The fourth camera in Leica's SL series of full-frame mirrorless cameras sees the 60MP BSI sensor from the Q3 and M11 models arrive with a significant interface redesign.
16 mm Zeiss Hologon on A7s sony
The 16 mm f 8.0 Contax g Zeiss lens is a legendary super wide angle lens and trials to fit and use this lens on the A7, A7r have been unsuccessful where the posterior element is recessed far back and thus interfering with the movement of the mechanical shutter. I have purchased the contax g lenses to use on my A7s with the autofocus adapter from Techart and it worked fine except for the Hologon 16 mm that would not attach to the adapter due to bulky rear element. I found an alternative manual focus adapter from fotodiox that could fit the lens with a smaller focus ring that does not cover any part of the focusing mechanism of the lens. I decided to try the electronic shutter feature that is unique to the A7s completely disabling the mechanical shutter. It worked fine and now I will work on the vignetting and chromatic aberrations. as the in camera application for lens correction fires the mechanical shutter by default.
So I conclude that unlike all reports on the internet with A7,A7r that the Hologon was not useable, the A7s works fine with the Hologon 16 mm with the electronic shutter
K.Gawdat
Cool. It looks impressive on the A7S, too.
Can you post a shot or two taken with it?
A7 with kit lens and a number of legacy lenses (mostly Canon FD); A3000 converted to IR.
I went out side and did some test shots. I will need a lot of work on the chromatic aberrations so these are some B&W samples for now
iso 200 1/60 sec f8 no graduated nd attached vignette corrected
iso 400 1/60 f 16 graduated nd attached vignette correction
iso 125 1/60 f 16 graduated nd filter attached minimum vignette correction
K.Gawdat
You brave soul! I am planning to get this lens as a complement to my ZM 15, small, light and zero distortion at f/8. You're the second one shooting this on the A7s. Can you take a few diagonal infinity shots so I can assess the smearing? Would be much appreciated.
Thanks to your report I bought a Fotodiox adaptor for my Sony A7s and my various Contax G lenses. Unfortunately the Hologon 8 / 16 does not reach infinity. The range the photos are sharp is between 0.2 to 0.7 meters.
Comparing the Fotodiox with the Techart GA3 adaptor the Fotodiox adaptor is 0.3 mm thicker! Unfortunately due to the bulky rear element of the Hologon it is not possible to mount the Techart GA3 so I have no experience with the Hologon and the Techart GA3. According to my measurements, the lens should be approx. 0.5 mm closer to the sensor of the camera the show a sharp picture.
Do you have any solution for the Problem?
A word of warning though. Every now and then, the camera does a pixel remap when you shut the camera off. It uses the mechanical shutter when doing so. You can hear it clearly as the mechanical shutter pop when you power down the camera, even if it is set to silent shooting.
Exchange for a new Fotodiox is the only solution I can think of. If you like the lens enough, you can always send it to DAG (Don Goldberg) to convert it to M-mount. Otherwise, good luck!
Although it would still have horrible color casts, does the A7iii e-shutter mode allow to mount and snap a picture of using this lens?
[This lens will probably sit dormant at $1200 USD until a sensor comes that can register photons from any incidence angle, just like film ever did and always will do. Until then, we are happy to wait ourselves, or for our children, to some day enjoy a lens that was the lowest possible distortion of all lenses. Until then, only curved sensors, or non Hologon designs can work on digital.]
I just re-read and this is answered in the original post. Dumb me. I had no clue that the A7S had had e-shutter since 2015! Of course, current sensors just largely bounce of the edges and the angle and stack makes those that made it through make it look smeared like boston business in the 30s.
Latest sample galleries
Latest in-depth reviews
The Fujifilm X100VI is the sixth iteration of Fujifilm's classically-styled large sensor compact. A 40MP X-Trans sensor, in-body stabilization and 6.2K video are among the updates.
The Nikon Zf is a 24MP full-frame mirrorless camera with classic looks that brings significant improvements to Nikon's mid-price cameras. We just shot a sample reel to get a better feel for its video features and have added our impressions to the review.
This $250 electronic lens adapter is perfect for Nikon Z-mount curious Sony shooters — shhh, we won’t tell anyone.
Latest buying guides
