upgrade to Olympu OMD Em10?
Started Mar 27, 2015 | Discussions
HelloBamboo New Member • Posts: 2
I currently own an Olympus PEN EPM-2, my 2nd M4/3 camera, and am pretty pleased with it. Over teh years I've picked up a number of additional lenses, including the Olympus 150mm zoom, 45/f1.8, 14-42 EZ and the Panasonic 20/1.7.
I am considering upgrading to an OMD EM10. I understand this model is easier to handle, due to teh additional buttons etc and of course the zoomfinder could come in handy. Having said that, the camera is going to be slightly bigger (size is a big reason for me to stick with m4/3 instead of DSLR) and i wonder if I am going to get an better picture quality given that the sensor seems to be the same (16Mpix Live MOS - or is there a difference?)
what are your thoughts? I sit worth the 500 $/€ for the upgrade or am i not going to see a difference in my pictures?
johnCam Regular Member • Posts: 265
Re: upgrade to Olympu OMD Em10?
You make a good point about the em10 using the same sensor as your epm2.  But, for me, the viewfinder on the em10 really improves the picture taking experience.  Two control dials is also an improvement.
 johnCam's gear list:johnCam's gear list
Fujifilm X-H2S Fujifilm XF 18-55mm F2.8-4 R LM OIS Olympus OM-D E-M5 Olympus M.Zuiko Digital 25mm F1.8 Tamron 150-500mm F5-6.7 Di III VC VXD
bs1946
bs1946 Veteran Member • Posts: 7,780
The image's out of any of the Pens or OM-Ds are great, even the 12mp ones. But it's not just the Sony 16mp sensor that your EPM-2 shares with the newer OM=Ds and Pens, but it's also all the advanced improvements the E-M10 will deliver. You get the EVF, the latest processor, much better CDAF, 3-axis IBIS, 0-second anti shock setting, WiFi, a much better tilting LCD with a 4:3 format instead of the 16:9 format you have now, much better control setup and ergonomics, and a bunch of other stuff that's too long to list.
What will you loose? The very small size of the EPM-2 and the ability to stuff the camera in your pocket with your 20mm f1/7 or 14-42mm EZ on it, because the E-M10 is larger and you would need a pretty big pocket.
If you don't care about the EVF, you might want to look at the EPL-7. Under the hood, it's an E-M10, plus the ergonomics and control layout are much better than your EPM-2 or even my EPL-5 that I got as a backup for my E-M10. Size-wise, the EPL-7 is larger than the E-PM-2 and smaller than the E-M10. The EPL-7 the same size as my EPL-5 and with my 17mm f/1.8 or 12mm f/2.0 on my EPL=5, I can put it in my jacket pocket.
Bill S.
“Your first 10,000 photographs are your worst.” Henri Cartier-Bresson
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
The sensor is pretty much the same in all of E-PM2, E-PL5/6/7, E-P5, E-M1/5/5ii/10 but the addition of 0 second anti shock and 3 axis IBIS in the E-M10 will make a noticeable difference in some conditions.
Plus of course a few more features in the newer firmware makes it a nicer camera to use.
Regards...... Guy
OP HelloBamboo New Member • Posts: 2
thanks all... still not decided yet!
