When to use/not use Electronic First Curtain Shutter on A7II
Started Mar 17, 2015 | Questions
Mike Stratil Contributing Member • Posts: 990
Would someone knowledgeable about the subject provide me with a summary of when to turn on/off the electronic first curtain shutter on the A7II.
Michael S
Sony a7
JimKasson
JimKasson Forum Pro • Posts: 38,753
Re: When to use/not use Electronic First Curtain Shutter on A7II
5
Use it for sure when the camera is on a tripod, unless the shutter speed is very short. I can't find the spec on the a7II, but on the Nikon D810, the shortest shutter speed you can use with EFCS is 1/2000 second, and the camera enforces that. The a7II does not; it will let you take a picture with EFCA on and the shutter set to 1/8000.
I leave mine on all the time except when the shutter speed is shorter than 1/1000 second, where it has little effect.
It really helps with the camera on a tripod, especially with longer lenses:
http://blog.kasson.com/?p=5429
Jim
 JimKasson's gear list:JimKasson's gear list
Leica Q2 Monochrom Nikon Z7 Fujifilm GFX 100 Fujifilm GFX 100S Nikon Z9 +1 more
blue_skies
blue_skies Forum Pro • Posts: 12,208
Jim
Technically, the EFCS is a 'all instant on' exposure start, whereas the mechanical FC is a 'slide' exposure. The mechanical SC is also mechanical.
For fast exposures, the two mechanical shutters provide a very precise exposure 'slit'. If you use EFCS you change this: the top of the sensor (bottom of the image) will get a longer exposure than the bottom.
At high speeds, this can become noticeable, depending on the scene. The user manual advises to not use EFCS when selecting high speed SS. But because it exposes the bottom of the image, in many daytime shots this may not matter.
The A7 shutter is a single moving shutter, the D810 has more parts. In the D810 you will see the shutter outline, if shooting too fast, therefore it is disabled if faster than 1/2000. Think of the A7 shutter becoming a graduated filter at high SS.
Henry
Sony a6000 Sony a5100 Sony a7R II Sony DT 18-55mm F3.5-5.6 SAM Sony 75-300mm F4.5-5.6 +35 more
le_alain Senior Member • Posts: 1,998
Jim
I just tested it, on my A7, no PB to shoot at 1/8000s with EFC-ON ?
and exposure was 1/4 of the same shoot at 1/2000s, so not locked ?
Edit: Sorry, you spoke of D810, I thought A7 vs A7 II
 le_alain's gear list:le_alain's gear list
Sony RX100 VI Leica M Typ 240 Sony a7 III Sony FE 55mm F1.8 Sony FE 24-105mm F4 +1 more
JimKasson
Uh, Henry, that's not the way it works on the D810.
http://blog.kasson.com/?p=6641
I think the a7 works the same way, with a moving reset to the sensor followed by the trailing curtain moving at the same rate. I can perform oscilloscope tests on the a7 if you disagree, but I don't see how EFCS could work on the a7 at 1/1000 second -- and it does -- unless the reset is sliding, not all at once.
Edit: I found that I'd already performed such tests on the a7S, and it is a sliding reset:
http://blog.kasson.com/?p=6450
Jim
vett93
vett93 Veteran Member • Posts: 5,396
9
I tested it at 1/2,500 and it works fine...
 vett93's gear list:vett93's gear list
Sony a9 Sony a7R III Sony a6500 Apple iPhone 11 Pro
vett93
It also works at 1/3,200.....
Steve Bingham
Steve Bingham Forum Pro • Posts: 27,680
Great shots (especially the 1st one) with even better information. Interesting. Nice to know the 70-200 can nail these sort of shots. Pretty impressive. Who says the a7II and 70-200 can't do BIF.
Steve Bingham
www.dustylens.com
www.ghost-town-photography.com
 Steve Bingham's gear list:Steve Bingham's gear list
Nikon Coolpix 990 Sony RX100 VII Nikon D810 Nikon D7200 Nikon AF Nikkor 85mm f/1.8D +33 more
blue_skies
Jim
Thanks, I learned something here.
It adds a lot of electronics which are totally unnecessary at slower speeds.
Impressive
Henry
vett93
Thanks, Steve. I really like this 70-200mm lens. I even use it as my forum picture.
martindesu
martindesu Senior Member • Posts: 1,247
 martindesu's gear list:martindesu's gear list
Sony RX1 Sony Alpha NEX-C3 Voigtlander 35mm F1.4 Nokton Sony FE 55mm F1.8 +1 more
RSR2800 Forum Member • Posts: 56
Like others before me, I suggest to turn it off beyond 1/1000s.
I just don't understand why there is no "auto" setting, to turn it off automatically at faster SSs.
Or why it's not possible to assign EFSC to a custom button, at least (same complain for "EVF brightness" setting too, by the way... it would be handy to put it on "C4")
RSR
Drawde Laen
Drawde Laen Veteran Member • Posts: 3,425
I dont have a A7II, I shoot with a NEX-7 and I keep the electronic first curtain turned off. except for making the camera a tad quieter I dont see where it offers any advantage and if I decide to shoot a sweep panorama the EFC can cause banding - it just does not work well when using this feature.
JMO
Ed
 Drawde Laen's gear list:Drawde Laen's gear list
Sony Alpha NEX-7 Sigma 60mm F2.8 DN Art Carl Zeiss Touit 1.8/32
vett93
It may reduce vibration caused by the mechanical shutter....
Drawde Laen
true and if I am taking long exposures where this would be a concern I can turn it on, but in my day to day shooting it is easier to leave it off so I dont have to think about turning it off every time I decide to shoot a sweep panorama.
perhaps this is a bigger concern to me than most, because the only lens I normally use is the Zeiss Touit 32mm f/1.8. as such I tend to use the sweep pano feature as my way to get wider shots. I switched from Nikon to the NEX system because I was tired of carrying a bunch of gear and carrying a bunch of lenses seems to defeat the purpose to me - also I find that now I have the camera with me much more than I used to simply because its so easy to just carry a camera and one lens on a wrist strap
Ed
alextardif
alextardif Senior Member • Posts: 1,376
Fantastic captures, really impressive, thanks for sharing!
Alex
 alextardif's gear list:alextardif's gear list
Sony FE 35mm F1.4 Sony a7R III Sony FE 90mm F2.8 macro Sony FE 24-70mm F2.8 GM Sony FE 85mm F1.4 GM +2 more
SimonOL Senior Member • Posts: 1,979
I just leave it on - prolongs shutter life?
JMO
Horses for courses, I guess
I always have EFCS turned on on my Nex-7 - mainly because I just prefer the single noise per exposure - and never noticed any adverse effect, even with panos, at any shutter speed.
I read somewhere that use of EFCS can prolong the life of your shutter mechanism, which seems to make sense seeing as the mechanics are only used once per exposure. It sounds good to me but whether this info is reliable/correct, who knows?
Anyway, I use EFCS all the time and just don't worry about it. If it ever caused a problem, I'd turn it off for that shot. Not very technical advice, but I'm just a casual shooter
 SimonOL's gear list:SimonOL's gear list
Sony Alpha NEX-7 Sony a7R II +1 more
Snikt228 Senior Member • Posts: 1,025
I have an A7 and I've used EFCS ever since Day 1, have never disabled it for any reason or seen any issues. Some people in here mentioned fast shutter speeds, I've taken images at 1/4000 and 1/8000 and haven't noticed any issues.
Here are a couple samples
1/4000
1/8000
 Snikt228's gear list:Snikt228's gear list
Sony a7 Sony FE 35mm F2.8 Sony FE 55mm F1.8 Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 70-300mm F4.5-5.6 G OSS
Drawde Laen
Re: I just leave it on - prolongs shutter life?
SimonOL wrote:
JMO
this is why I keep it off
a shot with no EFC and moving water
and a shot with EFC and moving water
I have literally taken 100's of images in sweep pano mode with moving water and never had an issue except for the one shot above where I forgot to turn off the EFC - - - look at the water, you can see the chop line of each and every exposure used to make the pano
heres another with fast moving water - no EFC, and no choppy lines
Ed
Drawde Laen wrote:
SimonOL wrote:
JMO
Good demo, nice shots
I don't use sweep pano very often - prefer stitching in PP - so it suits me better to have efcs on. I don't recall ever using sweep pano with moving water but it's good to see a scenario where efcs could have adverse effects. Thanks!
