20-50 Focus Ring?
Started Mar 7, 2015 | Discussions
mordor_74 Contributing Member • Posts: 622
20-50 Focus Ring?
Good light has come and I've start fitting my 20-50 instead of the 18-55. I really love this lens, both handling and IQ.
I noticed that i can use the rotating element as a focus ring, but i dont think it was mad with this usage, so i wonder if someone else is using that way and if you think that it would damage the lens.
 mordor_74's gear list:mordor_74's gear list
Sony Cyber-shot DSC-HX5 Canon EOS Rebel SL1 Samsung NX1100 Samsung NX 30mm F2 Pancake Tamron SP AF 17-50mm F/2.8 XR Di II VC LD Aspherical (IF) +7 more
Stan Still Regular Member • Posts: 227
Re: 20-50 Focus Ring?
It has always worked that way (the clue is in the manual under "Manual focus) so no, it will not damage your lens.
 Stan Still's gear list:Stan Still's gear list
Panasonic FZ1000 Panasonic LX100 Panasonic ZS100
If you mean rotating front element, yes, I don't think it was made to withstands such forces in regular use, I would not do it too much (the problem is likely uneven twisting by hand) . You can accomplish the same thing by activating DMF option and half pressing the shutter and then fine tuning the focus with proper focus ring.
OP mordor_74 Contributing Member • Posts: 622
Found the manual online... Seems clear that the rotating element ia not made to be used as a focus ring.
http://samsungnxtips.blogspot.com
We must be talking about 2 different things then. I assumed that you meant the ring next to the zoom ring which is the focus ring.
As Otto K said, you can focus manually by half pressing the shutter and turn the focus ring and you will get a magnified image and focus peaking.  Why anyone would want to focus using the small front ring is a mystery to me.
