Canon 35 f1.4 or f2 walk around Asia night time
Started Mar 30, 2015 | Discussions
irm Veteran Member • Posts: 3,105
Hi folks,
looking for a little guidance.
Background. I have a 6D with a 24-70 f4, 40 2.8 and 50 1.4 and a range of longer L glass
I am looking for advise as to purchase a 35 1.4 or a 35 f2 for the nigh time walk around lens.
For day time I might sell the 24-70 f4 and buy the 24-105 STM 3.5.-5.6.
Thoughts please?
Ian M
my 2 exposed flashcubes worth.
Ian the pbase supporter.
http://pbase.com/ianm_au
Please check my profile for equipment list.
An amateur with dreams of being a good to excellent photographer.
 irm's gear list:irm's gear list
Canon EOS 10D Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 50mm F1.8 II Canon EF 135mm F2L USM +9 more
Canon EF 24-105mm F3.5-5.6 IS STM Canon EOS 6D
Abu Mahendra Veteran Member • Posts: 5,312
Re: Canon 35 f1.4 or f2 walk around Asia night time
Canon 35 IS
Hoi An, Vietnam with said lens
Three stops of IS works wonders Sometimes
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
J A C S
J A C S Forum Pro • Posts: 20,544
I own the 35/1.4. It is a good nighttime lens compared to longer ones because of the 1/FL rule.
All handheld:
35/1.4
35/2.2
35/1.4
Formerly known as Just Another Canon Shooter
drh681
drh681 Forum Pro • Posts: 20,742
F 2.0 with the IS
and save 200 grams.
Photons by the bag.
Gravitons no longer shipped outside US or Canada
The best photographic tool is between the photographer's ears, not in front of his nose.
 drh681's gear list:drh681's gear list
Canon EF 40mm f/2.8 STM Lensbaby Composer Pro with Sweet 35 Optic Nokia Lumia Icon
EOSSpeedLite Contributing Member • Posts: 640
35L is the Better...
The 35L F1.4 has 1 stop brighter, and is a sharper lens than the F2.
Brighter, sharper always trumps IS, ESPECIALLY on such a wide lens (35mm).
The F1.4 means more bekah possibilities too.
 EOSSpeedLite's gear list:EOSSpeedLite's gear list
Canon EOS R5 Canon EF 135mm F2L USM Canon EF 8-15mm f/4L Fisheye USM Canon Extender EF 2x III Canon EF 100-400mm F4.5-5.6L IS II +12 more
Re: 35L is the Better...
The 35IS wide open resolves just as much, if not more than the 35L at f/2. It also has less CA.
wazu
wazu Senior Member • Posts: 1,408
Definately the 1.4L for night scenes
Although I only own Canons 35/1.4L I can compare it to my 35/2.0 RX1. Neither have IS which IMO is really  good for landscapes, but not so much when you have people moving around in them.
also skip the 24-105 and save for the 24-70mkII, never thought I would be overwhelmed after shooting with the 24-105 for many years. The 24-70mkII is truly fantastic. Or maybe wait and see if they improve the 24-105 with a mkII version.
There is a crack in everything That's how the light gets in. - Leonard Cohen
Fog Maker Senior Member • Posts: 2,733
All handheld:
35/1.4
35/2.2
35/1.4
I currently don't own it, but I always liked that lens. If Canon charges some crazy money for a mark II, i might settle with that lens instead (just out of protes until Canon comes down to earth a bit)
 Fog Maker's gear list:Fog Maker's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.2L II USM Canon EF 24-70mm f/2.8L USM Canon EF 100mm F2.8L Macro IS USM
J A C S
But it vignettes much more (both at f/2) which makes it not quite f/2 overall. Of course, the 35L vignettes a lot as well but at f/1.4.
J A C S
I am a bit afraid that when Canon releases the II, I will buy it because I would want to own the latest and the greatest  but that may turn out to be a mistake. My copy AF-s perfectly on my ancient 5D2 with every AF point - it just does, no MA. I had some objections about the bokeh in the transition zone initially but after seeing samples from other fast 35mm, including Sigma, and a super expensive Leica, etc., I think that the bokeh is quite good in comparison.
But F2 is still not F1.4, and the differences in CA is minimal worse case.
I have the 35L and for 10 years and I cannot remember ever having to deal with CA issues.
And as to razor sharpness, the 35L wins hands down.
Karl Summers
Karl Summers Regular Member • Posts: 234
irm wrote:
Hi folks,
Thoughts please?
Ian M
Please forget the Canon and consider the Sigma 35mm 1.4. Newer design, sharper images, better image quality, better value.
 Karl Summers's gear list:Karl Summers's gear list
Sony a7R II Sony FE 85mm F1.4 GM
Karl Summers wrote:
irm wrote:
Hi folks,
Thoughts please?
Ian M
Your claims is completely false.
I have never found a wide angle prime sharper than the 35L.  The sigma you mentioned is too soft, not razor sharp.  None of the 8 copies I tried came close to the 35L.
diness Veteran Member • Posts: 3,758
Karl Summers wrote:
irm wrote:
Hi folks,
Thoughts please?
Ian M
?? Are you serious? Every review I have read on the sigma says it is sharper than the 35L. I had the sigma and mine was crazy sharp, sharper than any lens I have owned. I have heard complaints of focus issues with the sigma and some people prefer the bokeh of the 35L, but I have never heard someone say the sigma is soft.
 diness's gear list:diness's gear list
Canon EOS R Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM
Karl Summers
diness wrote:
Karl Summers wrote:
irm wrote:
Hi folks,
Thoughts please?
Ian M
I have also owned the Sigma 35, albeit with a Nikon D610. Oh, and who goes through 8 copies of lens before they decide against it? NOBODY.
Anyways, I may hold out for the 35L Mark II. Something tells me Canon will match the Sigma sharpness with Canon AF reliability...the perfect prime for me.
Have you read the comparo's between the two?  You should...
Al Downie Senior Member • Posts: 1,407
On paper the IS of the f2 model sounds like a good idea, but if you're looking to capture nightlife on the streets then I guess you'll be using shutter speeds that will make IS a bit irrelevant. The 35L on the other hand is legendary for it's nighttime colour saturation and contrast.
I'd have a look for nighttime shots from both lenses in their respective Flickr groups, and see which ones float your boat.
Flickr photos: https://flic.kr/s/aHsjXbgGu9
(Mostly) Photography blog: http://wp.me/r7wg
 Al Downie's gear list:Al Downie's gear list
Fujifilm X-Pro2 Fujifilm XF 35mm F1.4 R Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R APD +1 more
Yes, plenty of them. They seem unanimous that the sigma is sharper. Can you link me to one that says otherwise?
Doug_PS
Doug_PS Contributing Member • Posts: 812
I own the Sigma 35 1.4 and have also used the Canon 35 1.4 extensively. My experience is this:
-The Sigma is the sharpest lens I've ever used (including the Canon 135 2.0L). The resolving power of the Sigma is amazing. The Canon was also very sharp, but the Sigma is in a different league (IMO).
- It took me 3 tries to get a good copy of the Sigma. I can't think that I'm unique and that there must be an element of the "Sigma Lottery" at work here!
- I found the the Canon nails the focus much more consistantly.
- I prefer the quality of the Bokeh and the colors produced of the Canon.
The price difference between the two lenses was the swaying factor for me. I got the Sigma for $799 (Authorized Dealer). The Canon was well over $1,000. If price had been equal (or even close), I might have gone with the Canon regardless of the superior sharpness of the Sigma. Both are fantastic lenses and are great for night street-scapes.
 Doug_PS's gear list:Doug_PS's gear list
Canon EOS 7D Mark II Canon EOS 5D Mark IV Canon EOS M6 Canon EF 400mm f/5.6L USM Canon EF 100mm F2.8L Macro IS USM +9 more
He who denies that the Sigma is the sharpest of the three knows not of what he speaks.
If you are going to shoot night static, I'd say go wl the 35 IS. If you are shooting night action, go with the sigma 24FI.4 Art.
