Olympus 14-150 II f4 vs Panasonic 14-140 II f3.5
Started Apr 18, 2015 | Discussions
ElliotV Contributing Member • Posts: 642
From a previous thread, I decided to buy the Panasonic 10x zoom and bring along my Panasonic 20mm/f1.7 lens for travel in Sweden and Croatia. Then, on another website I saw some very sharp photos with the new Olympus 14-150 II f4 lens. I have one Olympus body (E-M1) and one Panasonic body (the GX-7).
From what I can glean, the Olympus' advantage is its weather-resistance, while the Panasonic has OIS and is marginally faster. I am not sure how quickly the maximum aperture changes on each lens as one zooms.
  • The Olympus closest focusing distance is 50mm, the Panasonic 30mm
  • The Panasonic weighs 20 grams less
  • The Panasonic is shorter by 8mm but has a larger diameter by 3mm
  • The Panasonic comes with a hood, the Olympus does not
  • The Panasonic has reported to produce shutter shock, especially on the GX-7, which is the one thing that has held me back from buying it before now
Does anyone have experience yet with both lenses? Or do you have any more information on the lens' properties? There are only a couple of short, incomplete reviews as yet.
 ElliotV's gear list:ElliotV's gear list
Fujifilm X-T5 Fujifilm XF 100-400mm F4.5-5.6 OIS WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
Olympus 14-150 F4-5.6 II Panasonic Lumix G 14mm F2.5 II ASPH
aodi
aodi Senior Member • Posts: 1,678
Re: Olympus 14-150 II f4 vs Panasonic 14-140 II f3.5
Yes, I am not aware of any real comparison of these two. I had Panasonic 14-140 II before and have not seen any problem with it on GX7 or OMD-E-M1. I have Olympus 14-150 now and had short comparison before I sold 14-140 and did not notice any difference in IQ between the two. I sold Panasonic since got a good deal on Olympus and my main camera is OM-D E-M1, so now I have weather proof package.
Both are good lens.
Anatoli
www.transformingphoto.com
aodi
BTW it was couple of threads on this site a week or two back regarding these lens, just search.
Anatoli
Robert Deutsch Forum Pro • Posts: 10,229
Yes, it does.  (The Mk.I didn't.)
I really like my 14-150II, but have no experience with the Panasonic.
Bob
 Robert Deutsch's gear list:Robert Deutsch's gear list
Olympus E-M5 II
dholt Regular Member • Posts: 145
There was a discussion of this on the m4/3 forum awhile back, although a lot of it focused on the Mk I version of the Panny lens.
http://www.mu-43.com/threads/52925/
maggiemole Senior Member • Posts: 1,988
I use the 14-140 II f3.5 on my GX7. I like it very much as a walk-about lens, though I admit I don't go above 100mm a lot. I too noticed many comments about shutter shock, and I decided to avoid the risk: I set the electronic shutter and just forget about it. And having done that, I find I really like using the electronic shutter anyway, it is so quiet. I haven't got any examples of shutter shock to date - though I do have one or two slightly shaky hand examples, despite the OIS.
 maggiemole's gear list:maggiemole's gear list
Panasonic Lumix DMC-FZ300 Panasonic Lumix DMC-GX7 Panasonic Lumix DC-GX9 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +8 more
OP ElliotV Contributing Member • Posts: 642
Bob
Thanks for the correction about the hood!
Yes, I have read that people just use the electronic shutter and that avoids any potential for shutter shock.
JohnLock Senior Member • Posts: 1,524
 JohnLock's gear list:JohnLock's gear list
Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
Thanks for the link. I wish I could try each one of them, but the camera store locally probably only carries the Olympus.
AdamT
AdamT Forum Pro • Posts: 62,285
I'd like to know too as the Panny is --->
I'd like to know too as the Panny is Superb optically but the new Oly is Weathersealed and I`m back to a W/Sealed OMD again ...... also the Oly not having OIS can`t suffer OIS Video jitters and won`t shutter shock on a GX7
So is the Oly optically as good as the fantastic Panasonic through the range and especially across the frame wideopen at full zoom ???? . if it is then I may have to move over to it
Canon PowerShot SX50 HS Nikon D3 Panasonic Lumix DMC-GH3 Nikon Z7 Nikon Z9
TomFid Veteran Member • Posts: 4,000
Re: I'd like to know too as the Panny is --->
If you believe the objective tests, the Oly is unfortunately much weaker than the Panny at the tele end.
See, for example,
http://slrgear.com/reviews/showproduct.php/product/1320/cat/15
They only tested the Mk I, but as I understand it, the optical design didn't change.
AdamT
I knew the Mk1 wasn`t as good as the Panny Mk2 at the long end , it loses all the way through on contrast too but I thought the Mk2 Olympus was a totally different optical design
rsday75 Forum Member • Posts: 54
I have the Panasonic and the GX7.
I think some of the Shutter Shock may vary with each copy. I notice if I pixel peep that sometimes my images are not as sharp in the 1/100-1/200 with the mechanical shutter as they are with the electronic. That being said, you can only really see it at 1:1 or higher magnification. I find even these photos to be fine for most "snap shot" situations.
I use electronic shutter most of the time unless I need flash or I am under artificial lights that may cause banding.
I find the lens to be very sharp throughout the range. As good or better than the pair of lenses it replaced. (The Panasonic 14-42II and 40-150) Having this much range in an optically great lens is wonderful for walkabout use. No lens changes. I have primes if I need better low light performance. For reference, on my Nikon DX system I had the Nikor 18-200, and I find this lens to be SO much better even with the mechanical shutter, and not even in the same league with the electronic shutter.
This site lists the aperture as zoom increases. It only hits 5.6 at the very end of the range...
This all being said, I have not been able to use/see the Olympus lens to compare.
I have a little box with a piece of glass in front of it. It soaks up light. I use it to make 2D representations of a 3D world.
 rsday75's gear list:rsday75's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Olympus M.Zuiko Digital 25mm F1.8 +1 more
Hmm ... I may be wrong ... the DPR news item mentions cosmetic and coating changes, not optical design, but someone asserts in comments that it is new (different number of elements than the MkI). I can't corroborate that.
I don't know of a decent review, but PCmag did use imatest, and found it soft at 150mm. http://www.pcmag.com/article2/0,2817,2477116,00.asp
FWIW, a lot of people claim that the Panny Mk I is soft at the long end too, but that has not been my experience at all, nor can I see a big difference between the I and II in tests (if there were, I'd switch in a heartbeat).
Henry Richardson Forum Pro • Posts: 21,959
Change in optics for new Olympus 14-150mm
According to this post and link to an article the optical design did change:
http://www.dpreview.com/forums/post/55603475
Henry Richardson
http://www.bakubo.com
I went ahead and ordered the Tamron 14-150 f3.5. I liked the looks of some of the photographs from it and the 6-year warranty. I also saw some positive reviews, though admittedly there is not too much available.
Ron Zamir Senior Member • Posts: 1,421
My past experience with Tamron was not good - colors were not true to life and there was a lot of purple fringing - I can see evidence for this in the samples of this Tamron lens. The images with the Olympus lens seem to be free of these problems.
 Ron Zamir's gear list:Ron Zamir's gear list
Olympus E-1 Olympus OM-D E-M10 Olympus E-PL8
jbancroft1957 Contributing Member • Posts: 941
Any more info on this, especially with regards to shutter shock and sharpness?
I'm particularly interested to hear if the Olympus suffers from shutter shock as the Panasonic does (on some bodies).
John
Anyone?
John
