Exceptional lens
Started Apr 7, 2015 | User reviews
axlastro Regular Member • Posts: 497
Exceptional lens
This lens is really exceptional. The image is sharp from corner to center at all apertures with maybe a little softening at 11 mm at the far corner at least in my copy, which I've seen in only one shot so far, so it shouldn't be an issue. If I had to find any flaws, it will be the fairly visible barrel distortion which goes away at about 14mm. The bad news is Adobe Lightroom's profile doesn't correct the distortion very well. The good news is the lens is small, not vey expensive and very well built. It also focuses pretty quickly on the M1 and the IS works flawlessly. I won't give it 5 stars just because of the little more than usual distortion at the short end. The other problem that isn't actually connected to the lens is the lack of viewfinder on the eos-m, which makes composing shots quite hard with a wide angle lens.
 axlastro's gear list:axlastro's gear list
Canon EOS Rebel SL1 Canon EF 85mm F1.8 USM Sigma 30mm F1.4 DC HSM Art Canon EOS M Canon EF 50mm F1.4 USM +4 more
Canon EF-M 11-22mm f/4-5.6 IS STM
Wideangle zoom lens • Canon EF-M
Announced: Jun 6, 2013
axlastro's score
4.5
Average community score
4.6
riknash Veteran Member • Posts: 6,874
Re: Exceptional lens
You missed one obvious negative. It has an exceptionally high price. Wouldn't some more moderately priced primes be just as good technically, if not better and be almost as versatile? The other negatives are its huge front lobal element and it's weight. Yes, it would be fun to play with.
 riknash's gear list:riknash's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Canon EF 200-400mm f/4L IS USM Extender 1.4x HTC One
Rock and Rollei Senior Member • Posts: 2,916
It's not at all expensive, and what moderately-priced primes are there in EF-M fit? Equally, the front element is hardly huge - it takes 55mm filters.
Methinks you're somewhat confused, and think this is about the 11-24mm f4 L, not the lens in question... and anyway, even if it was, what 11mm primes are there for full frame?
 Rock and Rollei's gear list:Rock and Rollei's gear list
Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R Canon EOS M6 II Canon EF 50mm f/1.2L USM +29 more
OP axlastro Regular Member • Posts: 497
Yep, quite a lot of people would have them confused. Canon did a good job making it's M line totally unknown to many people. This might be the only real negative to the 11-22 - the M system.
Oh gosh, yup.. I misunderstood which lens this was. Probably a bargain then....
Abu Mahendra Veteran Member • Posts: 5,312
You heard it here first.
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
kotmj Contributing Member • Posts: 571
Very high contrast, sharp across the frame, flare resistant, quick focussing, improbably small and light, and extremely affordable.
