I want to back up sd cards on an external hard drive... but without a laptop :-/
Started Apr 7, 2015 | Discussions
Sup3rlevure Junior Member • Posts: 48
Hi everyone,
Are there any solutions to back up sd cards on an external hard drive without a laptop? Its seems hard with tablets, even Windows tablets - unless it's the expensive Surface pro 3.
Photobank / hyperdrives seem stuck in the 1990's when you look at their price! Also, many customers report that theyy are quite flimsy.
This is mostly for when I travel. I worry about losing all my pictures if my sd cards get stolen or if they fail and stop working. Backing up on a small hard drive (like WD Passport) would limit the risk of losing everything. Obviously, a laptop would be too heavy to carry around.
Thanks for reading.
 Sup3rlevure's gear list:Sup3rlevure's gear list
Fujifilm X-T1 Fujifilm XF 35mm F1.4 R Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 56mm F1.2 R Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR
AdHoc007 Contributing Member • Posts: 657
Re: I want to back up sd cards on an external hard drive... but without a laptop :-/
Sup3rlevure wrote:
Hi everyone,
Thanks for reading.
It's possible, here is a WD hard drive that has wireless capability as well as an SD card slot.
http://www.bhphotovideo.com/c/product/1076399-REG/wd_wdbdaf0020bbk_nesn_2tb_my_passport_wireless.html
 AdHoc007's gear list:AdHoc007's gear list
Fujifilm X-T1 Fujifilm XF 18-55mm F2.8-4 R LM OIS +1 more
OP Sup3rlevure Junior Member • Posts: 48
AdHoc007 wrote:
Sup3rlevure wrote:
Hi everyone,
Thanks for reading.
Amazing! Thank you! It's impressive how much technology they've managed to squeeze in there.
Great reply, thanks.
Sup3rlevure wrote:
AdHoc007 wrote:
Sup3rlevure wrote:
Hi everyone,
Thanks for reading.
I was surprised too, and the price is fairly reasonable compared to similar products. Warning though, BH isn't shipping anything till Passover is done.
AdHoc007 wrote:
Sup3rlevure wrote:
AdHoc007 wrote:
Sup3rlevure wrote:
Hi everyone,
Thanks for reading.
I'm in the uk, and I found it on Amazon uk. There is even a 1tb model available, which is fine as I'm not interested in streaming audio or video.
h andersen
h andersen Regular Member • Posts: 322
Used WD My Passport for 5 month, and it´s bin a plearsure all the way. Only drawback is, that i cannot copy from disc to the sd card. ( it would be nice to keep a copy of camera/lens software here , as a backup, in case of....)
 h andersen's gear list:h andersen's gear list
Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
h andersen
I forgot to mention. You can store jpg. tiff. and raw files on this devise. But you only can view jpg. and tiff. on laptops and Iphones using WD My cloud software.
Muresan Bogdan Contributing Member • Posts: 512
Also for the Fuji you can use the app with an Ipad or phone to backup your Jpgs even full size. I think it should be enough for backing up.
 Muresan Bogdan's gear list:Muresan Bogdan's gear list
Canon EOS 5D Mark III Fujifilm X-T1 Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-105mm f/4L IS USM +1 more
Do you mean backing up pictures on the ipad/phone memory? They don't have much memory, though.
I think that's ok, I'm really not interested in the streaming feature of the device. I'll just transfer all files to the PC and cloud when I'm back home.
h andersen
No. But you can check the pictures on Ipad/Iphone. Nice feature if you don´t have a computer with you.
Well some phones support up to 128 Gb SD cards. This should be enought to backup Jpgs from a trip. Also the Ipad comes in 64Gb but is kind of expensive. HDD will do also but you might end up keeping it in the same bag with the SD cards/camera. So phone could make more sense as it is usually in your pocket separately from the other stuff Backup means nothing if all 10 media you use are in the same place. Loss/steal/fire anything that happens usually will happen to all the items that you store in the same place.
shotguns Contributing Member • Posts: 920
I have a 128 ipad and use the card reader to pull off photos from the day to see how well/poorly things went. Not uber speedy but it works.
 shotguns's gear list:shotguns's gear list
Sony a9 II Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
DarkRider New Member • Posts: 10
I do it, for one year now, with my Samsung Android Tablet.
Using a OTG USB Hub (not the original Samsung. An other one which I bought for around 15 Euros on Amazon (Germany)) where I can plug the SDs directly in and which has 2 seperate USB Ports for HDs etc.
I can copy my pictures from the SD Card to the memory of the tablet and, if I connect the Hub to power, I can connect my WD Passport on it and copy the pics from the SD to the HD (JPG and RAF).
Further I have a app on the Tablet where I can view the RAF files and the JPGs.
I think, if you have a tablet and don't like to carry so much stuff with you (backpacking, motorcycling....) it will be hard to find a cheaper and safer solution.
Vic Chapman Forum Pro • Posts: 10,694
I take a small netbook plus some flash drives.
The sky is full of holes that let the rain get in, the holes are very small - that's why the rain is thin.
Spike Milligan
 Vic Chapman's gear list:Vic Chapman's gear list
Fujifilm X-Pro1 Fujifilm X-E1 Fujifilm X-T2 Fujifilm X-H1 Fujifilm XF 35mm F1.4 R +11 more
SwedishPhoto Regular Member • Posts: 430
Sup3rlevure wrote:
AdHoc007 wrote:
Sup3rlevure wrote:
AdHoc007 wrote:
Sup3rlevure wrote:
Hi everyone,
Thanks for reading.
I have the 1TB one and i Love it! It's not the fastest to backup, but it's still so worth it. The WiFi works great as well. Highly recommend it.
Edit: The different variants gets physically thicker as you go up in storage size. IE: my 1TB:er is thinner than the 2TB:er. But they're all still very portable ofc.
 SwedishPhoto's gear list:SwedishPhoto's gear list
Fujifilm X100F Canon EOS M Sony a7 II Sony a7 III Sony FE 70-200 F4 +7 more
The above mentioned HD is still more convenient, and doesn't need a tablet or laptop. But it do cost a bit ofc, but it's very much worth it, imo. And the WiFi and USB on it makes it perfect for basically everything (Tablet, Phone, Computer).
I agree, the WD WiFi HD is a great tool but the reason I prefer the way with my tablet is because I like to examine my copys and like to view the pics on the tabletscreen. (give keywords, sort out........).
But there a lot of other things I like to do when I am travelling so I like to have my tablet with me.
Btw my solution (OTG USB Hub and any small, portable HD) works with my smartphone too.
That sounds really good. What hub do you have? Last time I bought a powered hub, it was not working well at all.
win39 Veteran Member • Posts: 5,560
How do you know...
...whether the back up has worked?
You really need a back up on a device designed for photography, not a generic wireless hard drive. You need some sort of display to see the filing system at minimum.
UDMA Color Space
http://www.bhphotovideo.com/c/search?Ntt=sanho+hyperdrive+colorspace+udma2&N=0&InitialSearch=yes&sts=ps
