Canon L lens failures
Started Mar 4, 2015 | Discussions
(unknown member) Forum Pro • Posts: 11,521
Re: Canon L lens failures
blogdawg wrote:
I've been a user and advocate of Canon products since 1995, recommending them many times to camera shoppers, but I'm rapidly losing faith in the quality of their L series lenses. In the past 6 months alone, I've had three Canon L lens failures which so far has cost me over $1200. The first failure was the 24-105mm f/4 L, which had the infamous "err 01" failure, which essentially means a ribbon cable loses connection when the lens is zoomed out. While this has been a common failure with this lens among many photographers, Canon refuses to admit the problem is a manufacturing defect. The second failure was with the 100-400mm f/4.5-5.6 IS L lens, which turned out to be the same problem as with the 24-105. My third failure was with the 85mm f/1.2L II lens, which would hang up at the minimum focus distance while seeking focus.
While it certainly seems like you've had a run of bad luck - how long have you had those lenses?
OP blogdawg New Member • Posts: 8
I've had the 100-400 since 2001, the 24-105 about 5 years, but the 85 f/1.2 for only 2 years, which was the one that hurt when Canon quoted me $1563 to repair it. Don't get me wrong, I'm completely aware of the sophistication of today's lenses - usm, autofocus and IS all in one lens. The 100-400 has been a workhorse and a great lens. However, I don't understand the need for electronic manual focus "fly by wire" on the 85mm, unless Canon is trying to prevent users from mounting them on other systems. Just adds to the complexity of the lens, in my opinion.
Suave Senior Member • Posts: 2,289
Re: Roger Cicala has failure stats
Uhh, Nikkors and grease.... for every 50/1.4 with empty helicoids I have one stuck 55/2.8.
Where's my new 50, Canon?
 Suave's gear list:Suave's gear list
Nikon D7000 Canon EOS 5D Mark III Canon EOS RP Canon EF 85mm F1.8 USM Canon EF 24-70mm f/2.8L USM +7 more
maiaibing Veteran Member • Posts: 5,139
I agree the fly by wire focusing is a weak point of the lens as it also did not resolve the relatively slow focus of the 85L II - making it difficult to use the 85 L II for sports etc. even if this was what Canon intended when they made the II version.
Here Canon seems to have gone for a adjustment of the overall design in stead of a completely new construction - which of course would have been much more expensive.
 maiaibing's gear list:maiaibing's gear list
Canon EOS 5DS R Canon EF 70-200mm F2.8L IS II USM Canon EF 300mm f/2.8L IS II USM Canon Extender EF 1.4x III Canon Extender EF 2x III +5 more
