16-35 F4 LIS review
Started Mar 15, 2015 | User reviews
Powerdoc Veteran Member • Posts: 3,941
16-35 F4 LIS review
Very good lens
The AF is fast, IS is good and the price is OK for an L class lens
Highly recommanded
It's all about photography
 Powerdoc's gear list:Powerdoc's gear list
Fujifilm X-T1 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
Canon EF 16-35mm F4L IS USM
Wideangle zoom lens • Canon EF • 9518B002
Announced: May 13, 2014
Powerdoc's score
4.5
Average community score
4.6
paul simon king
paul simon king Regular Member • Posts: 193
Re: 16-35 F4 LIS review
how wide at its widest is this compared to the new 11-24?
I have looked at the AOV on Canon's website and don't understand , if the new 11-24 is te widest ever, that the diag AOV of the 16-35 is 108 degrees v the 11-24s 126 degrees
Could some kind soul explain to this bear of very small brain
ta
 paul simon king's gear list:paul simon king's gear list
Canon EOS 5DS R Canon EF 135mm F2L USM Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon 85mm F1.4L IS USM
OP Powerdoc Veteran Member • Posts: 3,941
See by yourself
ta
go to the Petapixel site and look at the review of the 11-24  (Sorry I can't give you the link, it's forbidden by the site)
You can see by yourself, the difference between 16 and 11 mm (and other focal length)
1Balance Contributing Member • Posts: 902
ta
Well, 16 is wide and 11 is WI-I-IIIIDE!! (yes you must pronounce all three syllables). You know the quote, "but this one goes to eleven." 'nough said.
Seriously though, check out petapixel and also Google "the digital picture canon 11-24" for an easy mouse-over of 11mm vs. narrower FOV.
For me, when I want that wide, I prefer panos to a single UWA shot. But that's probably because I fear change. ymmv.
GT
Lyin' Pete used to do this all by touch...
 1Balance's gear list:1Balance's gear list
Canon EOS 5D Mark II Canon EOS 30D Canon EOS 7D Mark II Canon EF 35mm F1.4L USM Canon EF-S 17-85mm f/4-5.6 IS USM +10 more
paul simon king
Re: See by yourself
ta
thanks Ill try it
paul simon king
ta
GT
thanks
victorian squid
victorian squid Veteran Member • Posts: 3,391
Lens Simulators
ta
Not sure I understand your question, but perhaps a visual reference will help:
http://canonlenses.ca/lens-tester?LensID=30&CategoryID=6&leftLensID=49&rightLensID=30
http://imaging.nikon.com/lineup/lens/simulator/
The Nikkor one used to be very good, but they've changed it so it's even harder to see the difference.
 victorian squid's gear list:victorian squid's gear list
Canon EOS 6D Canon EOS 70D Canon EF 24-70mm F2.8L II USM Tamron SP 150-600mm F5-6.3 Di VC USD Canon EF 16-35mm F4L IS USM +37 more
