DJB77
New Member
3000 slides copied in two afternoons
Apr 12, 2015
15
I have had this bunch of slides dating back to mid 1960's that haven't been looked at in at least 25 years. I have searched the internet as to a faster way of copying than using a scanner, and saw some people using old slide projectors. Since I had most of what was needed I set out to see what could be accomplished.
I had a Kodak Carousel 800, late 1960's vintage, a stack loader, K3 on tripod, camera remote, and a Tamron 90mm macro. All I needed was a diffuser to fit in the projector to lesson the light. After much searching I came upon the shown soap dish that I cut the bottom out of and it worked perfectly.
Setup consisted of removing the projector lens and inserting the diffuser in place of the condenser lens in the projector. The camera shot straight into it as shown below.
I then tried the setup and was really disappointed with the results. Color balance horrible, to dark and way to much contrast. After a couple hours experimenting my results were what I thought was much better. The camera settings I ended up with are listed next.
- Mode dial to Aperture Priority Av
- ISO 400
- Exposure compensation to +0.7
- Lens set to F8
- Whit balance to manual 3200K, will vary with different light sources
- Custom image to Natural
- Contrast set to lowest setting
- Sharpness was at +1 notch
- Instant review off, to speed things up
- Electronic level ON
- Shake reduction OFF
- JPEG setting to S (3072x2048)
- Jpeg quality to *** High
- Autofocus to ON
I leveled the projector with a level then used the level built into the K3 to level the camera. I kept the Jpeg setting lower to keep file size reasonable as I scanned slightly more than 3000 slides that resulted in 10.6gb of files. I could copy about 20 slides a minute, or about 500 an hour which includes changing slides in the stack loader. Auto focus kept everything in focus and you could see fine adjustments taking place on the slides had slightly different mounts.
I did not try to clean any as they mostly had been looked at once originally and stored properly. Below is a few examples of my results right out of the camera. One thing I learned is to copy all slides in landscape and rotate to portrait in the computer otherwise you will chop off some heads. I did all my flipping by batch operation in IrfanView. A few examples
Total time invested was 2 afternoons about 6 hours total. The reason for doing this is to give the kids some pictures when they were young, as I only shot slides back then. It sure brings back memories.
Don
