Olympus 40-150 F2.8 Tripod Mount Ring Studs
Started Mar 5, 2015 | Discussions
WNeuetc Regular Member • Posts: 378
I have an Olympus 40-150 F2.8 Pro lens and, like most users, have found it to be a superb lens.  It's extremely well made - clearly built to the "Pro" standards implicit in it's name - and takes extremely sharp, saturated and contrasty images.
However one annoying aspect is the rather sharp and prominent metal studs around the lens body near the rear of the lens that retain the (thank you Olympus!) included tripod mount. While probably not sharp enough to cause injury, they can be very irritating, sufficiently so that I leave the (bulky and a bit heavy) tripod mount on, even when I have no intention of using a tripod or monopod.  I'm frankly a bit astounded that Olympus didn't include a protective cover or trim piece of some sort for when the tripod mount isn't attached. I mean, they even included a removable cover piece for their venerable (and consumer grade/priced) 47mm F1.8 hood mount ring.
Is anyone aware of either an Olympus or aftermarket item to cover these annoying little studs?  (As an aside, these aren't even very well done or designed.  Frankly they look, and feel, like little stainless steel pop-rivets.)  Or possibly some clever DIY solution?  Hell, if nothing else I may have to pull out a roll of gaffers tape.  Would serve Oly right to see their $1200 masterpiece gaffed up!
Wes Neuenschwander
Seattle, WA USA
 WNeuetc's gear list:WNeuetc's gear list
Olympus E-M1 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro +2 more
Skeeterbytes Forum Pro • Posts: 23,182
Re: Olympus 40-150 F2.8 Tripod Mount Ring Studs
Hmm, tricky. Have three Oly lenses with the tripod mount but none that bothers me when handholding (drat the luck, don't have the new Pro).  Could you perhaps wrap that stretchy medical tape around it? A couple layers could both cushion the lugs and give a nice grippy surface to hang onto. Available in colors, too!
(Confess I thought of it because I was wearing some recently due to a nasty leg gouge I had to have stitched up. The stuff is vastly better than tape because it doesn't rip out hair.)
The aftermarket will probably come up with a fitted silicone ring that will be a mere seventeen dollars.
Happy experimenting.
Rick
Roger Engelken
Roger Engelken Veteran Member • Posts: 5,558
I have that very same lens, and have never noticed the studs.  I also grip the lens by the tripod collar, which is bad form but it fits very comfortably.  I will certainly not be gaffing up my lens, thank you very much.
 Roger Engelken's gear list:Roger Engelken's gear list
Olympus PEN E-P5 Olympus E-M1 Olympus OM-D E-M10 Panasonic Lumix DMC-GX8 Olympus E-M1 II +29 more
cfh25 Senior Member • Posts: 1,070
Given they've designed the "studs" to be on the top of the lens, I've found they aren't touched in the normal hand-hold for supporting a lens
OP WNeuetc Regular Member • Posts: 378
Perhaps I misunderstood you - or perhaps you misunderstood me (a common issue, I'm not always clear).  The studs are completely concealed and out of the way when the tripod mount is attached.  They're only exposed when the tripod mount is removed.  I was thinking of some sort of ring (much more compact than the tripod mount) which could be placed over the studs, in lieu of the tripod mount.
Yeah, I'd rather not gaff up my lens either.  Though will say, gaffer's tape is what duct tape should have been.  I've left it on gear for months, or longer, and it always peels off clean - no residue.
Wes Neuenschwander
Seattle, WA USA
JohnLock Senior Member • Posts: 1,524
I've thought the same thing-- including electrical tape-- but that would leave a sticky residue and be difficult to take of when the ring is needed.  I think gaffer tape would have similar issues unless you never intend to remove it.
Skeeterbytes suggestion has some real merit if you can find a way to slip it on and off.  Anyway, I'm having the same type of issues w/ my 40-150 f2.8 and am looking for a solution.
O/T, but Related, I've only used that huge lens hood once and that was just to try it out, besides being big it's heavy and this lens is virtually flare free.  I'd use it for rain protection though.
JL
 JohnLock's gear list:JohnLock's gear list
Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS
I'm not sure I understand. What I'm referring to are the four small metal pins or studs, spaced around the lens barrel under the tripod mount collar, about 2" from the rear of the lens.
True, one would normally grip the lens further forward when shooting, but when walking around I'm much more likely to grip further back on the lens barrel, nearer the camera body, and the damn studs are uncomfortably sharp edged.
To provide some simple protective cover for when the tripod mount is removed - especially on a top drawer lens like this - would seem an obvious thing.
Here's a quick shot of the 40-150 F2.8 Pro lens to illustrate the issue:
Olympus 40-150 F2.8 Pro lens, with tripod mount removed.  Note the steel studs that engage - and are covered by - the collar when the tripod mount is attached.
The studs look - and feel - like steel pop-rivets. Frankly, if they had been some sort of smooth machined inserts, it would be less an issue.
Wes Neuenschwander
Seattle, WA USA
macropaul Regular Member • Posts: 385
put an elastic band over the studs .must admit after removing the the tripod collar on mine and looking at the studs ,it kind of detracts from the look of the lens ,so i put it back on ,i also use the mount to rest in the palm of hand while holding camera ,supports well .
 macropaul's gear list:macropaul's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX8 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 75mm F1.8 Panasonic 12-35mm F2.8 +1 more
Ditto. Detracts from the looks and can be irritating - both literally and figuratively - in hand, so after trying it sans mount, I also put it back on, finding it to be a nice hand grip at times and also nice for supporting on surfaces when I need the extra stabilization. I'm on the lookout for an elastic band that will fit nicely, without detracting too much from the beautiful appearance of this Olympus masterpiece.
Back to my original post though, I guess I'm just griped that Oly didn't see fit to address this up front, particularly since they provide - an essentially superfluous - cover piece for $399.00 M. Zuiko 45mm f1.8 lens hood mounting groove. C'mon, who cares about a naked hood groove when you're bleeding from your 40-150 lacerations? (Just joking; just joking..)
Wes Neuenschwander
Seattle, WA USA
Lucas McDonald
Lucas McDonald Regular Member • Posts: 334
It annoys me as well , sort of makes the lens look cheap so I leave the tripod ring  on , it's just not about the photos you know sometimes I just like touching the bloody thing lol.
 Lucas McDonald's gear list:Lucas McDonald's gear list
Sony a7R III Sony FE 70-200 F4 Sony FE 85mm F1.8 Sony FE 20mm F1.8G Sony FE 35mm F1.4 GM
Airmel
Airmel Senior Member • Posts: 1,303
After humping my ZD 50-200mm and ZD 150mm lenses for years, and both having very similar studs exposed, it doesn't even occur to me that their presence is an issue.
Oh, and on my MZ 40-150mm Pro, they are hex head screw heads, no pop-rivets.
AirMel
http://www.mel-photo.com
There are 10 types of people in this world.
Those that know binary and those that don't.
 Airmel's gear list:Airmel's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro +18 more
lambert4
lambert4 Senior Member • Posts: 2,335
Place a black rubber or siliconbracelet around it, I believe they are even marketed a zoom ring bands to prevent lens creep.
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron SP 150-600mm F5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
OK, they *are* Allen head cap screws (minute).  They just *look* like pop-rivets.  My hyperbole.  Whatever they are, they are pretty sharp and (IMHO) look sorta cheapish.
Wes Neuenschwander
Seattle, WA USA
Yep. Learned something new today:
http://smile.amazon.com/Lens-Band-Stop-Creep-Black/dp/B0050KEEW0/ref=sr_1_2?ie=UTF8&qid=1425594421&sr=8-2&keywords=LENSband+Lens+Band
Exactly what I was hoping for - a simple, elegant and (reasonably) inexpensive solution.
Thanks!
Wes Neuenschwander
Seattle, WA USA
I've been following this thread with interest as it's a (minor) irritation to me too.  The rubber band for lens creep as suggested by Lambert may well do the trick.  Cool, and my thanks too.
John
Well, I ordered one of those lens bands (AMZ)-- a little spendy + $5.06 shp and handling, but I'll have a go at it.  And if it works well I'll report back.  Or maybe the OP will.
John
John
I will indeed.  My Amazon version (even more spendy; but WTH, after dropping ~$1600 on the lens, I ain't gonna sweat it) should be here Saturday. Probably could have scrounged around for a "Livestrong" (I hear they're available cheap) or some such, but I'm lazy - and don't want my fancy lens to be mistaken for a cheater (sorry, sorry; I promise no more proselytizing, or holding forth).
As an aside - or maybe the main point - what a great group this is!  Open minded - and hearted - discussion and sharing!  Thanks everyone!
Wes Neuenschwander
Seattle, WA USA
Lucas McDonald
I hope you didn't get the bright yellow or red one , the Pro range of lenses are only allowed to be pimped in black , will be interesting to see if this works as I can see Olypmus coming out with there own branded lens band and charging $50 for it lol.
Big Ga Forum Pro • Posts: 18,627
I don't believe the 50-200 (mk1 anyway) has studs like that shown on the 40-150. There is just one larger locating lug.
Airmel
Mine is the SWD version and it has four lugs/pins. The ZD 150mm F/2.0 has two.
AirMel
