Firmware 1.21 A7/7R/7S A6000
Started Apr 8, 2015 | Discussions
Jose Viegas
Jose Viegas Senior Member • Posts: 1,848
Re: I just updated my Sony A7 Mark II
Nivedita wrote:
The update took almost the same time as 1.2.
I have not tested extensively to compare the previous state and the new state. I am planning to test in detail to see whether any noticeable changes.
At least the menu did not change to Japanese
After applying 1.21
-Nivedita
So this update keeps current languages?
 Jose Viegas's gear list:Jose Viegas's gear list
Fujifilm X-T3 Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR Fujifilm XF 16mm F2.8 +7 more
Mordi
Mordi Senior Member • Posts: 2,305
Re: Firmware 1.21 A7/7R/7S A6000
http://www.dpreview.com/articles/1719238142/firmware-updates-to-reduce-sony-fe-lens-startup-times-on-the-way
Ver1.20: 2015/3/04
The first update, available immediately, reduces the startup times of five existing FE lenses when mounted on E-mount bodies. The lenses include:
  • FE 35mm F2.8 ZA Carl Zeiss Sonnar T*
  • FE 55mm F1.8 ZA Carl Zeiss Sonnar T*
  • FE 24-70mm F4 ZA OSS Carl Zeiss Vario Tessar T*
  • FE 70-200mm F4 G OSS
  • FE 28-70mm F3.5-5.6 OSS
Ver1.21: 2015/4/06
Firmware update number two ensures that the three prime and one zoom FE lenses introduced today will offer fast startup times on Sony's full-frame a7 series cameras (in all other respects they are already fully compatible). This update will be available at the end of the month.
  • FE 35mm F1.4 ZA Carl Zeiss Distagon T*
  • FE 90mm F2.8 Macro G OSS
  • FE 24-240mm F3.5-6.3 OSS
  • FE 28mm F2
In addition to the above (Japanese website) two bugfixes were included: 1) LCD display error and 2) low light hunting improvement.
Have you updated your A7 with the Japanese version?
 Mordi's gear list:Mordi's gear list
Sony a7 II Leica Summicron-M 50mm f/2 Voigtlander 15mm F4.5 Super Wide Heliar Sony E 16-50mm F3.5-5.6 PZ OSS Sony FE 35mm F2.8 +7 more
Beaverhelmet Senior Member • Posts: 2,296
I updated my A7S today with the file from the japanese site. No problems whatsoever, and all languages were intact.
westlites Contributing Member • Posts: 637
Re: Firmware 1.21 A7m2 link updated correctly!
RidgeRunner130 wrote:
This is the a7m2 link for both Mac and Windows.
アップデート方法はこちらをご確認ください。
This link takes you to both Mac and Windows for the rest of the models.
http://www.sony.jp/ichigan/update/ILCE-7_7R_7S_7M2_6000.html
John
Zeiss Loxia 2/35, 2/50
Thanks, successfully updated my A6k to 1.21. No problem with the English menus.
Re lowlight AF being better, my initial tests seem to show some improvement. Getting locks now in low light when I couldn't before. In those shots, zooming in shows quite acceptable sharpness.
Could be wrong, though.
EDIT: Yup, there's definite improvement. Don't know though, if it's because of 1.20 or 1.21. Didn't try taking shots in my almost-dark office immediately after the 1.20 update. Before, couldn't get AF locks in the same environment.
 westlites's gear list:westlites's gear list
Sony a6000 Sony a7 II Sony E 16mm F2.8 Pancake Sony 85mm F2.8 SAM Sony E 50mm F1.8 OSS +37 more
ykphuah Regular Member • Posts: 465
Hopefully they are releasing one for A5100...
 ykphuah's gear list:ykphuah's gear list
Sony a5100 Sony E 16mm F2.8 Pancake Sony E 50mm F1.8 OSS Sony E 16-50mm F3.5-5.6 PZ OSS Sony E 35mm F1.8 OSS
PVCdroid
PVCdroid Veteran Member • Posts: 4,396
John
I just updated my A7R to 1.21 without incident on Windows 8.1/64. I have the SEL5518 and did a before and after low light focus test and noticed a slight improvement in hunting....I guess. At least nothing appears worse and I'm not sure what the LCD error was that was fixed.
 PVCdroid's gear list:PVCdroid's gear list
Sony Alpha NEX-5N Sony Alpha NEX-7 Sony a7R II Sony a7R III
Jerry Canon
Jerry Canon Contributing Member • Posts: 875
John
Since I don't read Japanese too well, I believe I'll wait around for it to be on the USA site. It's easy enough to screw up a download even in English!
 Jerry Canon's gear list:Jerry Canon's gear list
Sony RX100 III Sony a7 II Sony FE 55mm F1.8 Sony FE 70-200 F4 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS +1 more
Jerry Canon
Is there a version in English anywhere? I can screw it up easy enough there. I sure don't want to mess up at the Japanese site. Talk about a wet dream in reverse!
Nivedita Contributing Member • Posts: 659
After applying 1.21
-Nivedita
Yes. When you extract the exe (Windows version) and you can see firmware update app is loaded and you can see that in English. I do not think any of these firmware updates are in different languages (unless it is specifically mentioned).
-Nivedita
 Nivedita's gear list:Nivedita's gear list
Sony a7R III Sony FE 70-200mm F2.8 GM OSS Phase One Capture One Pro
Pstuff New Member • Posts: 4
Just download the file to your desktop. Unzip the file. Peanuts. Should be in English too.
blue_skies
blue_skies Forum Pro • Posts: 11,868
There is no 'Japanese-only Firmware' - the firmware is universal.
As I understand this, the Japan-only models have a built-in hardware switch which locks the language to Japanese, this to allow lower priced models to be sold in Japan only.
Henry
Sony Alpha NEX-6 Sony a6000 Sony a5100 Sony a7 II Sony a7R II +37 more
rishi o' Senior Member • Posts: 1,462
Updated to 1.21 from the Mac with no problem. Hope I didn't screw myself over by using the japanese update instead of the US one but everything seems fine.
FramerDave wrote:
Taiwan site has link to 1.21 on Japanese site that corrected lenses hunting in dark situations under 1.20.
http://www.sony.jp/ichigan/update/ILCE-7_7R_7S_7M2_6000_win.html
I have not updated to 1.20 yet but heads up for 1.20 users.
Firmware should be universal for all countries.
vett93
vett93 Senior Member • Posts: 4,610
Same here. No problem at all.
BTW, great photos on your website. If you don't mind, what lens did you use for the homeless person photo?
Thanks.
 vett93's gear list:vett93's gear list
Sony a9 Sony a7R III Canon EOS 7D Mark II Sony a6500 Apple iPhone 11 Pro +1 more
Ari Aikomus
Ari Aikomus Veteran Member • Posts: 9,379
I did just update without problems (A6000)...n/t
- Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
Marky12
Marky12 Contributing Member • Posts: 761
Re: I did just update without problems (A6000)...n/t
Are we sure that the firmware is the same for all countries? Don't want any surprises like battery exploding.
 Marky12's gear list:Marky12's gear list
Sony RX100 Sony a7 III Tamron 28-75mm F2.8 III Tamron 17-28mm F2.8 Di III RXD Samyang AF 85mm F1.4 FE +2 more
Slingers Regular Member • Posts: 140
I went to the Sony Australia site to download v1.20 and the file to download was in the Sony Japan site. I don't think there is a difference with the files per site.
 Slingers's gear list:Slingers's gear list
Sony Alpha NEX-7 Sony a7S
Foxbat121 Senior Member • Posts: 1,599
They are the same since first generation NEX cameras. If you don't feel good about it, there is no harm wait a few more days or weeks for your region's Sony to post the link.
 Foxbat121's gear list:Foxbat121's gear list
Sony a6000 Nikon 1 J4 Nikon 1 J5 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 180mm f/2.8D ED-IF +15 more
slstr Senior Member • Posts: 1,029
1.21 firmware works good on my a6000, was trying it out for a good hour around sunset with a new sel50f18, so far a happy camper. can't say how much hunting improved yet, will try night photos during weekend.
 slstr's gear list:slstr's gear list
Sony a7S Sony a7 II Sony a7R II Sony a9 Sony E 30mm F3.5 Macro +12 more
Vuong Nguyen New Member • Posts: 10
Hi Nivedita,
There are three files for 3 different a7 cameras, but not for the a7m2.
Please tell me which one was used to update your a7m2.
Thanks so much.
beanxiu
Marky12
The a7ii has another link I believe. Go back a page, someone posted it there.
