Veteran Member • Posts: 7,850
I have both the old Olympus 14-150 and the new Olympus 14-150II. There is a quite noticeable difference in image quality between the two. The II is quite noticeably better, particularly in keeping sharpness across the image.
There is no way the optics are the same. It is a new lens design for sure.  But the II does have more chromatic aberration in the corners than I would have liked just like the older version.   So I got the EM5II to get the in camera correction of chromatic aberration for JPEGS.   The EM5 lacked that.
 OpticsEngineer's gear list:OpticsEngineer's gear list
Fujifilm XF1 Olympus XZ-2 iHS Canon PowerShot G7 X Olympus Tough TG-4 Pentax *ist D +27 more
brosenz Senior Member • Posts: 1,004
How is the AF speed of the 14-150 II lens?
