Is Panasonic 14-45 still the best cheap start zoom today ?
Started Mar 17, 2015 | Questions
Renatoa Regular Member • Posts: 464
As title say... trying to decide for a first lens on my GX7...
Panasonic Lumix DMC-GX7 Panasonic Lumix G 14mm F2.5 II ASPH
Klarno
Klarno Veteran Member • Posts: 4,239
Re: Is Panasonic 14-45 still the best cheap start zoom today ?
The only kit lens to outright avoid is the 1st generation Olympus 14-42 (not so much because of image quality, but because of primitive, slow AF mechanics including a rotating front element). Also the electronic zoom Panasonic 14-42 X, IIRC, is the lens that started this forum on nearly 13,000 posts about shutter shock. And people hated the original Panasonic 14-42 because it marked the point when cameras would no longer be packaged with the beloved 14-45 (the 14-42 had--gasp--a plastic bayonet! and it had slightly poorer image quality! and it was cheaper! darn those dastardly corporatists after their bigger profit margins!)
The Panasonic 14-45, Panasonic 14-42 II, Olympus 14-42 II/II R and Panasonic 12-32 are all regarded about equally. I'd err toward Panasonic over Olympus even though the GX7 has IBIS, because OIS tends to perform a bit better than 2-axis IBIS.
In reality, though, people complain a lot. My copy of the original Panasonic 14-42 that came with the GH2 outperformed the Olympus 14-42 for Four Thirds, and that was a lens considered by many to be the finest kit lens ever made up to its time. We really do have it pretty good in this system. In reality, these lenses all perform so similarly on average that you should be happy with any of them.
 Klarno's gear list:Klarno's gear list
Sony Alpha NEX-6 Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +9 more
photofan1986
photofan1986 Veteran Member • Posts: 3,841
In my experience, yes.
However, the new 14-42 II is also very good, and the pancake 12-32 is no slouch either.
Personally, I got a poor copy of the 14-42II, but it seems like a very good lens otherwise.
I also own the 12-32 which I got with my GM1, and while it's even slightly sharper in the center than the 14-45, it's less consistent across the zoom range. It's excellent from 20 to 32, but the wide you go, the softer it becomes in the corners.
The 14-45 on the other hand was a very pleasant surprise: my copy is very consistent, being good to excellent at all apertures and all focal lengths. Shooting with it, you know you will get a good result every time (within its limitations, of course).
But I guess that then it comes down to sample variation.
I think if you can get a good copy of the 14-42II, it's an excellent lens, as it's smaller, lighter and maybe even slightly sharper than the 14-45.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
Hithertoo Senior Member • Posts: 1,841
In my honest opinion the best kit lens is the Olympus 14-42 II R followed closely by the Panasonic 14-42 II but you're on Panasonic, so you might also consider the 12-32 pancake which is about equal to the aforementioned lens but gives you a noticeably wider 12mm lens on the short end.
The difference between 32 and 42 is really nothing in the real world on the long end. Both lenses aren't long enough to use for portraits as they don't get to 100 and they're too short to be considered a serious telephoto zoom.
All views expressed above are my own and are not an expression of how others should think, or a matter of group think for others.
 Hithertoo's gear list:Hithertoo's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +7 more
photofan1986
Funny, I found the Oly 14-42R pretty poor. Not bad sharpness overall, but inconsistent across the focal range (good at wide angle, really so-so at tele end), and build quality pretty low.
The Panny 14-45 is much more peppy and contrasty, and offers better sharpness across the frame.
Oh and I owned at least three copies of the Oly.
YMMV of course.
Englishman in France Senior Member • Posts: 1,726
Out of my 12-50mm olympus zoom and my 14-45mm Panasonic zoom, I prefer my Panasonic.  I cannot comment about any of the other lens discussed, except to add that there have been reports of shutter shock on the Panasonic 12-32mm when using the mechanical shutter (don't know whether this is true).
In my opinion, there is a big hole in the middle price range line-up for a 12-40mm F2.8 to F4 zoom.  It is a shame that Olympus release a mid range E-M5 mk2 with no mid range zoom. I do not consider the 12-50mm zoom to be in the same league as my premium range olympus lenses.  Hopefully, either Panasonic or Olympus fill this gap soon.  I am getting fed up of waiting (rant, rant).
Almagest Contributing Member • Posts: 561
Hi,
I would never describe the Panasonic 14-45mm zoom as cheap, it's an inexpensive well made lens with very good glass. I have the original version that came with Panasonics G1 and I would not hesitate to recommend Panasonic 14-45mm zoom!
You should also consider the Panasonic 45-150mm zoom. It's almost as good as the 14-45mm zoom! I picked up a copy from B&H a few months ago for $119! The two lenses are about the same size & weight and both use 52mm filters.
http://www.photozone.de/olympus--four-thirds-lens-tests/414-pana_1445_3556
http://www.photozone.de/m43/845-panasonic45150f456
Good luck...
Warren
tkbslc Forum Pro • Posts: 17,527
Get the 14-42 II Kit
The 14-42 II is a little better, albeit maybe 1/3 stop slower through the range.  It's smaller, with a metal barrel and outstanding sharpness and color.   Best part is you can get it for almost nothing in a GX7 kit.
The 12-32 is nice to go wide, but the GX7 is not such a compact body that the difference between the 12-32 and 14-42 Ii size makes a big difference on portability.  You also lose a MF ring, although to be honest I doubt most people MF a kit zoom often.
brentbrent Veteran Member • Posts: 5,767
I sold my 14-45 after I got the Panasonic 14-42 v.II, because I concluded the IQ was very close, and I preferred the smaller size and weight of the latter, plus its very short extension when zooming, plus its 46mm filter size.
The 14-42 v.II that comes with a camera body as a kit lens does have a plastic mount, while the version that sells separately and the 14-45 both have metal mounts. And the 14-45 has the switch on the lens barrel for OIS.
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
42mm is 84mm equivalent on 2x crop.  85mm equivalent is one of the all time classic portrait lengths.  So I'd say that definitely the 14-42 is long enough for that.
That seems like really weird logic. Surely the cost of an additional production run would exceed the savings of using a plastic mount.
Mingjai
Mingjai Senior Member • Posts: 1,430
I have experience with 4 m4/3 kit lenses: Panasonic 14-45mm, Panasonic 14-42mm II, Panasonic 14-42mm PZ, and the Olympus 14-42mm. All are good for what they are--cheap kit lenses.
I echo brentbrent's recommendation of the Panasonic 14-42mm II because of its combination of size and quality. It's significantly smaller than the 14-45mm yet it offers similar image quality. Also, the aperture and AF of the newer lens are better suited for shooting video.
 Mingjai's gear list:Mingjai's gear list
Panasonic Lumix DC-GX9 Olympus E-M5 III Leica Nocticron 42.5mm Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic 8-18mm F2.8-4 +17 more
Impulses Forum Pro • Posts: 10,039
Re: Get the 14-42 II Kit
It would make a big difference to anyone attempting to carry it in a coat pocket, purse, etc... The 14-42 II might be less susceptible to SS tho and it's like half the price of the 12-32 from what I've seen (lowest I've seen them is $125 & $250 respectively).
 Impulses's gear list:Impulses's gear list
Panasonic GX850 Sony a7R IV Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic Lumix G 42.5mm F1.7 Sony FE 20mm F1.8G +31 more
It's true tho, might also be a location thing... But all 14-42 II sold in kits come with a plastic mount (at least in the US/EU). I don't think it's sold separately outside of Asia, could be mistaken, so the metal mount might just be for their retail boxed version.
Also, initially Panasonic was only selling it with the GX7 in Europe as they had continued to sell the G6 & GF6 with the older 14-42 v1 over there... (v2 was the original kit lens for those in the US) With the G6 probably going EOL and the new GF7 being packed with the 12-32, we might start seeing less split kit 14-42 IIs out there.
It's pretty inconsequential either way, such a small/light lens, I doubt it makes a difference unless you're abusing it.
Worth noting that not only is the 14-42 II smaller, it also barely extends more than 5mm as you zoom. It's fully retracted at 25mm.
gary0319
gary0319 Forum Pro • Posts: 10,540
I'd look for a deal on a GX7 kit with the 14-42II, if you haven't already purchased the GX7 body. I got my 14-42II in the GX7 Kit, and the kit price was way less than $100 more than the body only.
Great little lens to start off with.........but beware, you could end up with a few more of these little M43 wonders.
Gary
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
I've got the GX7 and it doesn't really fitl in a coat or purse with a pancake lens.   I wear XXL too, so if anything my pockets are going to be on the large side.   I found it to be equally impractical and overly bulky with a 1" long lens or a 2" long one.
If you had a GM or GF series camera, then I may agree.
Yeah, I googled and found an image of one with a metal mount.  Mine is plastic (came with GX7)
I definitely agree.  m4/3 lenses are all so light that I think all of them could be plastic mount and it wouldn't make a bit of difference.  Modern composites are extremely strong and metal is primarily used for the appearance of quality rather than actually providing any benefit.
I did notice that the retail 14-42 are like $279.  Maybe they want it to look more "pro" if they talk you into spending that on a kit lens!
Hen3ry
Hen3ry Forum Pro • Posts: 18,218
Panasonic 14-45 s terrific but…
…rthere are now other, more compact choices.
The 14-42 II both in Panny (which K have not used) and Olympus, which I have used extensively, and the Panny 12-32, which I use daily, pretty much, are smaller, lighter choices with IQ as good, I would say.
Geoffrey Heard
Down and out in Rabaul in the South Pacific
http://rabaulpng.com/we-are-all-traveling-throug/i-waited-51-years-for-tavur.html
 Hen3ry's gear list:Hen3ry's gear list
Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +7 more
hindesite Veteran Member • Posts: 4,893
Every time I see some variation of this question,
I always point to:
http://www.dpreview.com/forums/thread/3566159
Very little has changed since that post.
