Camera Backpack recommendation e-m1 plus wildlife lenses
Started Mar 1, 2015 | Questions
vass
vass Senior Member • Posts: 1,929
Hi
I just recently received my 40-150 pro with mc-14 teleconverter. Now before I start birding again and taking wildlife photos in the forest or where I can get close to small birds, big birds I need a camera backpack that can hold the following items.
EM-1
FL-600R Flash
m.zuiko 40-150 f2.8 pro + MC-14 teleconverter
m.zuiko 300 f4 pro (when it comes out i'll be adding this to my kit)
m.zuiko 60mm f.28 macro
m.zuiko 12-40 f2.8 pro
Handful of UV and CPL filters
3 spare batteries
4xAA batteries
cleaning kit and cloths
Battery charges etc I don't care for as I wont be charging in the wild
I have seen a few that look ok online but without physically seen them its hard to know how everything will fit.
Anyone know of a good backpack anywhere between 0-100 AUD out there that can accommodate for this or have similar kit even with 4/3 lenses or any adapted lenses?
 vass's gear list:vass's gear list
Panasonic Lumix DMC-FZ18 Olympus E-M1 Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 12-40mm F2.8 Pro +3 more
Olympus 40-150mm F2.8 Pro Olympus E-M1
Colin Smith1 Senior Member • Posts: 1,104
Re: Camera Backpack recommendation e-m1 plus wildlife lenses
I have exactly the same gear as you, plus one more E-M1.  I use a Lowepro Pro Runner 300 AW.  It should also have room for the new 300 Pro when they release it.
Colin Smith
 Colin Smith1's gear list:Colin Smith1's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 85mm F2 Macro IS STM Canon RF 800mm F11 IS STM
vass
OP vass Senior Member • Posts: 1,929
Thanks, i'll put that on the list of bags to look at
Ken Gosden Veteran Member • Posts: 3,025
I carry a similar load in my LowePro Photo hatchback 22L AW.  Can't have the body attached to a big lens inside.   And you might need to use the non-photo section to hold the 300mm.  Last week i had the 4/3rds 50-200, Sigma 50-500, 9-18, ec-20, m4/3rds 40-150 kit zoom.  Still room for a few batteries,  etc.   The E-M1 w/12-40 traveled outside in a small case.  Since those 4/3rds are a bit larger than your kit it might fit.
 Ken Gosden's gear list:Ken Gosden's gear list
Olympus XZ-2 iHS Olympus Tough TG-3 Canon G5 X II Olympus E-M1 Olympus E-M1 II +19 more
vass
I'm tossing between the lowpro mini trekker and the pro runner 300 aw runner atm. Hmm there is not much difference from the look of things to me. Has anyone had experience with both these?
Martin7404 New Member • Posts: 1
Hi,
I had a Lowepro Vertex 300 in the past and sold it (I think i´ś quite similar to the model you looked into).I bought the Lowepro Rover Pro 45L AW which is the best rucksack I ever had.
The biggest advantages are that the rucksack is not so deep and therfore the mass center drawing you back. And the waist straps are really broad. All in all it´s a trekking rucksack (with space for photo equipment) and not the other way around. I used it with my heavy Nikon equipment before I sold all that stuff and came to Oly And only with that model I could walk for hours withouth shoulder pain and later on a bad headache.
Try to find a shop where you can test the rucksacks.
Good luck
Martin
vass
Thanks for all the advice guys, never had a backpack for a camera before as I used to shoot lumix FZ series camera which came with a fixed lens. I ended up ordering the pro runner 300 in the end. Was a tough decision and I think pretty much all those backpacks mentioned would be great so thanks again for the imput guyz
regards,
Vas
R V C
R V C Senior Member • Posts: 1,272
I am in the same hunt, and I thought instad of starting a new thread would just use this one.
To the OP ( apologies for taking over, hope you dont mind)
ANyone has any idea about the Kata 3in1 33?
Much like the OP i will be using it for birding and would like to carry my Sigma 50-500mm and Nikkor 400mm f3.5 both mounted to camera if possible.
"Anything worth doing is worth doing poorly until you learn to do it well."
-- Zig Ziglar
https://www.flickr.com/photos/126558841@N07/
 R V C's gear list:R V C's gear list
Ricoh GR II Olympus OM-D E-M5 Olympus E-M1 Olympus E-M1 III OM-1 +16 more
Hithertoo Senior Member • Posts: 1,841
Here's my urban photo sling 250, with an extra divider in it. I like it because its the transformer of camera bags, load it like a backpack, wear it like a sling, unload it like a top loader.
  • It fits either 4 lens with 1 quick release and a lens on the body
OR
  • 3 leans and an accessory such as a camera flash.
  • It also fits an 11" laptop or tablet.
  • It will also fit a full sized lens attached to your body such as a Canon 5D with a 70-200 in the top loading compartment where that square is.
  • It will fit an even longer lens if you take out the divider which I'm using for a flash.
No bag of course is perfect and this bag does not come with enough dividers, so I stole 1 out of my old bag
That said the slots for lens are deep enough to fit at least a full 75mm length EF sized lens in each slot. The top loading slot is designed for a full frame camera body, You could quite easily fit 2 Micro Four Thirds bodies in it with lenses attached.
I have it configured with a 20mm F/1.7 45-150 and 14-42 as well as an FL36. I could fit another lens in it if I had a divider with my 12/2 on my camera body.
 Hithertoo's gear list:Hithertoo's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R +7 more
vass
All good
Gravi
Gravi Senior Member • Posts: 1,546
vass wrote:
Hi
EM-1
FL-600R Flash
3 spare batteries
4xAA batteries
I went to Norway last september with two bodies, oly 50-200 + tc and a lot of other lenses. I used my old Lowepro Mini Trekker AW and I'd say it can hold your gear comfortably.
The inside is quite adjustable, and there is room on the front pocket for a lot of extra stuff. You can even mount a tripod on it, which I found quite useable for long walks. I found the bag to be comfortable enough for these long walks.
Downside is that you have to take the pack off your back for camera access...
But as the bag has been around for some years already, it is easy to find one second hand, if you want.
Gravi
randallktodd Junior Member • Posts: 31
These are well made, and can handle camera gear plus space for day hiking...
http://clikelite.com/products/product-category/backpacks/
Randall
Arizona Sunset
Arizona Sunset Veteran Member • Posts: 3,797
Have researched this a ton, because LowePro and the other popular gear companies don't make a legitimate outdoor / adventure / climbing backpack with modern suspension and layout.
Here are three options that I considered after reviewing and handling dozens more. Each has their own unique layout and features, an external tripod attachment, and is extremely lightweight.
1) FStop Loka UL - the sensible, lightweight choice
My cousin saunters around the flat lands "wilderness" with his FF kit (similar in size and weight to yours) with fstop backpacks, and swears by them. The Fstop Loka UL is something that I've looked at a couple of times, but ultimately, due to having so much space, decided against. I tend to fill the bag up, which means that I'll be less likely to make it to the next ridge or top of the mountain if it's too big.
Fstop has a variety of options - here's the Loka UL
2) Click Elite Obscura (for quick draw pouch) - probably not great for your case
I briefly owned an adventure camera pack from Click Elite (or however you spell it) called the Obscura. It's really a clever design for storing a camera, has a quick draw padded insert, and it relatively light. I would have kept it but abandoned the bulky and heavier zoom lenses from my kit in favor of fixed compacts, and didn't need the larger padded space.
For your purposes, this would fit the bigger telephoto zoom and the EM1:
3) MindShift Gear Rotation 180 Panorama
This is an innovative product with a patented waist belt.
If I were you, I would seriously consider this option, however, you have so much gear, that I'm not sure that it will work - perhaps you could figure out how to make it work.
I'd probably go with choice #3 to see what innovation in a backpack can do for my photography, however, your needs may be different.
All three options would require separate pouches for your extra stuff, but that's kind of a given.
 Arizona Sunset's gear list:Arizona Sunset's gear list
Canon G7 X II Sony RX1R II Sony RX100 VI Apple iPhone 7 Plus
Bruce Clarke
Bruce Clarke Senior Member • Posts: 2,690
Bit late for you now, but others may want to give the Benro Cool Walker series a look. Here's my experience with the CW200 backpack:
http://www.dpreview.com/forums/post/55357989
Bruce
 Bruce Clarke's gear list:Bruce Clarke's gear list
Olympus E-M1 Olympus E-M1 II Olympus E-M1 III Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital 1.4x Teleconverter EC-14 +7 more
Martin.au
Martin.au Forum Pro • Posts: 14,339
I've recently been in a similar position. I needed a proper daypack to carry waterproofs, lunch, geology gear, jumper, spare shoes, hydration pack, etc, and a decent array of camera gear. The problem is most camera backpacks are designed around the camera gear and don't have much space for other gear. These bags - The Fstop Loka with it's ICUs and the Obscura - with it's two compartment setup, looked like the best options for hikers who want to carry camera gear. The gear rotation pack I wasn't convinced about, thinking it may be quite tricky to rotate it back if the daypack is full.
I wasn't able to find those options in Australia, so I bought a nice technical day pack - Mountain Designs Stream T38 and combined it with a Thinktank V10 holster - for fast access to the camera, and a load cell (which is similar to the ICUs from Fstop, but around $30 - http://www.kathmandu.com.au/packs-and-bags/packing-solutions/cells/protective-cell-v2-l-black.html). This allowed me to take a decent array of lenses (12-40, 75-300, 75mm, 60mm, 8mm FE, FL300R flash). When the 300mm comes along, I'll probably pack it separately in its own case, as it will spend most of it's time in the holster and will be so much larger than the other lenses. If pushed, the top pocket of the T38 can also hold the E-M1 + 75-300mm lens.
As for the Kata 3n1 someone asked about earlier - I have a Kata 3n1 22, and it's a magnificent pack. Built really well. I don't use it much, as I've gone to shoulder bags for general wandering and proper backpacks for hikes, but it's exceptional for backpacking/slinging camera gear.
One final option I'm going to keep an eye on, is the idea of a small lens pouch, just big enough to hold the largest lens I'll carry, so I could have one on the camera in its holster, and a second lens available without taking off the pack.
 Martin.au's gear list:Martin.au's gear list
Olympus OM-D E-M5 Olympus E-M1 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +7 more
These are some serious backpacks, if you want to carry a fair amount of gear they look nice. It's correct Lowepro don't really make anything like this and there bags are catered around carrying you gear and not your packed lunch also.
The only reason I posted what I posted above is simply to show just how much you can fit into a small pack. I used my Urban Photo Sling as a travel pack that is small enough to be measured and put through regular carry on luggage when going through airports. This was my primary concern as I travel through Melbourne, Sydney and Canberra regularly and I needed something big enough to carry lots, and particularly going through Canberra something that would fit on a Dash 8.
All views expressed above are my own not an expression of how others should think, or as a matter of group think.
