FA 50 1.4 vs DA 50 1.8
Started Mar 31, 2015 | Questions
soheil Veteran Member • Posts: 3,025
Re: FA 50 1.4 vs DA 50 1.8
Bernie3 wrote:
Thanks for the responses. I have a good copy of the FA 50/1.4 and will keep it.
Bernie
If you decide to keep it, do not look into Sigma 50mm f/1.4 EX
I have both FA 50/1.4 and DA*55/1.4. Although some reviews suggest no big difference between the two, I much prefer the 55, it has something special maybe in better micro contrast.
Soheil
It's the singer not the song.
 soheil's gear list:soheil's gear list
Pentax Optio 330GS Pentax MX-1 Pentax K-7 Pentax K-5 Pentax K-5 IIs +19 more
DAVID MANZE Veteran Member • Posts: 6,390
soheil wrote:
Bernie
Soheil
Given the era and the complexity of construction I wouldn't expect otherwise, sans parler du prix!
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 28mm f/2.8D +17 more
KL Matt Veteran Member • Posts: 5,999
ogl wrote:
J
However, at least on the older model f/1.4s (m50 in my case), the speed of the lens does benefit comparatively when stopped down somewhat. The sharpness at f/2 is pretty good. However, the f/1.8 is still practically wide open at f/2 - and some bloom is still evident. Also, longitudinal CA (purple in front, green behind point of focus) is much more evident.
The lenses are pretty close to equal overall, but their strengths differ. It isn't surprising that the newer, designed for crop sensor, lens will be a bit sharper at most apertures. However, for fast aperture shooting (f/2.4 and faster), the f/1.4s are probably at least as good.
Bottom line, if I had an FA and was happy with it, I wouldn't look at the DA f/1.8. However, the m50 is not a FA - and I like having the AF option and better metering options.
I've tried A50/1.4 - it seems to me it's better than FA50/1.4 wide-opened.
I have both and couldn't tell any difference in performance whatsoever on a K10. There performance was nearly identical at all apertures. I haven't compared them on my K5, however.
Matt
... interested in .... photographs? Heh? Know what a mean? Photographs? (He asked him knowingly). Nudge nudge, snap snap, grin grin, wink wink, say no more, say no more, know what a' mean? Know what a' mean?
http://www.pentaxphotogallery.com/home#section=ARTIST&subSection=183820&subSubSection=0&language=EN
madbrain
madbrain Regular Member • Posts: 186
I know this is an old thread, but I will comment on this.
I have a DA 50/1.8 which I bought new years ago, as well as an FA50/1.4 which I bought used last week.
I tested both on my K-1 II. Both lenses fill the entire sensor, though I have to force FF mode with the DA50.
The DA 50 autofocuses faster and more reliably than the FA 50.
The FA50 is absolutely no good wide open at 1.4, at least on my copy. But it becomes great when stopped down to f2.0 .
When comparing both lenses at f1.8, the image from the FA50 is bit sharper than the one from the DA50, but it's not a night-and day difference.
I would say that in the majority of situations, the DA50 is the better choice, as you don't have to spend extra time to manually stop it down, and it autofocuses better. If you have a high ISO camera like a K-P, K-1 or K-1 II, letting the camera just bump the ISO slightly higher will probably work just as well.
I'm actually torn on as I thought I would sell my DA50 after acquiring the FA50, but the FA50 isn't superior to it in every respect. I will probably end up keeping both ...
 madbrain's gear list:madbrain's gear list
Panasonic Lumix DMC-GX85 Pentax K-1 II Pentax smc FA 50mm F1.4 Tamron AF 28-300mm F/3.5-6.3 XR Di LD Aspherical (IF) Macro Sigma 70-300mm F4-5.6 APO DG Macro +9 more
Alwina H Regular Member • Posts: 376
That's the spirit, Madbrain!
A.
Historicity Senior Member • Posts: 2,342
Madbrain,
Hmm, in a recent thread (on the K1) when I was trying to get some idea of what the soon to be released DFA 50 f/1.4 had that my FA 50 f/1.4 didn't have -- for hiking purposes, I came away with the idea that I would have no reason for buying the DFA 50.  The discussion expanded to include the F 50 1.4, FA 50 f/1.7, and the DFA 50 f/2.8.  One person mentioned the DA*55 f/1.4, saying it was excellent at full frame.  I tried it and agreed.  In fact I have all of these lenses and tried them all during the discussion.  No one mentioned the DA 50 f/1.8, if I recall correctly.  Thus, I was surprised to read through this old thread and see the DA 50 f/1.8 given so much respect.   No one quite gave up their FA 50 f/1.4 for one, but they were thinking about it and almost did.
I bought a KP recently; so perhaps I should revisit the DA 50 f/1.8.
Lawrence
 Historicity's gear list:Historicity's gear list
Ricoh GR II Pentax K-5 IIs Olympus PEN E-PM2 Olympus E-M1 Nikon D610 +108 more
