E-PL6 (or E-PL5) as a pocket camera?
Started Apr 12, 2015 | Discussions
MOD Tom Caldwell Forum Pro • Posts: 46,352
Re: E-PL6 (or E-PL5) as a pocket camera?
TimoK wrote:
Tom Caldwell wrote:
Impulses wrote:
Since I live in the tropics and it's never jacket weather over here, for me the GM is no more pocketable than an E-PL would be... Both need a waist pack if I'm bringing a couple lenses or at least a strap, I could get away with slipping the GM into cargo shorts during the day but that's about it.
I've actually wanted an RX100 for a while too, that brighter lens on the mk3 really made it even more appealing, but the price was always too high for something that would be my secondary camera...
That's what made me take a second look at the GM1 the low prices), and I'm really enjoying having it even tho for me it's not really pocketable. It's small enough that I'll actually bring it along with my GF6 with a second lens mounted tho, which helps tremendously (less swapping).
It's also that much more conspicuous in social situations, these days someone's more likely to think "who's the weirdo with the P&S" than be self conscious about what I'm shooting. It's light and small enough that I don't even mind it on a wrist strap tho.
I can't see myself splurging on an RX100 anymore unless it dropped under $500...
With the GM1 I'm finding my M4/3 gear as a whole more usable than ever, on the rare occasion that I don't wanna be seen with a camera on me at all (like if I'm a groomsman in a wedding ceremony or with strangers) I'll just reach for my old P&S (LF1) or simply the phone.
I live in a warmer part of the world as well and jackets are maybe a month mid winter on a cold day. I don't see the GM1 as a pocket camera - just a small one. Therefore a carry bag of some sort is necessary. But any given size carry bag will carry a whole lot more gear if it is based on the GM1 as a system camera. So I load my little cameras up with whatever lenses that I need without feeling that they need babying with only the tiniest lenses lest they break .....
A Ricoh GR can give you first class prime lens performance in a quite small package.
While Helsinki is about as south as you get in Finland, we are pretty much "north of the Wall" here (60 deg N) and I'd say it's jacket weather at least 9 months a year. So even the E-PLs might be pocketable to some extent.
Timo
I bet you have te very best jackets there Timo.
While where we are in Australia is really well south of the real steamy hot parts we are still sub-tropical enough never to get frost.  But it does get cool enough for llght jackets for a couple of months.
But even the GM1 is not really pocketable in my book - it might get into a large pocket when fitted with certain lenses but in essence it is just a very small regular camera.
Tom Caldwell
OP TimoK Regular Member • Posts: 109
Tom, to be honest I have to agree with you there. Even with the kit lens the GM1 is not really a true pocket camera. The reasons I ended up choosing the GM1 were, in this order: 1. sensor size, 2. it's a system camera and I already had lenses for that system, and 3. some inexplicable 'it' factor the tiny, and in my case bright colored, GM1 seems to have. The cost of the GM1 kit was so low (299 eur) that even if I pick up the RX100 later this wasn't a lot of money wasted.
Timo
 TimoK's gear list:TimoK's gear list
Nikon D800 Panasonic Lumix DMC-GM1 Sigma 150mm F2.8 EX DG OS Macro HSM Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye +7 more
Re: GM1 it is
TimoK wrote:
Thank you everyone for your input!
After your suggestions I read a few more reviews, especially of the GM1 vs. RX100 and tested both at a local store. I decided in favor of the GM1 and bought it at the store for 299 eur with the kit lens, which I think was a great bargain. I also picked up the Panny 20 mm f/1.7 II for another 299 eur. Of course on the GM1 the non-stabilized 1.7 doesn't offer much more low light capability than the kit zoom but it still seemed like a good addition and will of course be a much more versatile tool on the E-M1.
Having now set up the GM1 for my use (i.e. switched the mode dial to 'A' and figured out how to adjust exposure compensation, ISO and focus behavior) I find no other fault with the ergonomy besides the obvious: the lack of a view finder and a tilting screen. On the other hand, as such the camera appears quite robust with the minimal amount of moving parts and so far I'm satisfied with the purchase.
Both the lenses seem quite sharp at least in the center. More tests of image quality will have to wait until I get some decent light again.
Best regards,
Timo
Join the GM1 club. Welcome.
There are two ergonomic failings of the GM1. The one that gets trotted out most is the little wheel on the back.  If attacked aggressively by the thumb when twirling it is easy to press it and invoke one or other of second "press" functions.  Also you have to take care that the thumb rotation is parallel to the back of the camera - if it is not then higher pressure can be exerted at some point in the rotation (same problem).  Setting an EV value can be an issue as it requires an up press followed by a twirl  Furthermore the EV does not need to be "set" by using the centre button but remains live.  I  dumped myself into the menu quite a few times by pressing "set" when I did not need to do so.
I have had mine for 15 months now and I now only occasionally get tangled up with the wheel. It has a very light action and only needs soft pressure to be used. Getting this right is the hardest part of the camera - some never make it over the tactile digit learning hump.  They almost need big meaty cameras where you hit the buttons with a hammer and turn the wheels with a wrench.
If you set ISO to one of the soft function keys it is easy to access - in fact the five soft function keys can be set to give a considerable boost to ergonomics and handling of the camera but might take some head scratching and consideration of the manual before you can find the ones that suit you.  I can post what work for me if you are interested.  A little deeper is the 15-slot quickmenu.  The camera responds well to a thoughtful set up.  There are only three almost randomly set custom function keys when the camera comes out of the box.  In fact I found it necessary to make quite a lot of custom adjustments before the camera came to my idea of a good set up.
You have to take care with the touch screen - overlapping fingers and thumbs can send it off on a journey of its own.  In playback mode an overlapping thumb can invoke the nearby touch screen delete icon when using the mechanical "left arrow" button.  Something nobody else seems to have mentioned.  I use pinpoint focus a lot and am bedevilled by it roaming off its centre screen location, I am not exactly sure why but it can only be accidental brushes of the touch screen.  This is my last frustration frontier with the GM1 and might also be a problem with the GM5.
I have the centre reset procedure down to almost fingertip memory: left arrow, down arrow, disp.
Strangely although I am almost on top of it this is the first thing that any one else encounters if I let them try a few shots with the camera.
Apart from this the camera is a full function powerhouse and at the moment I am playing with the 45-175mm f4.0-5.6 lens which is a good-light little telephoto wonder with a reach of 90-350 in FF sensor terms.  It is small, light and compact, wears well on the GM1 and has internal focus and zoom capability. Not a pocket camera in this configuration, but I don't now how big jacket pockets are in Finland .....
Tom Caldwell
Timo
Yes it looks a good price.  I hope that Panasonic does not abandon his little gem as it certainly will always have a place in photography even though it doesn't suit some for their own good reasons. I my book I am happy to put up with the lack of some user conveniences to get the benefit of its extremely compact size.
I had a try of the RX100 and respect it as a capable camera but this was at a time when I was on holiday with only my GM1 and a handful of lenses includng the incomparible Nocticron 42.5 f1.2.  A quite large lens that did not seem to affect the handling of the GM1 at all.
If the GM1 has its own ergonomic shortcomings then I also didn't instantly wam to the RX100 either.
The best supplement to the GM1, but mainly for the extra user conveniences in a larger format, is the GX7.
The best powerhouse camera that is ultra compact is the Ricoh GR.  All aps-c and take no prisoners images with an impeccable prime lens.  No zoom. One serious camera for serious photographers.
Tom Caldwell
Roger Nordin
Roger Nordin Senior Member • Posts: 1,657
Re: GM1 it is
That was a really fantastic value for money indeed! Welcome to the GM1 club.
The 20/1.7 is really compact yet sharp and offers that shallow DOF that works great with people. And even though the IS on the kit lens will offset the slower aperture for low light work when shooting static landscapes, keeping the shutter speed up is more important when photographing people indoors, so the 20/1.7 is really useful too.
So, I am sure you noticed the double-duty of the trashcan button, to also bring up the quick menu. Makes it very easy to quickly adjust settings with the touch screen. I normally shooting RAW + reduced JPEG (for online sharing, since there's no in-camera RAW development), but have C1 set for HDR JPEG shooting.
The lack of a tilt screen when doing shooting on the ground etc can be compensated for by using WiFi and a smartphone in such situations, so unless you are shooting such things for every shot, it's not really a problem, IMHO. Note that long-pressing the Wifi button (even if assigning it to a soft screen touch button) will kickstart the last connection type without any further prompts or choices required, making it very quick and easy to use.
I find no problem shooting wide open with both the 12-32 and the 20/1.7. The 14-140 II I try to stop down a little, by comparison. They are very fine lenses.
/Roger
 Roger Nordin's gear list:Roger Nordin's gear list
Panasonic LX10 Olympus OM-D E-M5 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 +17 more
Impulses Forum Pro • Posts: 10,039
Timo
I think if they could actually keep it around at a very low price they probably would/should, many of us just sorta gamed it buying it ultra cheap as an import or selling of the kit lens for which there's still a decent demand... Coming out with that lens definitely paid off for them.
It looks like they intend to keep the GF7 as the budget option tho, then again they're similarly priced right now even at full retail so who knows. My GF6 had some minor firmware limitations that I wonder if the GF7 has.
For instance, I can't bring up magnified view for MF very easily (or in a PiP box) like you can on most other Panasonic bodies, it requires a pinch of the touchscreen. As much as I like the touchscreen for some things, it's definitely easier just hitting left on the GM's d-pad.
Then again, the GF6 does let me cycle thru images in playback while keeping the same magnified view, which is just awesome for quick comparisons of two images... The GM1 and possibly the GF7 can't manage that cause they have less physical control points.
I actually thought the G6 couldn't do it either, because even tho it has a dial and a toggle switch (like my GF6), it requires a click press of the rear dial first (and every time)... Otherwise both it and the toggle just serve the same function in playback (image cycle) which seems like a bit of a bizarre choice.
Sometimes I wish there was a sort of map to all these minor firmware differences, quirks, and features between all the bodies that are otherwise very functionality similar!
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
Re: GM1 it is
I think I've pressed the wheel twice while intending to turn it over the last two months... It was a total non issue for me, very much a case of YMMV. If anything, having a touchscreen on such a small body or having the on/off rocker switch get bumped in my bag have both been more of a concern.
The former is just a matter of getting accustomed to it, the latter happened twice, not quite sure what the switch got caught on... Possibly the flap of a neoprene lens pouch. I quite like having the switch around the shutter tho, makes it very quick to find in general, so I'm not complaining.
I do stuff my cameras & lenses into smaller bags than the vast majority.
Congrats on the GM1 Timo!
Re: GM1 it is
Really? Is that in the manual? The tip about the Wi-Fi button I mean... I haven't gone thru the entire GM1 manual yet, gonna have to try that as soon as I get home tho...
