1Dx and Sigma 150-600mm Contemporary
Started Apr 5, 2015 | Discussions
Micloi Regular Member • Posts: 419
Canon EOS-1D
mansod
mansod Senior Member • Posts: 1,226
Re: 1Dx and Sigma 150-600mm Contemporary
Micloi wrote:
First quick shots with the 1Dx
Overcast weather. No noise reduction or sharpening, just adjusted levels.
https://dl.dropboxusercontent.com/u/16187250/Canon%201DX/A21P7811.JPG
https://dl.dropboxusercontent.com/u/16187250/Canon%201DX/A21P7812.JPG
https://dl.dropboxusercontent.com/u/16187250/Canon%201DX/A21P7814.JPG
Looks nice. But some sort of sharpening seems to be applied. Right?
Also, you need to clean your 1Dx sensor.
Thanks for sharing!
 mansod's gear list:mansod's gear list
Nikon D7100 Nikon D610 Nikon D7200 Nikon D500 Nikon AF-S Nikkor 300mm f/4D ED-IF +6 more
bontemps Regular Member • Posts: 296
Huh?
Micloi, you previously shot some comparison tests with the Tamron, Sigma S, and 300 PF, any chance you could shoot those same targets with the Sigma C? Because of course what everyone wants to know is whether it is as good or better than the Tamron, even if it is clearly pretty good.
mansod
bontemps wrote:
Huh?
There are some dust spots on the sensor. And it looks like some sort of sharpening has been applied. Maybe the default sharpening of the RAW converter? I could be wrong but it does not look completely unsharpened to me.
poppyjk
poppyjk Contributing Member • Posts: 943
I want to like the Sigma lens but am confused by the claim of no sharpening or noise reduction in the samples when detailed EXIF appears to show otherwise.
Happy to receive some education on the data.
http://regex.info/exif.cgi?b=3&referer=https%3A%2F%2Fdl.dropboxusercontent.com%2Fu%2F16187250%2FCanon%25201DX%2FA21P7811.JPG&imgurl=https%3A%2F%2Fdl.dropboxusercontent.com%2Fu%2F16187250%2FCanon%25201DX%2FA21P7811.JPG
 poppyjk's gear list:poppyjk's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EF 35mm F1.4L II USM +5 more
OP Micloi Regular Member • Posts: 419
The file was opened in Adobe camera raw, levels adjusted and saved, no sharpness or noise reduction was applied except the default settings of the raw converter.
And yes the sensor will be cleaned this week, just acquired the camera yesterday.
Even though I do not know anyone that does that, to keep everyone happy, I reloaded the raw file and turned even the default (minimal) noise reduction and sharpness in adobe camera raw to 0.
This is the resulting file, IMHO there is a slight difference but nothing too obvious even on my 27 inch monitor.
https://dl.dropboxusercontent.com/u/16187250/Canon%201DX/A21P7812%20NS.jpg
Do not have the sport or the Tamron anymore. I have the 300mm pf but the contemporary is Canon fit so a comparison between 2 different cameras would not really be too helpful.
poppyjk
Thanks for going to the trouble.  Minimal but perceptible differences.
The lens looks like a keeper.
Anxious to see more samples.
sjphoto Regular Member • Posts: 295
It looks like we will have to wait for more in depth samples from the Sigma C lens, as it is still early on the market. This link, https://photographylife.com/reviews/tamron-150-600mm-f5-6-3, to me, are some of the best shots I have seen in a review of the Tamron 150-600. Unless the Sigma C can produce images like these, I will have to go with the Tamron. I have until late May, early June before I will need the lens, so hopefully by then there will be enough sampling to make my decision. Right now, its the Tamron, the Sigma C has a couple of months to change my mind.
 sjphoto's gear list:sjphoto's gear list
Nikon D7000 Nikon D800 Nikon D500 Tokina AT-X Pro 12-24mm f/4 DX II Sigma 8-16mm F4.5-5.6 DC HSM +6 more
mansod
Thanks! I was just wondering. I have the sharpness slider on zero by default in ACR and sharpen in PS using smart sharpen.
How is the AF speed and accuracy? I do feel the Tamron 150-600 is sharp enough for me but the AF is a bit inaccurate at times. It's fine for stationary/slow targets but for fast birds in flight you get a lot of slight focus misses for every in focus shot.
If the Sigma C has as good AF as the Sigma S seems to have I might just have to buy one.
Difficult to compare without having both lenses side to side I am afraid but I can just say that I find the AF of the C version fast and accurate.
buybuybuy
buybuybuy Veteran Member • Posts: 5,388
Thanks for taking the trouble to post these. It's good that you posted the unsharpened example, because "default" settings vary. I, for one, have NO RAW sharpening applied--all sliders are set to zero--in ACR, and there is an appreciable difference between the sharpened and unsharpened examples you provided.
CaryT Junior Member • Posts: 47
Little Hummer
Handheld jpg straight from the camera; not sure if this will be full size or not in the forum.  I'm pretty happy with the lens: quiet focus and image stabilization.  My neck, however, is not...  ouch.
monographix
monographix Regular Member • Posts: 492
I think those images are sellers for the C ...
I have seen this good or even better quality images from the C, but also i saw very bad ones too and makes me wonder: Apart from the ones that heat haze is obvious, in the case of the rest of bad images i wasn't able to say for sure if it looks as a back or front focus issue, so what could it be? Calibration issue with specific bodies / copies?
For example here
http://www.imaging-resource.com/news/2015/03/30/sigma-150-600mm-contemporary-lens-review
the 7D images are ok but the 1D images are disappointing. They have this common spoiler in all the bad images i have seen from C : appear to be in focus but are wrapped in a hazy glow as if an effects filter is used or some sort of softening cloth is placed in front of the lens
Nick
www.flickr.com/nickdelhanidis/sets
monographix.deviantart.com/gallery
 monographix's gear list:monographix's gear list
Nikon D500 Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 17-50mm F2.8 EX DC OS HSM Samyang 8mm F3.5 Aspherical IF MC Fisheye +7 more
monographix
Micloi wrote:
You have switched from Nikon to Canon or you work with both systems?
Nick
Both
monographix
These images are solid sellers .... if only the Nikon mount was already out ....
Nick
