Re: 100-400 MK II tripod foot WARNING (additional considerations)
Landscapeforwouldn't landscape for funly of passing interest but just for fun, I removed the base plate on the tripod collar where the tripod foot is mounted for a close look under a magnifier.
The small, black base plate appears to be die-cast alloy and is held in place with 4 x M2 (2mm dia) screws - two of which had a light application of Loctite or equivalent - on their threads. The base carries the M5 mounting hole into which the stock foot (or after market alternative) is bolted.
The M5 thread is implemented using a "helicoil" type insert (similar to the ones in the photo below) rather than a solid threaded insert like the 1/4" x 20 UNC one in the foot itself. In my experience in engineering, the helicoil type insert is commonly used for repairing damaged threads.
I'm guessing that Canon chose this method of implementing the thread because of the strength advantage over simply drilling and tapping the alloy base plate itself. However, I don't really see much strength advantage in this method compared with say, a solid stainless threaded insert (threaded on both sides) screwed into the base plate. Possibly, it's cheaper.
All this is academic I know, but what it boils down to is that you have the tripod foot bolted into this small, alloy base plate on the collar with a M5 screw. The foot is then bolted to something else (Arca-Swiss plate, ball-head or whatever) via a 1/4" x 20 UNC screw which screws into the bush which, as has already been established, is only an interference (push) fit in the alloy foot.
You then have the entire weight of the lens and camera body (which might in some cases also have a battery grip, flash, additional filters etc attached) ALL SUPPORTED BY JUST 4, TINY M2 WATCH SCREWS! Attaching any form of after-market foot makes no difference.
Obviously, there's no problem if the entire load is resting vertically downwards on the foot with the camera/lens rotated solely by means of the collar. However, I hate to imagine the shear stress on those 4 screws if the camera/lens were tilted into portrait mode using a ball head with the foot in the horizontal position. Or worse, with the whole rig hanging off the end of a tripod swung over a shoulder as some shooters do when moving around.
The Mk I version had a VERY solid collar and tripod foot cast as a single component that was built like a tank and impossible to break even if bounced around over the shoulder fixed to a tripod. The MK II is flimsy in the extreme by comparison and has nothing like the load bearing ability of the Mk I.
It seems to me the collar/foot design on the Mk II is seriously compromised in terms of load bearing capability especially given that this lens is even heavier than the Mk I. This is the only criticism I would make of the build quality of this lens and I fail to see why Canon wouldn't have made the collar/foot much beefier like the Mk I. Cost savings again, perhaps.
I'd recommend all owners of this lens to bear this in mind and avoid unduly stressing those 4 tiny screws when mounting the camera/lens on a tripod or carrying it around. At least, never carry it around hanging off the end of a tripod without some additional support. Also, when using any form of after market foot, make sure that the M5 screw used to mount it is NOT so long that it "bottoms out". If this happens and the screw is continually tightened, it could "jack up" the alloy base plate stripping the M2 threaded holes in the collar with potentially disastrous results. The sound of a heavy camera and lens hitting concrete must be one of the most sickening sounds it's possible to encounter!
Thanks for reading.
The breaking strength of a single m2 screw is around 300lbs... I think 4 of them can safely hold the lens. I suppose if you attempt to fight off a brick wall by swinging the lens from the end of a tripod as hard as you can you might be able to break one of the screws of you are very unlucky. Of course the lens itself will be dust by then, but at least you'll have shown how "weak" the tripod collar is.
-Adam
https://www.flickr.com/photos/90719248@N04/
Correct. It wouldn't be the screw that would fail or snap just from tension. If anything, it would be the thread in the soft alloy that would strip if the foot were stressed enough.
