Canon G7X macro really bad
Started Mar 11, 2015 | Questions
mart1541 New Member • Posts: 2
I recently upgraded from a G9 to a G7X and have been noticing it is very difficult to get a sharp macro image. I decided to do some direct comparisons and the problem is far worse than I thought. While the G9 does super sharp macro less than 1cm from the subject, with only slight softening around the edges, the G7X has to be several centimetres away and has terrible distortion everywhere except the centre of the image. I know they had to make compromises to fit such a fast lens into a small camera, but I suspect there may be something wrong with this one. Even in the centre where it is sharpest it is still far inferior to the G9.
Could someone else with a G7X take a similar photo so I can see whether there's something wrong with mine or it's just a shitty design? The photos are of a full HD laptop screen, taken as close as the autofocus can handle.
Sample G7X photo:
Sample G9 photo for comparison:
Thanks for any help!
Martin
Canon PowerShot G7 X Canon PowerShot G9
rachi Regular Member • Posts: 235
Re: Canon G7X macro really bad
Some considerations. (I'm not a pro)
Canon G9 has a 1/1.7" sensor size, G7X 1". Quite bigger. So it's easier for G9 to focus at shorter distances. (You can also consider that G7X is 20 Mp, rather than 12 Mp that G9. So with G7X you can focus farther but that crop a lot).
Anyway, I agree that G7X cannot do wonderful macro photos, IMO. Shorter distance is about 5 cm. But result are not so bad. I don't see a lot of distorsion in my photos.
 rachi's gear list:rachi's gear list
J_dpr Contributing Member • Posts: 990
Sample G7X photo:
Martin
What you are mostly seeing here is the effect of the much shallower DOF that G7x has due to it's larger sensor. The edges of the image is further away than the center and becomes out of focus. Best macro shots with the G7x is done by backcing of to 40 cm and zooming in to 100 mm FL. This will give you sharp subject with nice blured background making subject separation much better than a small sensor camera.
Jan
brianj Forum Pro • Posts: 14,657
Cropping is an interesting solution, why not try turning on the Digital Multiplyer to 2X, I have used this method with my IXUS and get amazing macros.
The poor macro is just another penalty of the larger sensor, for those where low light shooting is not important, these larger sensors are a real drawback.
Brian
 brianj's gear list:brianj's gear list
Canon PowerShot ELPH 330 HS
Tonkotsu Ramen
Tonkotsu Ramen Senior Member • Posts: 2,380
5
Nothing wrong with the design, and probably nothing wrong with your copy. You need to understand how differences in sensor size change the way you're supposed to take photos.
kodakrome
kodakrome Senior Member • Posts: 1,026
If you're interested in better image quality, the larger sensor isn't a drawback - it's an advantage.
I don't see any difference from different size sensors if they have sufficient DR and are viewed at the relevant size, apart from DOF.
Brian
jimwoodward Forum Member • Posts: 90
I just tried shooting the Google logo with my G7x, just as I shoot macro under water---zoomed out to about a 90mm equivalent. Looks pretty good in the viewfinder and distance to the screen is about 5 or 6 inches. Edge to edge seems decently sharp.
BTW, I just discovered I can "zoom" on the recorded image in the cam using the zoom lever, pretty neat focus check!
Remodeling has stuff messed up around the house, so I won't be able to post pics anytime soon........
damian5000 Senior Member • Posts: 1,948
Brian
It's not only low light. Any type of shot where the lighting isn't excellent requires high ISO and/or long exposure with S120. I do product shots in fairly good "standard" indoor lighting (just the standard room fluorescents)  with S120 and I must admit I cuss and moan more often than not because of this. Yes, in excellent lighting the S120 will do fine, or if using a tripod and shooting static scenes it's okay. There's certainly more benefit to the larger sensor in the G7X than just shooting in low light. Having owned both the G7X and the S120, I can say there's no doubt about that.
 damian5000's gear list:damian5000's gear list
damian5000 wrote:
Brian
Could you see the difference in a 4x6 inch size image?
Brian
Jerrich
Jerrich Senior Member • Posts: 2,738
Notice the dof in this g7x shot.  As stated, just back up and zoom in for more dof.
JR
 Jerrich's gear list:Jerrich's gear list
Panasonic Lumix DMC-FZ200 Canon PowerShot G7 X
minuteman26 Regular Member • Posts: 343
JR
What the heck is that?
Jerrich
Those are ye olde phonograph needles from yesteryear.
JR
Zbyszek_Z Regular Member • Posts: 231
Very interesting! Really
Zbyszek
 Zbyszek_Z's gear list:Zbyszek_Z's gear list
Panasonic Lumix DMC-FZ200 Panasonic LX100 Canon PowerShot G7 X Olympus Stylus 1s Panasonic Lumix DMC-FZ300 +13 more
Donthuis
Donthuis Regular Member • Posts: 139
JR
All shot at longest, 100mm equivalent focal length. In analogue times special macro lenses came either in 50mm, or in the 90-100mm range for a higher distance from the subject and avoid disturbing subjects like insects and the like. But with apertures around 3,5 usually and optimised towards highly stopping down and still with a fine bokey thanks to as rounded as possible aperture systems.
Since the G7X already performs well on the 100mm position at 2,8 at least on paper it is a more capable macro instrument IMHO. Unless you want to reach 1:1 images of of course! Indeed I tried at first how nearby my G7X worked OK and 1:1 is definitely out of range for this one
These pictures show there is nothing wrong with G7X, unless you desire a higher DOF. Then a camera with a much smaller sensor such as the older 1 /1.7 types (new Fuji X30 included) are easier.
Longterm photographer from way back in the 50's via analog SLR's, three generations of video equipment towards present 2 high end compacts both with (F)HD-video included.
ECDC Regular Member • Posts: 120
I've played with my G7X macro a lot. I found that at 24mm and f/1.8, you can be only as close as 6 inches away or else it's terribly soft. It's then a sliding scale until f/3.2, where you can be 2 inches away and things are sharp and in focus. Or, you can back up and use the zoom. It's just the way it is, trying to fit a decent zoom + bright lens in a tiny body. If you need a killer macro for your stamp or coin collection, the G7X probably isn't the best choice.
Donthuis
My guess is you're right. I contemplated the Fuji X30 for a while which has a fine macro performance and the famous color rendition of course. But for a number of reasons I finally settled on the G7X, mainly because of its low light performance (since confirmed) and much better video.
From my macro days with analog SLR's (reversed lenses, distance tubes and bellows) I remember macro really puts special requirements to both lens as well as the camera. I even used to keep my very old Exakta with its replacable viewfinder for reproduction purposes. I feel all P&S camera's but also the G-series are aimed at a wider application and much less oriented to special applications
OP mart1541 New Member • Posts: 2
Thanks to everyone who has responded. I was hoping that someone could post a similar photo of a monitor screen at 24mm wide angle so I could visually confirm that there's nothing wrong with my camera.
From the responses so far I'm sort of convinced that the softening at the edges is normal when trying to use macro at 24mm, although I would have liked to have seen an image taken of a flat surface from someone else's G7X just to confirm it is as bad as mine. When I sent the image to the camera shop their expert said the photo should be sharper around the edges and I should send it back but she didn't have a G7X there to play with.
The other thing I wanted to check is whether my camera is focussing properly in the middle, as I suspect it is slightly out. The reason I suspect it is not focussing properly is that when I half press the shutter to focus, then move the camera slightly closer before taking the photo, the centre looks much sharper. Below are comparison shots.
Canon G7X macro shot at 24mm zoom taken with a tripod
Canon G7X macro shot at 24mm zoom hand held, half press to autofocus, then moved a few mm closer before taking photo
As you can see the detail in the second image at the centre is much sharper.
Does this indicate there is something wrong with the autofocus on my camera? Or maybe with the G7X autofocus in general?
Thanks in advance for any more advice or similar tests with your G7X.
cberry Senior Member • Posts: 1,127
I thought I had a problem until I changed the focus mode to macro and single point AF AND saved the settings.
I think. It seemed to me that it would focus properly before shutter press and go OOF and lose the focus on shutter press without it.
Since then, not a problem. I do however stop it down quite a bit - f/8 is a nice sweet spot.
cb
 cberry's gear list:cberry's gear list
Canon PowerShot G7 X Canon EOS 70D Canon EF 70-200mm F4L IS USM Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF-S 24mm F2.8 STM +3 more
My G7X also reveals the back - focus behaviour (only for 24 mm close focus shots). It seems to me that I have read some posts about that in this forum.
Zbyszek
