LF Advice on selling a front focusing EF-S 17-55mm f/2.8 lens
Started Mar 8, 2015 | Questions
CanonNoob New Member • Posts: 2
I've decided to sell my front focusing Canon EF-S 17-55mm lens.  It's off by a fair amount, it requires a micro focus adjustment of +8/+7 at wide/telephoto on our 7D mkII.  Whether I sell it on eBay or craigslist I would mention the front focusing issue so there would be no surprises.  I still have a couple of weeks left on the warranty so I may have the option of sending it in but it doesn't sound like that is necessarily a sure bet for an accurately adjusted lens.  I'm looking for opinions on how best to sell the lens.  A reply of "I would never buy a used lens requiring MFA" is also informative as it would give me an idea of the general acceptance of this type of issue with used gear.
Thanks,
Nick
Canon EF-S 17-55mm f/2.8 IS USM
x-vision
x-vision Senior Member • Posts: 1,231
Re: LF Advice on selling a front focusing EF-S 17-55mm f/2.8 lens
Since the lens is still in warranty, send it to Canon with a complaint that it is front-focusing.
Then, after the lens comes back, put it on sale with a note that it has just been to Canon for 'adjustments' - and you will be providing a proof for that.
This way you are covered for any issues - and at the same time it would be reassuring for the buyer that the lens has just been inspected/adjusted by Canon.
stratobill Senior Member • Posts: 2,081
Re: +1 NT
 stratobill's gear list:stratobill's gear list
Canon EOS 6D Canon EOS Rebel SL2 Canon EF 70-300mm f/4-5.6L IS USM Canon EF 24-105mm f/4L IS USM Canon EF 40mm f/2.8 STM +4 more
davel33 Senior Member • Posts: 2,978
You need MFA because of manufacturing tolerance on both the lens and the body. Your MFA of +8 could just as well be from you 7D2 as the lens. I MFA my lens on both my 7D2 and 70D they are not the same, 7-8 difference for most of them. Even if you have the lens calibrated it does not mean it will be right on another camera.
Dave
 davel33's gear list:davel33's gear list
Canon EOS R Canon EOS R6 Canon RF 35mm F1.8 IS STM Macro Canon RF 24-240mm F4-6.3 Canon RF 85mm F2 Macro IS STM +29 more
Keith Z Leonard Veteran Member • Posts: 6,134
Thing is that there is a range of "within spec", so any lens might front or back focus a bit on any given Canon body.  You could send that lens into Canon and it could come back the same, as it's likely within their "spec".  If it's under warranty you might want to send it to Canon anyway before you sell it, up to you.
All "fast" lenses might require MFA on a given body, that's why the pro bodies have MFA.  I just picked up an 85 f1.8 that needed -13 and it's dead on now.  My Sigma 50 is at -5.  My 135L didn't need any....
 Keith Z Leonard's gear list:Keith Z Leonard's gear list
Canon EF 70-200mm F4L USM Canon EF 100-400mm f/4.5-5.6L IS USM Sigma 50mm F1.4 EX DG HSM Canon EF 24-105mm f/4L IS USM Canon EOS 400D +16 more
gqllc007 Junior Member • Posts: 45
Not sure what the issue is...most of my lens need some type of MF adjustment. Very normal..If your lens is sharp after MF just sell it the way it is. The reason Canon has MF is for the different tolerances of bodies and lens...I dont see any issue with your lens.
Seehorse Regular Member • Posts: 124
Mine needs +6 on my 7D Mk II and +2 on my old 7D Mk I.  It's tack sharp and fast on both bodies.  It's no big deal.
The possible problem is if it needs a different adjustment at wide vs telephoto... that can be problematic on many bodies.  My new 150-600 Tamron needs +3 wide/+8 telephoto on my Mk II body which would be an issue on my old Mk I with only one adjustment.
I don't have any lenses that don't need some minor adjustment for optimal performance; the closest is my 70-200 f4L IS at +2 on my Mk II and -1 on my Mk I.
 Seehorse's gear list:Seehorse's gear list
Canon EOS 7D Canon EOS 7D Mark II Canon EF 50mm F1.4 USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-200mm F4L IS USM +5 more
axlastro Regular Member • Posts: 497
You should send both the body and lens to Canon and let them adjust them. You could try your body with different lens and see if there is any need for MFA - if it has the same issue with other lens, then you could tell them that the body needs adjustment too.
 axlastro's gear list:axlastro's gear list
Canon EOS Rebel SL1 Canon EF 85mm F1.8 USM Sigma 30mm F1.4 DC HSM Art Canon EOS M Canon EF 50mm F1.4 USM +4 more
geronimo789 Regular Member • Posts: 263
I'd say to sell it as-is, simply mention everything is working perfectly on your 7D with +x MFA.
Enthusiasts/pros will know what you mean and not care one bit or move on to another lens.
Entry level people (aka; with rebels and kit lenses) are not so likely to be buying this lens. If they do it's simply up to them to research what MFA is and take an informed risk. Canon will probably do nothing with your lens, since it's likely perfectly within spec.
Sending body + lens in is kinda dumb because the 'defect' may just as well reside on your camera. So sending both in might actually make the lens WORSE instead of better.
More info for you/potential buyers: http://www.canonrumors.com/tech-articles/this-lens-is-soft-and-other-myths/
 geronimo789's gear list:geronimo789's gear list
Canon EOS 70D Canon EF 50mm F1.4 USM Canon EF 24-105mm f/4L IS USM Canon EF 70-200mm F4L IS USM Canon EOS M +3 more
Jonathan Brady
Jonathan Brady Veteran Member • Posts: 6,725
I agree with a common sentiment of this thread
Don't sweat it.  MFA doesn't mean something is wrong with your lens.  In fact, your lens could be the most accurately calibrated lens ever, and your body is off.
Now, if the lens was heavily decentered or something like that, then yes, I'd say mention it.  But requiring MFA?  Don't even mention it as you're not hiding anything.  Most lenses require MFA if you pixel peep.
Taken from an MMA article and I think it applies on DPR:
"My point is, we all do this. And we feel entitled to do it, because we think we’re smart people with smart opinions. If we also happen to be paying customers of the thing we’re opining about, then forget it. How obnoxious we feel entitled to be is directly proportionate to how much money we’ve spent." - Ben Fowlkes
