EOS Rebel T5i is stuck on video
Started Mar 8, 2015 | Questions
Craig Severance New Member • Posts: 10
I am new to photography.  I can't seem to get out of the video mode.  When I toggle the power switch (the one labeled video/on/off), from video to on, nothing changes.  I believe it should go to a picture taking mode when I do this.  As a result, I can't take any photos (I appear to be stuck in the video mode).  Sorry for the lame question, but I am stuck.  Thanks so much.
Canon EOS 700D (EOS Rebel T5i / EOS Kiss X7i)
ZX11
ZX11 Veteran Member • Posts: 6,156
Live view?
Are you in live view?
"Very funny, Scotty! Now beam me down my clothes."
"He's dead, Jim! You grab his tri-corder. I'll get his wallet."
 ZX11's gear list:ZX11's gear list
Canon EF 85mm F1.8 USM Canon 70-200 F2.8L III Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 85mm F1.2L USM
mocha123 Senior Member • Posts: 2,497
Re: EOS Rebel T5i is stuck on video
Hi Craig Severance,
If you havn't already done so, turn off the camera remove the battery, turn power on without battery installed, press the shutter button once it wont fire but should discharge remaining power in camera.
Turn power off, reinstall battery, turn power switch to on (not fully to video/live view) and see if that cures it.
Worked for me when my 700D locked up whilst taking photos.
 mocha123's gear list:mocha123's gear list
Canon EOS 70D Canon EOS 7D Mark II Canon EF 100mm f/2.0 USM Tamron SP 70-300mm F4-5.6 Di VC USD Sigma 17-50mm F2.8 EX DC OS HSM +3 more
mane666 New Member • Posts: 1
Hi there, did u find a solution? Mine t5i today also get stuck in video mode after shooting at the beach. The on off video switch seems like no responding when rotating it. Take off the battery and when put back on, the camera came on automatically in video mode even if the knob is off?
Phhoenyxx
Phhoenyxx Senior Member • Posts: 2,507
If your camera locks up in video mode or live view mode to the point where even switching it off does nothing and you have to pull the battery, upgrade the firmware. Both the T4i/T5i had this bug when one of the STM lenses was used in certain situations. The new firmware fixed the issue for me.
"Amp up and amplify! Defy! I'm a brother with a furious mind!"
 Phhoenyxx's gear list:Phhoenyxx's gear list
Canon PowerShot A720 IS Canon PowerShot S3 IS Canon EOS Rebel T4i Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EF 50mm F1.8 STM
Tauleo New Member • Posts: 1
mocha123 wrote:
Hi Craig Severance,
Wow! Thank you sir it really works with my 700d! I just created dpreview account bc of this. Thanks again sir.
Hi Tauleo,
I'm happy to be of help, one consolation is that it only ever happened that once.
Good Luck.
James2310 New Member • Posts: 1
Hey what did you have to do here, I have same issue.
Tim Heaton New Member • Posts: 1
I don't have an answer, but my T5i has just developed the same problem. The camera is always in video mode whether the power switch is Off, On, or Video. I've twisted and turned the power switch and blown compressed air into it to no avail. What a pain.
SHR100 Forum Member • Posts: 80
Try to get the battery out.
Charge the battery and return it to the camera.
 SHR100's gear list:SHR100's gear list
Canon EOS 700D Canon EF-S 55-250mm f/4-5.6 IS Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF 50mm F1.8 STM
HOWLnorth New Member • Posts: 1
I have a 77D and am having the SAME issue. When I plug it into my computer and the EOS software starts; I cannot even update the firmware because it will not do it in video mode. I have removed battery, memory card, tried all different things; played with the little tiny switch where the battery pack opens....nothing :/ This happened instantly when I put a new Sigma 18-35mm Art lens on the camera. So looks like I will be returning the lens (because I can’t risk this again)  and have no working camera - any help with this issue - specifically how to update firmware while in video mode - is appreciated!!
PartySnax New Member • Posts: 1
I am struggling with the same issue right now, did you find a way to fix it? I would appreciate if you could reach me.
