Best kit lens I ever had!
Started Mar 14, 2015 | User reviews
baladeur New Member • Posts: 1
When I owned a Canon 7D, the kit lens was an 18-135. I could never fault it.  Wanting something lighter when I retired I sold on the camera and lens. Several mistakes later, I've now bought a Canon 700D with the 18-135 IS STM lens. I've used it on walks, low light, action shots of grandchildren, portraits and so on.  It's every bit as good as I had hoped. It's sharp, responsive and doesn't weigh a ton. I've no plans to buy any other lenses because I don't think I'll need them.
Canon EF-S 18-135mm F3.5-5.6 IS STM
Telephoto zoom lens • Canon EF-S • 6097B002
Announced: Jun 8, 2012
baladeur's score
5.0
Average community score
4.8
bridlow New Member • Posts: 2
Re: Best kit lens I ever had!
I made the same mistake sold 7D 18-135stm. Bought Pansonic G-7 + 100x300 45x150  14x45.very light and very good results and a fraction of the weight.  Missed the Canon so bought 40D + 55x250 stm.when will I learn 64years young.
 bridlow's gear list:bridlow's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 Olympus Zuiko Digital ED 70-300mm 1:4.0-5.6 +6 more
NowHearThis
NowHearThis Veteran Member • Posts: 4,598
Re: Best kit lens I ever had! I paid $$$ to avoid the kit lenses.
I've only owned 1 Canon lens before, the EF-S 15-85mm.  I paid $700 more than the kit lens and $300+ more over the Sigma 17-70 just to get an extra few mm on the wide end.  Without question this was the best investment I have ever made (photography wise).  Now that I'm coming back to Canon I am planning on picking this lens back up.  From my own testing there isn't a EF-S zoom lens as good optically.  IMO I think it's even a little better in the corners than the 17-55/2.8 wide open at wide angle and telephoto (although the differences are closer between these to than any of the others).
NHT
//life motto
if (sad() == true) {
sad().stop();
beAwesome();
 NowHearThis's gear list:NowHearThis's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Olympus E-M1 III Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 42.5mm F1.7
Ronomy
Ronomy Veteran Member • Posts: 4,062
15-85 is a great lens I agree and it's a fun lens and the best lens given its range to leave on the camera at all times.  It works well indoors in close quarters so you can get the entire shot at close range and outside it still has good reach.  All around great lens!
 Ronomy's gear list:Ronomy's gear list
Canon PowerShot SD800 IS Panasonic Lumix DMC-LX7 Panasonic Lumix DMC-FZ200 Canon EOS 7D Canon EF-S 15-85mm f/3.5-5.6 IS USM +6 more
jwilliams Veteran Member • Posts: 6,395
Yep.  I am pretty amazed that a superzoom like this performs so well.  Most lenses of this type really drop off in sharpness at the long end.  Not this one.  Just a good solid all around usage lens.
Mine sits on my SL1 and is my most used setup.  I have a 6D and L zooms, but for most uses I just grab this combo.
Jonathan
User5692363302 New Member • Posts: 1
Hi,
I am also using this lens with 7D, the results are good in daylight. In the night and in a big group when lens is on wide anlge, the results are displeasing. Only when zoomed into the subject the image is sharp. I am using external flash 430 EXII. Not sure what is missing
Any suggestions most welcome
jvc1 Senior Member • Posts: 2,202
Can you post a couple of examples? No way to help without seeing what the problems are.
I keep some of my favorite pictures here,
https://www.flickr.com/photos/129958940@N03/
 jvc1's gear list:jvc1's gear list
Canon EOS Rebel SL2 Canon EOS 90D Canon EF 85mm F1.8 USM Canon EF-S 15-85mm f/3.5-5.6 IS USM Canon EF-S 60mm f/2.8 Macro USM +10 more
