E-M5II extreme macro for metrology
Started Feb 28, 2015 | Discussions
parejkoj Regular Member • Posts: 115
No, I don't mean meteorology...
I'm curious if anyone has considered using the E-M5II high res mode with either a standard 1:1 macro lens, or one of the various 2:1 or higher macro systems for some ultra-extreme macro work? My specific goal here is to do measurements of some precision engineering equipment (metrology).
If I did the math right, the high resolution E-M5II mode should give a physical scale of about 2 microns/pixel. Can the Olympus 60/2.8 macro resolve that scale? Anyone have either of these and able to provide a test?
There are also a few more extreme macro lenses (Venus 60/2.8 2:1, Nanoha x5), which could provide even higher magnification, in particular when coupled with the E-M5II. Most reviews of these lenses focus on their photographic qualities, as opposed to their physical resolving power, so I'd be curious if anyone knows more.
I'm not wedded to micro 4/3 for this purpose (we currently borrow one of the engineer's D810), but it would be quite a bit cheaper and light enough that we could carry it around to use for other purposes.
Nikon D810 Olympus E-M5 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro
nzmacro Forum Pro • Posts: 18,755
Re: E-M5II extreme macro for metrology
I did something up on this for in here awhile ago. 2:1 is a bit low for me, so anything above a 2:1 works for what I want out of it. Generally 4:1, but not always.
http://www.dpreview.com/forums/post/55297406
No crops, I don't crop macro shots.
BTW, specialised lenses like you mention there or even the Canon M-PE -65 F/2.8, you need to be very close to the subject. I hit a 4:1 at a distance of 210mm lens to subject.
Danny.
 nzmacro's gear list:nzmacro's gear list
Sony Alpha NEX-7 Olympus E-M1 Olympus E-M1 II Sony a7R IV Sony FE 200-600 F5.6-6.3 +5 more
SteB
SteB Veteran Member • Posts: 4,577
A bit of info.
https://www.flickr.com/photos/9578475@N02/
I'm pretty certain I will be getting the E-M5 II for greater than life size photography in the near future. I've just got a move coming up, and then as soon as I've moved in a few weeks I'll be getting one. I'm specifically interested in the his res sensor shift feature. I've got a whole set of macro lenses, mainly Canon fit including an MP-E 65mm f2.8 1-5x lens I will probably use with it via a Metabones smart adapter, plus I'll probably be getting a Venus (now called ‘LAOWA’) 60mm and an Olympus 60mm macro.
http://www.venuslens.net/
One of my internet friends just did a test on one, and there are some full res comparison images he took. He compared it to the Tamron 60mm f2 macro and the Canon MP-E 65mm at equivalent magnifications. It is at least as good as these lenses. Wide open it is apparently still quite good in the centre.
http://orionmystery.blogspot.co.uk/2015/02/venus-60mm-21-macro-lens.html
Be aware though that apparently the Venus lens apparent shows some slight distortion. Not visible on insects, but possibly on engineering samples.
From what I've read the Olympus 60mm should be more than capable of resolving the detail.
However, what you need to be aware of is that as you get more into the macro region is that the effective aperture becomes smaller than the nominal one, due to the bellows factor. Already 2 f-stops smaller at 1:1. This means diffraction softening kicks in earlier. Therefore, for maximum resolution, but not necessarily for active insect shots, you need to use a wider aperture. Until at higher magnifications, for maximum resolution you will need to use the lens near wide open, and focus stack if you want more dept of field.
An alternative for higher magnification in a controlled situation like engineering photos, would be to use a reverse enlarging lens, a bellows lens, or a microscope lens on a bellows. This link below has some good tests and reviews. It also tells you the extension you will need for various magnifications. Some of the better enlarging lenses can be gotten quite cheaply secondhand.
http://coinimaging.com/Lens_tests.html
This is the best person I know for information on using various microscope, bellows and enlarging lenses. Whilst John shoots mainly insects, his technique is the best, and he produces some incredibly high magnification focus stacks. Look at the equipment sets for more information. There is a lot of technical information there.
https://www.flickr.com/photos/johnhallmen/
Conrad69 Junior Member • Posts: 48
Interesting question. Disclaimer: since this is an engineering question, you get an engineering type of answer that may not be a perfect match with a photography audience.
About diffraction: when modeling the sensor resolving power in combination with diffraction limits, the 40 Mp MFT camera will suffer a 20% impact on resolution because of diffraction around f/6. If you do not care about depth of field (flat subject), I would advise to stay at f/4 or below for MFT. This advice holds equally for the D810 to achieve the same resolution at subject plane (at magnifications larger than 1:1, the diffraction limit is at the subject side). Take also into account that the real aperture at maximum magnification is likely one or 2 stops worse than the value specified for focus at infinity. So basically, shoot wide open. If you get more resolution by stopping down, there is still significant room for resolution improvement by finding a better lens.
About lens data: I have only tried the Panasonic Leica 45/2.8. At maximum magnification (1:1) the lens is actually sharpest (in the center) wide open, which suggests very low aberration levels. At this aperture I can, on a GH4, clearly resolve a tiny "plus" sign with an overall width of 20 micron and a line width of 4 micron (chrome on glass). I do not know the performance of the Oly. Take chart measurements for comparing it to the PL45 taken from several meters with a grain of salt. They are not representative for macro lenses since they can be optimized for closer distances.
I don't know what type of structures you need to resolve, but my model of the GH4 reaches for a perfect lens an MTF50 value for repeating line/space structures at 4 micron line width. This goes down to 2.5 micron when i substitute in the same model a 40 Mp sensor with similar anti aliasing filter strength (additional blurring as a percentage of pixel size). Based on the model in combination with the measurement, I would take the bet that the PL45 in combination with the EM5ii will resolve better than 4 micron line/spaces when placed on a very sturdy tripod, but I'm not sure whether you will reach your quoted 2.
 Conrad69's gear list:Conrad69's gear list
Panasonic GH5 Olympus Zuiko Digital ED 50mm 1:2.0 Macro Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Leica Summilux DG 25mm F1.4 +3 more
k0mit
k0mit Junior Member • Posts: 29
Yes, I did a quick macro test. You can see it on Flickr:
https://www.flickr.com/photos/thrumikesviewfinder/16649226955/
And I didn't even get all the way to 1:1 magnification in this image.
Mike
 k0mit's gear list:k0mit's gear list
Fujifilm X70 Fujifilm X100F Olympus E-M1 Olympus E-M1 II
