350D Life Time
Started Mar 25, 2015 | Questions
WorldMedia New Member • Posts: 6
350D Life Time
Hello dear users...
Dany here..
Want to ask you something about this old but but great camera!
I know this cam doesnt have a shutter count,but its there a way or something to find out how many photos last owner did with my camera???
 WorldMedia's gear list:WorldMedia's gear list
Canon EOS 50D Canon EOS 6D Canon EF 50mm F1.4 USM Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical (IF)
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N)
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
Re: 350D Life Time
There's no reliable way to determine the shutter count. But then, it really doesn't matter. The shutter will last for however long it lasts.
Unless you're planning to be very hard on the shutter, like time-lapse movie making, it's unlikely you'll see a shutter failure. Most DSLRs die from something else (like being dropped). I've been reading photo forums since I got my XT/350D ten years ago, and I've never read of an XT/350D suffering shutter failure. I'm sure it happens, but so does getting struck by lightning.
If the camera looks beat-up and worn, it's probably seen a lot of use. If it doesn't, it probably hasn't. That's your best indicator. (The coating on the grip area deteriorates over time, not necessarily with use, so don't go just by that.)
The open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
jrkliny
jrkliny Veteran Member • Posts: 4,887
Re: 350D Life Time
Shutter failure is not a rare event.  The shutters on the older Rebel series last in the vicinity of 30k-60k actuations.  The shutter on my XSi burned out at the high end of that range.
 jrkliny's gear list:jrkliny's gear list
Canon EOS 90D Canon EF 35mm F2.0 Canon EF-S 10-22mm F3.5-4.5 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 55-250mm f/4-5.6 IS +6 more
Doug Pardee
Re: 350D Life Time
It depends on the shutter. The XT/350D has a very reliable shutter, perhaps in part due to the slow burst speed of that model. Or perhaps in part due to the camera dying from other problems; one person I know went through two XTs that both experienced circuit-board failures early on. Interestingly, the 20D which came out at almost the same time has one of the least reliable shutters that Canon's ever put into a DSLR; at one point a law firm was trying to put together a class action about it but that never came to fruition.
Of course, regardless of the model and the shutter design/manufacture, the shutter in any camera can fail at any time.
In any event, the XT/350D is an obsolescent piece of equipment. It seems unlikely to me that anyone would be buying one today with the intention of taking tens of thousands of pictures with it. I'd be more concerned about sensor dust (due to the design of the case and the sensor) than shutter failure. While sensor dust is much much cheaper to deal with than a broken shutter, after a while the aggravation of repeated cleanings — and spotted pictures — can take its toll.
imqqmi Veteran Member • Posts: 8,639
Re: 350D Life Time
Agreed, I dropped mine but the shutter has never failed. I think I did about 100.000+ shots with it before I sold it. I've heared from others that they did similar amounts of shots without failure. There were more bent pins in the CF card slot though, I'd look for that when buying second hand.
On the 40D, I owned two and on both the shutter failed. One at around 15.000 shots and the other around 25.000. After they were fix under warranty, no problems, even after 50.000+ each.
Kind regards
Imqqmi
Links:
View my webgallery
http://www.pbase.com/imqqmi
The DSLR jargon cheatsheet
http://www.jmbfoto.nl/dslrcheatsheet.pdf
Sunset blending tutorial
http://www.jmbfoto.nl/tutorial/blendingTutorial01a.pdf
Wilba's Frequently Asked (beginners) Questions and answers
http://snipurl.com/RebelFAQ
 imqqmi's gear list:imqqmi's gear list
Canon EOS 40D Canon EOS 7D Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF-S 10-22mm F3.5-4.5 USM +2 more
Doug Pardee
Bent CF slot pins - urgh
Oh yeah, I forgot about that one. That's a big failure mode on the XT/350D.
artlmntl Senior Member • Posts: 1,804
Re: 350D Life Time
True
A buddy gave me one yesterday. He'd had it in a box for years. He said, "You shoot Canon. Here." I put my 28-105 on it. Seems nice. 8MP is small, but it's fine for web and whatever. The screen is small, but the camera has the extra LCD on the back. AF is OK, IQ seems OK. Looks and acts like a Canon. I might get a surprise if I turned the aperture down to f16; but I usually shoot from f4 to f8. I don't know how long it will last or how many shots I may get out of it, but it fits in a small bag. I can loan it to a pint-sized shutterbug without worrying about it.
LightZone is pretty cool, BTW.
Hunter
DePurpereWolf New Member • Posts: 3
Re: 350D Life Time
To my knowledge, this is not possible with the 350D
