Anyone else have AF problems with the 24mm STM lens?
Started Mar 23, 2015 | Discussions
seri_art
seri_art Veteran Member • Posts: 3,063
Late last year I tried two copies of the new 24mm STM lens on my 650D. Both times the AF was not consistent, actually was pretty consistent being a bit "off". But it was dead-on using live view. I returned both lenses. FYI, my 40mm STM lens AF is dead-on with my 650D.
By now, there are several reviews posted about this lens (none here) and I've not yet read anything about AF problems.
 seri_art's gear list:seri_art's gear list
Sony RX100 III Canon EOS Rebel T7i Canon EF 40mm f/2.8 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM +3 more
Canon EF-S 24mm F2.8 STM Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
(unknown member) Regular Member • Posts: 355
Re: Anyone else have AF problems with the 24mm STM lens?
Yes, I am having some sort of back/front focus issue on my 100d. I put lens on my 7d and set about doing a dot test and it was perfect. But still on the 7d it presents the occasional mis focused shot. I sent the 100d body with lens to canon for checking and possible calibration, and they returned it promptly reporting that everything was up to spec. I havent been using it much (24 efs) but I'm sure the problem still exists. I Think it may be my technique more than the lens, who knows..
1cb
1cb Regular Member • Posts: 398
no issues with mine. I use it on my T3i.
Thanks!
Chris
The best camera in the world is the one you own!
 1cb's gear list:1cb's gear list
Canon EOS R7 Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 35mm F1.8 IS STM Macro +5 more
ZX11
ZX11 Veteran Member • Posts: 6,156
Is is it not a contrasty lens?  It misses focus on subjects with little contrast to work with such as in low light?  I think that is the issue with my 50mm f1.4 (and it isn't stabilized).  My 50mm lens also works better in live view because focus is achieved using different methods than contrast.
How well does it focus on well lit subjects with high shutter speeds?
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
seri_art
OP seri_art Veteran Member • Posts: 3,063
I really didn't try that. I only tested it in fairly low light, similar to what I would find at an indoor party where it would be a good "social" lens. As I said, my 40mm STM lens has no problem with AF in that same situation.
ZX11
You should try in better lighting.  The focusing accuracy at very shallow DOF's (to test focus accuracy) should improve.  Also, I noticed the non stabilized lenses really needed fast shutter speeds to get things sharp like a stabilized lens can.  Handheld sharpness with non-stabilized lenses is a matter of opinion on what is acceptable motion blur.
My 50mm f1.4 would have problems indoors low light.  Just where I thought a f1.4 lens would excel.  It could get nice photos but it doesn't always work that way.  Contrast just falls off too fast.  I think my lenses chromatic distortion issues makes the problem with missing fine focus worse.  Can a camera achieve fine focus, by contrast methods, if the lens is throwing color fringing into the mix?  I think that is another reason the UD elements in the "L" lenses are worth the money (if you have it).  How is the chromatic distortion on the 24mm?
So, auto focusing techniques and limitations is another skill a photographer needs.  And why the 7D mkII various focusing settings seem pretty cool.
seri_art
- One of my main uses for that lens would be in lower-light social situations. So if it won't reliably focus in that setting, it won't work for me.
- The shutter speed was fine. I used flash to make sure the shutter speed was fast enough. It was just focusing in front of or behind the supposed focal point.
- Of course I could get another copy and use it in Live View where it focused perfectly.
Abu Mahendra Veteran Member • Posts: 5,312
Another plus for the M 22F2
>> I love the Canon EF-M 11-22mm f/4-5.6 IS STM lens! <<
 Abu Mahendra's gear list:Abu Mahendra's gear list
Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 70-200mm F4L IS USM Canon EF 24-70mm F2.8L II USM Canon EF 40mm f/2.8 STM +5 more
artopaeaekkoenen New Member • Posts: 19
Problems here to, both on Canon EOS 800 and 650. Functions great on both cameras in live view but not through viewfinder.
Both cameras functions as expected (good) with other Canon lenses, so maybe the lens is in some way badly calibrated from factory?
plantdoc Veteran Member • Posts: 4,339
Not an uncommon problem with lenses. It's why the D series cameras have micro focus adjustment, but Canon won't add this firmware feature to the Rebel cameras. Sold 2 Rebels to buy a 70d just for MFA to correct 3 lenses that I thought were just soft.
greg
Ray UK Contributing Member • Posts: 977
greg
Bit of a misleading statement, outside of the USA the cameras that you call Rebels also have a D in their model numbers. It is most (but not all) of the xxD and xD models that have micro focus adjustment, the xxxxD and xxxD do not.
In this era of international communications, using different names or numerical names for the same devices is not helpful. Confusing to me at least
greg
