FA 50 1.4 vs DA 50 1.8
Started Mar 31, 2015 | Questions
Bernie3 Regular Member • Posts: 186
I have the FA 50 f/1.4 and K5IIs and plan to stick with APC. I could sell the FA 50 and purchase a DA 50 f/1.8. Would the DA 50 f/1.8 be better?  Is the DA sharper edge to edge?
Bernie
 Bernie3's gear list:Bernie3's gear list
Panasonic Lumix DMC-ZS50 Pentax KP Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc D-FA 100mm F2.8 Macro WR Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +4 more
Pentax smc DA 50mm F1.8 Pentax smc FA 50mm F1.4
DrewE Senior Member • Posts: 2,053
Re: FA 50 1.4 vs DA 50 1.8
I think the DA 50 1.8 has a very similar optical design to the FA 50 1.4 (and lots of other traditional "fast 50" lenses), and likewise similar performance.  The coatings may be slightly better, leading to better flare control on the newer lens, but hardly enough to worry about.  I'm not positive about that, though.
If you want better performance at large apertures, the 55/1.4 lens would be the obvious choice among Pentax's lenses.  If you want noticeably better performance at moderate or small apertures, you'll probably be looking for a pretty long time.
--DrewE
 DrewE's gear list:DrewE's gear list
Pentax K10D Pentax K-5 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc DA 40mm F2.8 Limited Voigtlander 58mm F1.4 Nokton SL II +3 more
KL Matt Veteran Member • Posts: 5,999
I'd probably go with the newer lens for the coatings and potentially better contrast wide open, but I can't confirm any of that because I've never shot the DA 50 1.8.
The FA 50 1.4 is nothing to write home about wide open. I view that aperture as useful in extreme low light only -- fun shallow-DOF shots suffer from low contrast at that aperture. The FA 43 at f/1.9 is far better in that regard, possibly the 50 1.8 is as well.
M
Bernie
... interested in .... photographs? Heh? Know what a mean? Photographs? (He asked him knowingly). Nudge nudge, snap snap, grin grin, wink wink, say no more, say no more, know what a' mean? Know what a' mean?
http://www.pentaxphotogallery.com/home#section=ARTIST&subSection=183820&subSubSection=0&language=EN
karet Contributing Member • Posts: 504
Have a look at comparisons of bokeh. I like the octagonal shape of highlights I get with the FA 50 1.4 at around f 2.8 or f 3.5  . You would loose that when you go for the DA lens.
Karet
 karet's gear list:karet's gear list
Nikon Coolpix 5200 Pentax K-5 II Pentax K-3 Pentax smc FA 50mm F1.4 Pentax smc DA 16-45mm F4 ED AL +9 more
fakuryu
fakuryu Senior Member • Posts: 1,348
Bernie
Do you have a good copy? If you do, I don't think you'll gain anything from switching to the DA50 f1.8
There is no such thing a "Pro" level gear, just Pro level work.
 fakuryu's gear list:fakuryu's gear list
Panasonic Lumix DMC-LX7 Olympus PEN E-PL1 Pentax K-r Pentax Q Pentax K-5 II +1 more
DAVID MANZE Veteran Member • Posts: 6,390
M
Bernie
My trusty camper wagon awaiting it's vehicle road worthyness test!
Here you go with the FA50 @ F1.4 1/4000 sec. ISO 200 a little PF reduction and a tad of sharpening, it's dammed sharp fully open, taken with the K01. OK wide open there is flare in high contrast situations, but hey, it's an oldie!
Dave's clichés
 DAVID MANZE's gear list:DAVID MANZE's gear list
Nikon D750 Nikon D500 Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF Nikkor 24mm f/2.8D Nikon AF Nikkor 28mm f/2.8D +17 more
paulkienitz
paulkienitz Veteran Member • Posts: 5,459
Bernie
It's better, but IMO the difference is very small.  I switched only because the 1.8 was included free in a bundle.
"A good photograph is knowing where to stand." -- Ansel
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
Heh don't get me wrong, I had that lens glued on my *istDS for years. There is a lot of fun to be had with it on digital. It's just I think I'd choose the modern lens on a modern Pentax body. Lighter, better coatings, probably better AF, colors, and contrast. But yeah it would be nice if someone with experience with both could chime in. New lens has no aperture ring and is not all metal, however.
Matt
M
Bernie
JNR
JNR Veteran Member • Posts: 4,652
While it is true that they are similar in optical design, they have somewhat differing characteristics by most reports (much like the two 35mm lenses - f/2 and f/2.4 are not similar due to differences in build between FF and crop designs).
I have the m50mm f/1.4 and the DA 50mm f/1.8 (newly acquired at $119 - had to go for it). They are similarly not sharp wide open. If the contrast and flare resistance is better on the newer lens, it doesn't appear significant in my early comparisons. The build on the f/1.8 is very impressive - and I really don't care about plastic vs. metal. The dampening in MF is very good (almost too much).
If there is a slight edge, based on the early shots - a week's worth - the newer lens does not appear to be quite as sharp at the f/2.2-2.8 range as the older optic; but is great at f/4. Have no idea if that's because the older lens is faster (doubtful), or because it's FF. However, the difference isn't substantial - and my experience is very limited.
The 50mm f/1.8 is reputed, based on testing, to have nearly no CA. However, my early shots indicate longitudinal CA - and it is very apparent at relatively close focus. I hadn't seen that in the older lens - at least not to the same extent. The DA seems to be optimized for distance shooting.
JNR
www.jamesrobins.com
 JNR's gear list:JNR's gear list
Fujifilm X-T2 Fujifilm 50mm F2 R WR Phase One Capture One Pro Pentax K-01 Pentax K-3 +22 more
Petroglyph
Petroglyph Veteran Member • Posts: 6,096
paulkienitz wrote:
Bernie
Me also.  And the Novoflex adapter even gives it a metal mount & aperture slider for my NEX-7.  Seems like a great lens but is not used by me so much.
 Petroglyph's gear list:Petroglyph's gear list
Sony a7R II Zeiss Batis 25mm F2 Zeiss Batis 85mm F1.8 Samyang 20mm F1.8
JNR
Karet
Respectfully, I would disagree. The f/1.4 has 8 linear blades that create an unnatural symmetry easily picked up by the eye. The DA has 7 rounded blades that create a much more rounded look between f/2.4 and f/8 (roughly), and the critical eye is far less drawn to the more natural appearance created by odd-numbered blades which are not in opposition to each other.
Not that the bokeh overall is much superior to the f/1.4 look IMHO, but it most certainly is not worse.
JNR
www.jamesrobins.com
All that yeah, but somehow people have missed the point here, the FA 50mm has F1.4 not 1.8!
I just like the old FA for all it's faults, the build quality and weight is very decent with it's metal mount and S/H you should pick one up for $200.
In troubled times when needed this lens when thrown accurately at the head should keep an assailant down long enough to effect your escape, the 1.8's injuries would be negligible.
I have it on good authority that the SAS are never issued plastic lenses!
Dave's clichés
JNR wrote:
Karet
Hmm, I was a bit fast, didn't check the blades and thought it had only 5. You're right, 7 rounded blades, it will probably look allright.
Karet
stern Senior Member • Posts: 1,740
Bernie
if you have a good copy of the FA 50/1.4 - keep it! These are pics I took with mine all at f1.4:
http://sternbild.zenfolio.com/p960599886
 stern's gear list:stern's gear list
Pentax MX-1 Sony RX100 VA Pentax K-3 HD Pentax DA 15mm F4 ED AL Limited HD Pentax-DA 20-40mm F2.8-4 ED Limited DC WR +1 more
OP Bernie3 Regular Member • Posts: 186
Thanks for the responses. I have a good copy of the FA 50/1.4 and will keep it.
Bernie
andrew britten Senior Member • Posts: 1,495
I love Europe for its lack of Japanese cars. Okay, there's a Honda here, but you get what I mean.
Keeping on topic, I have the F 50 1.7 (which may be close in design to the DA???) and it's very ordinary wide open.
AB
 andrew britten's gear list:andrew britten's gear list
Pentax K10D Pentax K-7 Pentax K-x Pentax K-5 Pentax K-01 +2 more
prime instinct Contributing Member • Posts: 526
Bernie
If you decide to keep it, do not look into Sigma 50mm f/1.4 EX
 prime instinct's gear list:prime instinct's gear list
Pentax K-01 Canon EOS M Pentax K-5 IIs Fujifilm X-E2 Sigma 50mm F1.4 EX DG HSM +7 more
ogl
ogl Senior Member • Posts: 2,004
Bernie
I had FA50/1.4 for many years and I have DA50/1.8. DA50/1.8 is sharper at all apertures.
It's better than FA50/1.4 in terms of sharpness. FA43 is sharper than FA50/1.4 too.
If you like f/1.4-1.6's bokeh only, keep it...But I don't need soft pictures with such bokeh.
I'm not fan of such fast lenses. 1.8 is enough for me.
 ogl's gear list:ogl's gear list
Pentax K-5 IIs Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited
JNR
ogl wrote:
Bernie
I agree with you that most lenses faster than f/2 need to be stopped down by at least half a stop to be adequately sharp and free of bloom. You also end up with considerable failure to capture all the light due to incidence angle of light at fast apertures.
However, at least on the older model f/1.4s (m50 in my case), the speed of the lens does benefit comparatively when stopped down somewhat. The sharpness at f/2 is pretty good. However, the f/1.8 is still practically wide open at f/2 - and some bloom is still evident. Also, longitudinal CA (purple in front, green behind point of focus) is much more evident.
The lenses are pretty close to equal overall, but their strengths differ. It isn't surprising that the newer, designed for crop sensor, lens will be a bit sharper at most apertures. However, for fast aperture shooting (f/2.4 and faster), the f/1.4s are probably at least as good.
Bottom line, if I had an FA and was happy with it, I wouldn't look at the DA f/1.8. However, the m50 is not a FA - and I like having the AF option and better metering options.
JNR
www.jamesrobins.com
ogl
J
I've tried A50/1.4 - it seems to me it's better than FA50/1.4 wide-opened.
