What is your holy trinity pf primes?
Started Mar 24, 2015 | Discussions
C Sean Veteran Member • Posts: 3,423
It doesn't have to be all primes, say you have a wide angle zoom instead of a prime.
Here is mine.
15mm 1.7
Originally my trinity used to consist of Panasonic 14mm and the 20mm. Both of these lenses worked very well together and very often traveled together. The 15mm 1.7 captured a lot of their strengths and you could say the 15mm is the love child of the 14mm and the 25mm.
25mm 1.4
Now the 20mm is only used for indoor shots for rare occasions, I have space in my pocket/bag for additionial lens and the 25mm 1.4 get my use for it speed and it completely different focal length.
45mm 2.8
Part macro, part portrait lens. Another lens from the Pana/Lecia featuring the duo personality disorder. I could of gone for the Olympus but I wanted the Macro as an extra instead of speed/macro. Even when the new 42mm 1.7 comes out, I most likely ignore it.
Panasonic Lumix G 14mm F2.5 II ASPH
Hithertoo Senior Member • Posts: 1,841
Re: What is your holy trinity pf primes?
There's no one answer.... for me it's the 12/2, 20/1.7 and 45mm F/1.8 together I have no need for any other lenses and I could sell every other lens I owned and combine them with the 75-300.
 Hithertoo's gear list:Hithertoo's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +7 more
gugarci Senior Member • Posts: 1,622
Me too. Those are the only primes I own. However If didn't own the 12mm I would of bought the 15mm or 17mm instead of my 20mm. But I love my 20mm lens. It's my favorite lens. Also I don't use the 12mm or 45mm nearly as much.
 gugarci's gear list:gugarci's gear list
Panasonic Lumix DMC-LX3 Sony a6000 Sony E 16-50mm F3.5-5.6 PZ OSS Sigma 30mm F2.8 DN | A Sigma 19mm F2.8 EX DN +3 more
Impulses Forum Pro • Posts: 10,039
For me, at first, it was:
Panasonic 12-32mm + 20mm f1.7 + Oly 45mm f1.8
I knew I wanted to go wider even before buying into M4/3 with those three, so I soon ended up with Oly's 9-18 and even the Bower 7.5 FE. That still left me wanting something wide BUT brighter, so eventually I ended up at:
Oly 12mm f2 + Pana 20mm f1.7 + Oly 45mm f1.8
If portability wasn't such a big priority I'd possibly replace the 20mm with a combination of Panasonic 15mm f1.7 + Panasonic 25mm f1.4 (or Oly 25/1.8)... So effectively it'd be four primes rather than three.
It'd be a lot to juggle mentally tho; and there's several other choices I'd rather bring or mount right now to bother with that, including the UWA, FE, and a tiny 35-100 f4-5.6 I want to start using more.
The three primes are seeing more use lately simply because I haven't been out to shoot during the day nor traveling anywhere so it's been mostly social occasions, largely at night.
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Panasonic Lumix G 42.5mm F1.7 Olympus M.Zuiko Digital ED 75mm F1.8 Sony FE 20mm F1.8G +31 more
jeffharris
jeffharris Forum Pro • Posts: 11,409
Holy trinity? Why the mythological reference?
Anyway, the three prime lenses I carry most…
  • Voigtländer 17.5mm
  • Voigtländer 42.5mm
  • Voigtländer 75mm f2.5 Color Heliar (Leica L39 screw mount)
There are other primes I like and use a lot… my other Voigtländers (25mm and 35mm f1.4), or my Nikon 105mm f1.8 AI-S macro… but three is three.
 jeffharris's gear list:jeffharris's gear list
Panasonic Lumix G Vario 7-14mm F4 ASPH Voigtlander Nokton 25mm F0.95 Voigtlander Nokton 17.5mm F0.95 Aspherical Voigtlander Nokton 42.5mm F0.95 Panasonic Lumix DMC-GX8 +26 more
I've really grown to love the 20mm's FL, tho originally I largely chose for it's combination of price, sharpness, and small size... Having it kinda led me to the 12mm too. If the 14/2.5 was a 12/2.5 I might've settled for that.
The 15/1.7wasn't out when I bought the 20 but I doubt it would've changed much, still larger, pricier, and a little too wide for all around use for me.
I find my 20mm lens is my most frustrating, I'm just not good with normal lenses and prefer wide angles or telephotos. That's not saying it's a bad lens, it's just something that challenges me to get the most out of it.
Most likely it's the fact that I have an aversion to getting close enough to make it really work well. It can be a bit flat when you use it from long distance, but get a bit closer with it and it works well.
Skeeterbytes Forum Pro • Posts: 23,186
Most of the time my set would be bookended by the 12 and the 75, but in the middle, well, either the 25/1.8 or 45/1.8. Or, I could  have the Holy Quad.
To be fair, the 1-2 combo of the 12-40 and 75 trumps a handful of primes when flexibility is paramount. They will do so very much, and with less lens swapping.
Rick
dv312
dv312 Veteran Member • Posts: 9,215
Olympus 12mm, 25mm, 75mm
Been toying with this list for a while
Had the Oly 17mm 1.8, and the 45mm 1.8, and Panny 20mm II then I acquired the 12mm f2 and let go of the 17mm since I like the perspective on the 12mm
I lust after the 75mm then acquired it; the 45mm became less used so let it go
Between the 12mm and the 75mm I had to have something , so the 25mm 1.8 came into existence
The Panny 20mm with its slow AF also were let go
Now remain the 12mm, the 25mm, and the 75mm, the 'holy' trinity of primes AFAIC
The 60mm macro is always there as a specialized macro lens , ditto with the 9mm fisheye
The PRO zooms complement the missing focals
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
jl_smith Veteran Member • Posts: 3,970
14, 20, 42.5 Noct
I could do most of my shooting with just these 3 lenses. Wish the 14 had a bit better IQ but love the form factor.
JL Smith
www.flickr.com/photos/jl_smith
 jl_smith's gear list:jl_smith's gear list
Sony RX10 IV Canon EOS R6
Loga Senior Member • Posts: 1,981
14, 25, 45
14mm 2.5
A very good lens which I like a lot. Environmental portraits, indoor photos, landscapes. Small, affordable, with very nice rendering. And I just attach the Pana wide angle converter lens, and have a 21mm equivalent lens too.
25mm 1.4
My general street photo lens. It gets me close enough to the subject, while takes the surrounds as well. I also use it indoor when I want to show the subject in a more intimate way.
45mm 1.8
My ultimate portrait lens. However, for face portraits I prefer my Pana 45-150 at its long end.
Here is mine.
15mm 1.7
25mm 1.4
45mm 2.8
 Loga's gear list:Loga's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GF2 Panasonic Lumix DMC-GX85 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
Godfrey Forum Pro • Posts: 29,636
My two most-used lenses on the E-M1 are the Summilux-DG 25mm and Macro-Elmarit-DG 45mm.
I guess I'm a Taoist, not much of a Trinity person ...
G
Mark B UK Senior Member • Posts: 1,772
For me it's the Zuiko 12 2.0, 25 1.8 and 60 2.8 macro. Rationale:
- All three use the same 46mm filters, are from the same manufacturer so have similar colour and contrast characteristics, are all available in black and handle similarly. In other words, they feel like a complete set;
- The focal length progression is logical, slightly more than doubling at each step
- Between them, they can shoot most subjects, from landscapes to available light to close-ups
 Mark B UK's gear list:Mark B UK's gear list
OM-1 Olympus 12-100mm F4.0 Olympus 25mm F1.2 Olympus M.Zuiko Digital ED 8-25mm F4 Pro
ijm5012 Senior Member • Posts: 1,889
Here is mine.
15mm 1.7
25mm 1.4
45mm 2.8
Mine is exactly this, but instead of the 45/2.8 macro it would be the new 42.5/1.7. Pair it with the Olympus MCON-P02 focal reducer, and I bet you'll have a seriously capable macro lens on your hands. That's my plan anyways.
 ijm5012's gear list:ijm5012's gear list
Nikon D500 Nikon Z6 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR II Nikon AF-S Nikkor 300mm f/2.8G ED-IF VR Nikon Z 24-70mm F4 +6 more
danslides
danslides Regular Member • Posts: 245
I have
PL15
P20
PL25
O45
The I want the Nocticron to replace the O45, and the O60 for macro. Well I guess that's more than the trinity lol.
Perfect world
PL15 Check
PL25 Check
PL42.5 do want!
 danslides's gear list:danslides's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 II Sony a7S Sony a7R II Panasonic Lumix G 20mm F1.7 ASPH +14 more
igorek7
igorek7 Regular Member • Posts: 288
If I had a choice of just three prime MFT lenses, my choice would be:
  • Voigtländer 10mm f/0.95
  • Panasonic 20mm f/1.7
  • Panasonic Leica 42.5mm f/1.2
 igorek7's gear list:igorek7's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Samsung NX500 Panasonic Lumix DMC-GH4 YI M1 +8 more
Robert Evagelista
Robert Evagelista Veteran Member • Posts: 3,448
http://robertevangelista.blogspot.com/2015/02/blog-32-olympus-17mm-f18-more.html
http://robertevangelista.blogspot.com/2014/12/portraits-before-selfies-there-was.html
http://robertevangelista.blogspot.com/2014/07/blog-16-olympus-40-150mm-f40-56-r-12.html
My Trinity is:
17 mm 1.8 (35mm FF Equivalent)
45mm 1.8 (90mm FF Equivalent)
75mm 1.8 (150mm Equivalent)
17mm 1.8
45mm 1.8
75mm 1.8
Sample Pictures
17mm
17mm
17mm
45mm
45mm
45mm
45mm
45mm
I don't have the 75mm yet.
 Robert Evagelista's gear list:Robert Evagelista's gear list
Olympus E-M1 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 17mm F1.8 Samyang 85mm F1.4 Aspherical IF Canon Pixma Pro-100 +11 more
clengman
clengman Senior Member • Posts: 1,991
If I had to choose only three lenses they would probably be oly 9-18mm, oly 25 f/1.8 and oly 40-150 f/4.5.6 and a raynox DCR-150 closeup lens.
 clengman's gear list:clengman's gear list
Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Rokinon 7.5mm F3.5 UMC Fisheye CS Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 Panasonic Lumix G 14mm F2.5 II ASPH +4 more
Chas2 Veteran Member • Posts: 3,715
Re: 12-32, 20, 45
I know it is not a prime, but the 12-32 is currently my small, wide angle, and hard to   All three lenses make for a small light package on the GX7.  It is hard to argue about for less than $200.  I suppose if funds were unlimited, the 12/2 might be the choice instead, and maybe the 60 or 75 instead of the 45.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +12 more
sean000 Veteran Member • Posts: 7,727
Re: 7.5mm FE, 20mm f/1.7, 45mm f/1.8
  • Rokinon 7.5mm Fisheye, because I enjoy playing with the unique perspectives a fisheye can capture. I also own rectilinear wide lenses like the 9-18mm, but the fisheye is special and can always be de-fished with very good results as well
  • 20mm f/1.7  - the lens that tempted me to buy a m4/3 camera in 2010. Beautifully compact with excellent image quality and a focal length that pleasantly splits the difference between a 17mm and a 25mm. It provided a FOV that works for so many situations. AF is slower than my other lenses, but still faster than the MF Rokinon!
  • Oly 45mm f/1.8 - versatile  enough for indoor and outdoor portraits, as well as any general photography that calls for a modest telephoto. Excellent IQ and fast AF. I wish it had slightly better build and a better MF ring, but on the other hand its tiny size and feather weight is part of its charm.
Sean
 sean000's gear list:sean000's gear list
Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Samyang 7.5mm F3.5 Fisheye Olympus OM-D E-M5 +6 more
