Is Panasonic 14-45 still the best cheap start zoom today ?
Started Mar 17, 2015 | Questions
OP Renatoa Regular Member • Posts: 464
Re: Is Panasonic 14-45 still ... and focus change :)
Lots of good advices, thank you.
12-32 is surely not a choice, I am not a wide fan, my (realistic) dream lens would be something like 18-70 3-5-4.5, or 16-70/4, such lens exists for other brands, and I would love having such glass instead the current offering. I know these lenses are not for MFT, the other brands use APS-C, but as I said, I am rather leaning to tele side than to wide.
As a result of my preference, and digging more, I think will change my focus to Olympus 14-54 2.8-3.5 with MMF adapter. Was a bit hesitant due to weight, but after testing a 500 grams lens on a NEX, I think will be fine with this choice, that also save me buying a standard prime, because this zoom will give me 2.8 at 25mm, enough for my bokeh needs.
Now tell me I am wrong
Re: Every time I see some variation of this question,
Thank you, but 14-45 is not in that gallery, and the size is the last of my worries, see my last post about the turn of the thread
Jacques Cornell
Jacques Cornell Forum Pro • Posts: 16,262
DoF @ 25mm f2.8 on m43
I wouldn't presume to tell you you're wrong, but I'd caution that if you're not intimately familiar with m43 you might be overestimating the amount of bokeh you'll get with f2.8 at 25mm. As a reference, DoF will be the same as f5.6 with a 50mm lens on 35mm-sensor camera. Not what I'd call shallow. For portraits with a fairly soft background, I'd be looking for 25mm f1.4 or 45mm f1.8. I have a 20mm f1.7, and if I want shallow DoF effects with it, I need to get pretty close. If you're into selective focus at shorter focal lengths, I'm afraid there's no getting away from fast primes. A 35-100mm f2.8, OTOH, can give you good subject separation.
I had a Panny 14-45 and really liked it. Good build & optical quality and smoother zooming action than some.
The way to make a friend is to act like one.
www.jacquescornell.photography
 Jacques Cornell's gear list:Jacques Cornell's gear list
Panasonic Lumix DMC-LF1 Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-GX8 Sony a7R III +54 more
Re: DoF @ 25mm f2.8 on m43
Sure, I am aware about all of these, but still... more than one stop gain for the whole range is appealing.
The equivalent lens rendering the same image on my actual NEX would be 20-80 f/4-5, and I am OK with this.
Helen
Helen Veteran Member • Posts: 7,606
Do also bear in mind that as it's a Four Thirds lens (not Micro Four Thirds), the GX7 will likely autofocus it considerably slower than a native MFT lens, since it doesn't have phase detection (and of course the MMF adapter will also add more length and weight).  You will also be relying on the relatively simple 2-axis IBIS in the GX7 body (I am assuming it will work, though I have never got around to trying a Four Thirds lens on my GX7, I just realised...).
