DSLR Lens equivalent cost to match SX60HS.
Started Apr 11, 2015 | Discussions
HighSierra Regular Member • Posts: 190
Like the title says. How much would it cost to get the same range in lenses for a DSLR as the 65X zoom on the SX60HS.
Lets assume same minimum and maximum apertures and IQ, if that's possible.
I've been thinking about purchasing a DSLR but hate to give up that range.
 HighSierra's gear list:HighSierra's gear list
Pentax Optio 450 Canon EOS 70D Sigma 18-250mm F3.5-6.3 DC Macro OS HSM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM +2 more
Canon PowerShot SX60 HS
soufiej Contributing Member • Posts: 635
Re: DSLR Lens equivalent cost to match SX60HS.
5
There is no comparison IMO. Particularly if you throw in the built in teleconverter of the SX60 which doubles the effective range at the long end. Even more so if you add the inexpensive Raynox adapter at the short end. There is no real apples to apples system in the DSLR or equivalent system choices.
You will need several lenses to cover the SX60's range but each individual lens will have some improvements over the full zoom of the SX60. While the one size fits all concept works well for the superzoom, there are weak spots in its system where it becomes a generally very nice camera but not an outstanding camera. Buying by the individual lens you can buy a very good lens, say, a macro lens, with superior specs and overall superior resolution. The minimum I see for that comparison is about about $1k with, say, a SL1 body and one of the many macro lenses available. At that price you have one lens.
In a recent thread elsewhere on the forum I was challenged in my math by someone telling me their $400 macro lens was "worth every penny" of its cost. But that one macro lens couldn't back off five feet and still fill the frame as can the SX60 with a bit of zoom. I can easily pull far away objects close to fill the frame and place as many usable pixels on the subject as possible without sacrificing much in the way of resolution. To do the same with a DSLR body would mean yet another lens. There, in that broad midrange of possible choices, an owner could select from any of a number of lenses from primes to zooms and from moderately good to phenomenally great. The body can go from a SL1 with its APS-C sensor size to a full frame or better still. The DSLR owner could choose from brand name only lenses or go with a third party brand to possibly save some money. In the middle of its range is where I feel the SX60 lens is at its weakest. Buying a good interchangeable lens here wouldn't be difficult but would probably add another several hundred (the choices include both grey market goods and pre-owned options) to one thousand (or more) if the user didn't want to compromise or wanted a more extended range lens.
From there the issues become more difficult to predict since, why would any one with an interchangeable lens system buy a moderately good lens? "Moderately good" though is what I feel you get with the superzooms in their middle range. Not terrible by any means but also not great by most modern day standards. If you simply input "Canon 600mm lens" into Google, you will see lenses going from approximately $1k to $15k. Lower f stop ratings so more light gathering and better DOF control come with any of those lenses. Better glass for sure with fewer problems to be corrected by software. The SX60 lens works because it is purpose built to the SX60 sensor and the SX60 processor corrects for many of the distortions of the SX60 lens at all focal lengths. From there, what you want in a long focal length lens can rather easily be accomplished by a very good medium range lens and cropping. With the higher quality camera body and the faster lens, noise will be minimized in the DSLR system allowing for more cropping before loosing resolution.
I would say, don't fool yourself into thinking Canon has produced some sort of laws of physics rule breaking system with their superzoom cameras. IMO a large part of the success of the superzoom category in general is the camera's processor ability to make the best of the single lens with all of its issues and not have to deal with the dozens and dozens of choices an interchangeable lens system would present. Do some research in in-camera lens corrections to see just how much the digital circuitry of any camera has to do with the image quality. In the end, you get what you pay for in almost every case you can make for a comparison. A $500 camera simply is not going to better a $2k rig. The differences may be slight for most people and certainly the better photographer is far more important than the better camera - as you can see by viewing some SX40/50/60 sample shots - but, if you are the type who wants to never say their gear is at fault or holding them back, then you realize the gear can't be compromised in the first place.
Any zoom lens is a compromise from the get go. Not that long ago, when 10X zooms were first becoming available, they were the limit of acceptability for the "serious" shooter. I never carried more than a 3-4X zoom to keep the lens issues at bay. Now, with the current superzooms, we are talking about 50X plus?! To think that is a simple thing is to also think your Civic Si really is capable of beating the Ferrari in all out performance.
Any camera lens system is a compromise and the most successful shooters are those, IMO, who learn to work to the advantage of the system and avoid the weaknesses of the system. However, going in thinking there are no weaknesses is likely to get you nowhere fast.
"Don't get me wrong. The Canon SX 50 HS does not produce the same quality images that DSLR cameras do and you should consider purchasing these if you want high quality images. I really like my Canon 1D Mark IV (shown here) and I have gotten incredible photos with it ... I now use use the Canon 1D X or my new Canon 7D Mark II with a Canon 300mm IS lens and 1.4 teleconverter, or my Canon 500mm IS lens with 1.4 teleconverter, Gitzo 1325 Carbon Fiber Tripod and Whimberley head. The Canon SX 50 is not in the same league with the big, professional, or near professional DSLR equipment. Then again, it costs around $430 vs. the Canon 1D Mark IV originally cost around $5,000"; http://stokesbirdingblog.blogspot.com/2013/02/canon-sx-50-hs-for-bird-photography-i.html
https://kenn3d.wordpress.com/2014/03/30/sx50-beats-all-my-dslrs/
https://www.youtube.com/watch?v=9kuFN8RWer8
If you are considering a purchase, I would suggest you first define the task at hand; what will you be doing with the camera? Do you need a jack of all trades and are willing to sacrifice the absolute quality of the far more expensive and complex system to achieve flexibility?
Then define your budget and how quickly you could afford to step into the higher quality system piece by piece. As you can see, the superzoom can replace several $kkkkk worth of equipment IF you realize what you are giving up and what you are gaining. It's rather easy to carry one compact camera rather than a large and heavy bag full of gear. And making the most of a minimalist approach is a great exercise in photographic freedom akin to carrying an interchangeable lens system but with only one prime lens. To be successful, the best photographers will take the extra moment to think more deeply about what they are intent on achieving with either system.
Finally, assess your own nature. Are you content with giving it the best you have an accepting those results? If not, then there are going to be many instances where a $500 system betrays its ultimate cost to the photographer. Is what you have said with the image more important than how sharp, clear and clean the image appears? Today's cameras allow everyone to be an accomplished shooter when it comes to capturing an image. It is only those few who think about what they are about to do who will, IMO, come away with remarkable shots with even the simplest of gear.
For approximately twice the cost of the SX60, you could own the current version of the Fuji X100 series; http://www.kenrockwell.com/fuji/x100.htm and http://zackarias.com/for-photographers/gear-gadgets/fuji-x100s-review-a-camera-walks-into-a-bar/
It is, by all accounts a ground breaking camera system with few peers anywhere near its selling price. A camera that provides an experience in use rather than just another photograph. It is, however, one fixed lens which will not achieve the reach or total flexibility of the SX60. Which camera would you rather own?
OP HighSierra Regular Member • Posts: 190
Thank you very much for that detailed and thoughtful reply.
saycheese
saycheese Contributing Member • Posts: 592
5
No it doesn't, it just crops the image and not as well as photoshop can resample it. If you are looking for good IQ you should disable all software teleconverters, I am not even sure why canon deemed them necessary.
 saycheese's gear list:saycheese's gear list
Canon PowerShot SX50 HS +1 more
Can I assume you are referring to digital zoom here?
waterwingz
waterwingz Regular Member • Posts: 243
So at the risk of getting into yet another nerd fight about sensor size and aperture and IQ etc,  I thought it might be interesting to answer the original question.
Here's a link to an article about a Canon 1200mm lens .  While it does not have quite the reach of an SX50 or SX60, it does have a price tag of about $120,000.
Apples and oranges comparison?  Sure.  But the price difference does kind of make you go "hmmmm".
 waterwingz's gear list:waterwingz's gear list
Canon PowerShot G16
grimlock361
grimlock361 Regular Member • Posts: 253
You would need an apsc body that can autofocus at f8 and that only leaves (on the canon side of things) the 7DMII at $1800 + 100-400mm zoom at $1900-2200 and then a 2x teleconverter at $530. 400mm x 2x = 800 x 1.6 crop factor = 1280mm. I am working on putting this together myself but as you can see its very expensive. If you choose cheaper bodies you will loose autofocus with the teleconverter combo but you can go for the 800mm f5.6 at $13,000.
The quality for the price combination of superzooms like the sx50 and sx60 just can't be beat. At base iso the image quality is not that much different but the 7DMII iis faster and has much better IQ at high iso/low light. Its very hard to get good IQ above iso 800 on the sx50 and sx60 but not impossible. With good photography skills and good knowledge base of how to work within the limits of a small sensor you can produce excellent images with these cameras. Nothing irritates a nerd raging camera snob more than to produce equal or even better images with small sensor cameras. Make no mistake. DSLR and large sensors are better but smaller sensors are just not as bad as the legend would imply.
 grimlock361's gear list:grimlock361's gear list
Canon PowerShot SX70 Canon EOS Rebel SL1 Canon EOS 7D Mark II Canon EOS 90D Canon EF 28-135mm F3.5-5.6 IS USM +10 more
This is a very interesting discussion waterwingz and grimlock.
$120,000 hmmmmm. Would image quality be that much better?
and grimlock with your combo of long lens and teleconverter would quality be better?
Obviously yes, but worth it?
I asked this question because I'm selling my SX60-HS and will buy a entry level/enthusiast DSLR of some sort. Haven't decided on Canon Nikon or Sony.
Obviously I can't afford to have the reach my SX60 has.
Of course on an APS-C camera, a 750mm will equal 1200.
Why are you selling?
The salesperson's questions would be ...
What is the SX60 not doing that you feel you need?
What are you expecting to gain with the new camera?
Obviously, if you don't like the ride quality of the Fiat 500, you buy something else.  But a F250 Super Cab isn't always the answer either.  Each has its own set of trade offs.
Britney Elvis Veteran Member • Posts: 5,382
No compete claws
Different tools for different jobs...
My SX50 and Dslr do not compete with each other, they compliment each other.
I will never be able to afford a dslr lens that shoots the long zoom shots.  I will almost never take my dslr with 55-300 or 300mm alone on a hike... the sx50 comes with or usually by itself.
At the same time I am not taking my sx50 to school to take pics of the kids in the gym or classrooms, or to indoor soccer, or pull it out at a birthday party...
Have fun with your new dslr...   I love mine.   If you can find away to keep the sx60, at least consider it.
gus
"It is not necessary to understand things in order to argue about them."
~~ Pierre Beaumarchais~~
Augustin Man
Augustin Man Forum Pro • Posts: 11,361
Re: No compete claws
WHAT an image, Gus! It's one of the best I've EVER seen!
It's so good I feel I'd offend you saying "congratulations"
Shortly, I'm speechless...
Augustin
 Augustin Man's gear list:Augustin Man's gear list
Nikon Coolpix P1000
Thank you...
Augustin
Thank you Augustin...    it is one of my favorites.
gus
grimlock361
Actually TOTAL cost is about $4000-4500 for canon setup. Nikon with a D7200 would probably be about the same. Its very important to understand teleconverters don't to well on APSC bodies. The canon 7DMII and Nikon D7200 being the only exceptions I know of. The big quality gain would mostly be observed in low light and BIF. Wildlife that is stationary and in ample light is not as big of difference. Also, even though modern EVF have come along way they are still not the best for tracking BIF and the ones on the sx60 and sx50 are a little......well little. BIF are possible on superzoom cameras but just harder. If you really into wildlife photography a good DSLR is worth it but you can still make great photos on the sx60.
SX50HS
7DMII with 55-250 STM
patticake Senior Member • Posts: 1,308
SX50HS
those are absolutely gorgeous pictures, just wonderful!
that being said, a 300mm lens on an APSC sensor camera isn't going to have the zoom needed unless the birds are fairly close.  i ended up with a superzoom for this reason.
to the OP, you might want to play with your raw files on your canon - you may end up with the quality you feel like you're missing.
 patticake's gear list:patticake's gear list
Olympus PEN E-PM2 Sony a6100 Sony E 50mm F1.8 OSS Sony E 55-210mm F4.5-6.3 OSS Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +3 more
jackwelch Senior Member • Posts: 1,088
You can do it cheaply if you're okay with 200mm (which is about 400mm, 35mm equivalent)
The minute you go above 200mm, the lenses get pricey.
Another alternative is to look into 1 inch sensors like the RX10 and FZ1000 or FZ2500, that'll give you about 400mm to 600mm, 35mm equivalent).
