Issue with 40mm EF lens on 350D
Started Apr 4, 2015 | Questions
DePurpereWolf New Member • Posts: 3
Dear all,
I recently purchased a 40mm EF lens f/2.8 stm.
To my surprise when I mount it on my canon 350D, the light metering seams to be all off. In automatic setting It takes pictures that are very over exposed. It also insists on using the flash when it's not necessary.
I can make a good picture when I adjust shutter speed myself (Tv), but I would like to use the automatic settings (the green rectangle). This is now impossible because it over exposes everything
Is this a known issue?
Is there something I can do to rectify it?
Canon EF 40mm f/2.8 STM Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N)
imqqmi Veteran Member • Posts: 8,639
Re: Issue with 40mm EF lens on 350D
DePurpereWolf wrote:
Dear all,
Hoi!
Have you checked if the aperture is being set correctly? Greenbox mode and flash isn't great, especially on older camera's. To take full control, I recommend the use of M mode instead. This way you're able to balance ambient and flash.
Kind regards
Imqqmi
Links:
View my webgallery
http://www.pbase.com/imqqmi
The DSLR jargon cheatsheet
http://www.jmbfoto.nl/dslrcheatsheet.pdf
Sunset blending tutorial
http://www.jmbfoto.nl/tutorial/blendingTutorial01a.pdf
Wilba's Frequently Asked (beginners) Questions and answers
http://snipurl.com/RebelFAQ
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
seri_art
seri_art Veteran Member • Posts: 3,063
I don't know what is wrong, but try using P (Program) mode instead A (Automatic) and see if that works. P mode is mostly automatic but lets you also set some things.
 seri_art's gear list:seri_art's gear list
Sony RX100 III Canon EOS Rebel T7i Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
Ed Rizk Veteran Member • Posts: 3,898
I agree completely.  P gives you all the advantages of the green box, but allows you to make adjustments and only uses flash when you manually open it.
M is great if the light is perfectly consistent, or you just want to go through the entire adjustment process for each shot.  Personally I don't use it that often and have shot my 60D for almost 4 years and had two EOS film cameras in the 80's and 90's.  P will get it right the vast majority of the time, and with the screen, you can see when it gets it wrong and can make any kind of adjustment.  If you are involved in what's going on in any way other than to photograph the scene, conversation, detailed observation, etc. M requires way too much concentration for just a little benefit, IMO.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 6D Canon EOS R Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +4 more
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
I can't think of any reason that should happen. The lens only affects the metering in that it's expected to be wide-open (f/2.8 for that lens) during metering. Everything else is done by the camera body, and about the only thing metering cares about from the lens is the wide-open f-number (2.8 for that lens).
Have you tried removing and remounting the lens, to be sure you got good contact?
Is the viewfinder dim with that lens mounted? If so, it may be failing to "open wide" for metering.
The open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
Rob Bernhard Senior Member • Posts: 1,872
There is no known issue with the 40mm pancake and the 350D.  As has been suggested, I would check the contacts and the mount, to ensure a good clean connection.  I would also make sure the aperture works across its entire range by setting the camera to AV, pressing the DoF Preview button, and and rolling the wheel across all possible values while looking at the lens (front of the camera, not through the viewfinder).
OP DePurpereWolf New Member • Posts: 3
Thanks to all for your insightful replies.
I have checked the contacts and mount, I could find nothing out of the ordinary. However, I will try with another canon camera to rule this out.
I have tried to see if the aperture is opening up with Av as suggested, but I couldn't really see anything. So instead I have made some pictures in m-mode, at different apertures, and there was a clear difference between the photos. So I believe the aperture is working.
I can live with using P mode, if I don't find a cause, than this is the way to go.
Thanks again,
Just to be clear, you need to keep holding down the DoF Preview button while turning the dial to see the aperture change rapidly.
