Shooting sports: PEN E-PM2 vs EM5ii/EM1
Started Feb 21, 2015 | Questions
Nicholas Johnson Regular Member • Posts: 387
I'm fairly happy with my $100 refurb EPM2 but after buying those beautiful Oly primes I am seeing general softness even with good technique and shutter speeds twice the rule. I'm thinking shutter shock and I'd like a body that has been engineered with no shock in mind.
I also have the opportunity to shoot my kids sports (soccer, baseball, tennis) or people getting dragged behind a boat.  Soccer is incredibly tough as the subject distance is changing and the whole scene is chaotic.  Here the C-AF on the EPM2 is so wrong. Just always. Hunting, breathing, sharp background or sharp foreground but the subject in the middle is a disaster.
The question becomes is there anything in the EM5 (original since people have experience, or the II) that makes it better at C-AF than the cheapest m43 with the same sensor. My understanding is that the EM1's PDAF only works on legacy 43 lenses and since I have no desire to buy any its not really on my radar.
In case you couldn't tell I'm in the market for a new body. The EM5ii is at the top of my list for sharp stills and super stabilized video. I just wish I could do C-AF with my current lenses (40-150/5.6R) and not either give up or buy into another system.
Olympus PEN E-PM2
Lisa O
Lisa O Senior Member • Posts: 2,567
Re: Shooting sports: PEN E-PM2 vs EM5ii/EM1
I had E-PM's (1, 2, maybe 3) back when they first came out, focus was never great. The focusing is much better on E-M1 and assume so for the very soon to be released E-M5 MkII.
see about me in my profile for more info
http://500px.com/LisaOsta
http://www.flickr.com/photos/losta
 Lisa O's gear list:Lisa O's gear list
Sony RX100 VII Fujifilm X-T2 Nikon Z50 Sony a7C Sony a7R V +4 more
Barry Stewart
Barry Stewart Veteran Member • Posts: 9,147
Shooting from back screen
I used my E-PL5 for sports shooting for almost a year before getting my E-M1. I still had my E-5 during that year but left it at home unless it was raining. A number of times, it was clear that I should have brought the E-5 and 50-200 swd… but I forced myself to make the E-PL5 and the kit 40-150R work.
First thing: shooting distant objects with a longish lens (40-150R) is difficult when using the back LCD. It's one thing if you have your arms straight out… but if you tilt or tip the LCD (not possible of the E-M2) and have the camera overhead or at your waist, it's very difficult to keep things lined up while the subjects are moving about. An electronic eyepiece (EVF) can be added to any cameras that don't have them built in.
Secondly, that lens is not as responsive as a higher-spec (i.e. "more expensive") lens. It's bound to clog the AF pipeline a little.
Third, I wouldn't put much stock in the C-AF ability of the cheaper cameras. They are great value for what they are… but there's no way Oly can afford to put all of their tools in a low price-point camera.
Realizing all that, I basically went old school when I shot sports with the PL5. The one big advantage it had over the 5 frames per second E-5 was its 10 fps burst mode. I'd lock focus (say, on the goalie in hockey or the batter or baseman in baseball) with a half-press of the shutter and wait for the action to arrive — then rattle off 5 frames at the peak of action.
A small focus point is the first key in getting the AF where you want it.
Most sports need around 1/1000th of a second to freeze limb movement (depending on age and skill), so the F/5.6 of the 40-150 will require you to up the ISO to get that shutter speed. This is a real challenge indoors, or on cloudy days, or in amateur sportsfield light.
There are ways to make a low-budget camera work for you in sports — but hey, if you have the money and want to make things easier, the E-M1 certainly does that. I can't speak for the E-M5 or EM-5 MkII.
Barry
 Barry Stewart's gear list:Barry Stewart's gear list
Olympus E-1 Olympus E-M1 Olympus E-M5 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +6 more
Ulfric M Douglas Veteran Member • Posts: 4,828
Re: Shooting from back screen
Barry said it, proper technique for the camera is important.
I'll mention some of the same and some extra points ;
e-pM2 : switch stabilisation OFF,
use S-AF and burst mode.
Let the camera do what it does best instead of trying to make it act like a PD-AF DSLR.
My e-pM2 focuses just as fast as an E-M5, and C-AF is just as crummy and should be avoided.
There are two lenses that would help : M.Zuiko 75mm and/or 40-150F2.8PRO, and maybe the Lumix 35-100F2.8
VF-2 or VF-4 EVF would help with grip and holding.
Cheksa wrote:
You're evil Ulfric.
drj3 Forum Pro • Posts: 12,636
The E-M1 is supposed to use both PDAF and CDAF when used in CAF mode with mFTs lenses as long as the target stays within the PDAF part of the frame.  It uses only PDAF with FTs lenses for both SAF and CAF modes.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
Skeeterbytes Forum Pro • Posts: 23,186
I'm not surprised--Oly has only recently corralled CAF and using it solely with a back display, especially outdoors, is the pathway to less than ideal shooting conditions. The OM-Ds are the first cameras I've had any success with CAF. And outdoors, an EVF is simply mandatory.
Majority opinion, and the DPR review function table, is that the E-M1 combines CDAF and PDAF for all lenses in CAF, not just 4/3 lenses. I can vouch that it works for soccer.
The kit 40-150 is too slow for sports. Due to the modest apertures it can't isolate the action sufficiently and it also prevents using really high shutter speeds, which is an important component of success. It might be okay for tennis or a lone player on a field, but amongst the chaos and clutter of team sports it is the wrong lens. No matter what system you choose, you'll need to budget for fast glass.
Can the OM-Ds shoot sports? Absolutely. The E-M1 and 5ii are better suited because of the 1/8000 shutter, and the M1's CDAF and PDAF allow for very good CAF. I won't comment on the 5ii's capabilities without some real user experience. They're shipping so we'll know pretty soon. The M5 does work but is a half-step behind the M1 (I own both).
In general, prefer shutter speeds above 1/1000 for soccer--trade ISO for speed always. Several soccer shots are in my DPR gallery, including several with the E-M1.
E-M1+ZD35-100
Oops, the one below is from an E-5!
Rick
OP Nicholas Johnson Regular Member • Posts: 387
PDAF
Thanks for the definitive understanding of that. It sounds like there is still something the EM1 can do that the new EM5 cannot.
It would seem I'm far away from the setup to get great soccer pics consistently. But they do happen. I'm especially amazed when someone, today even at a school event, was telling their husband I have one of those "mackin' cameras." Bottom of the line and it still gets the shot.
But for the sports pics I do see the need for a big fast zoom, probably a 40-150/2.8 over the 35-100/2.8. At that point I'm spending a bunch of money either way. It also seems likely that a lens of that size wouldn't handle too well on the tiny body. Though I find the EM1 too big for my pocket tastes I think the EM5 size might be perfect, especially since I can add more grip as needed but also shrink down when needed.
So big glass is good, but no good without a body to keep up. My wife seems to remember me saying too many times that "this camera is great but not for kids running around" and I'd like to find one that is. Maybe the EM5 will be that camera. I don't need a Canon 1Dx just a better hit rate.
Who needs weather sealing?
Paulmorgan Veteran Member • Posts: 9,499
Nah get a lensbaby, they nail every shot
http://w2.sydsvenskan.se/bildspel/ldasmfriidrott/
"Just" an E-M5 and your existing lenses would up your game, but whether that's just the next step in a journey or an end in itself depends a lot on your goals.
My little soccer player is now 13 and playing on a full-size pitch against girls three times faster than when she was a U8. My kit has had to evolve along with her competition level and the field dimensions. To be honest, I'd have a LOT less invested had she picked tennis or piano or something.
Another pathway: E-M1 and 4/3 50-200. During my E-system days I got the zoom as soon as I figured out the kit 40-150 wasn't cutting it and wow, what an improvement. The Mk1 can be had for less than half the 40-150 Pro. It and a refurb E-M1 could be had for...$12-1300?
Rick
DonParrot Veteran Member • Posts: 4,968
Just use the C-AF plus and press the shutter in one go. With a little practice, this gives you three FPS and each pic is perfectly in focus, due to the camer's great AF speed. Shot running dogs with the even older E-PL3, this way, and it worked fine.
The C-AF of the E-M5 works reasonably but it takes a lot of practice to achieve a semi pleasing keeper rate. And to date, nobody knows if the MKII will do better, in this area. So I'd rather opt for the E-M1 that C-AFs in fine style with both FT and µFT lenses. And will do even better from Tuesday, with the new 9FPS firmware 3.0.
The 40-150R is a fast fociusing lens and if the light is right, it will give you great results with the E-M1. If video also is on your agenda, I'd recommend the GH4. It has a C-AF for dummies (even with the m.Zuzikos but is even faster with Lumix lenses such as the 45-175 that provide the cam with DFD data) and as one can read everywhere (got the cam but don't do video) it's the king of the hill, in the video area.
I wish I was an OLYgarch
 DonParrot's gear list:DonParrot's gear list
Panasonic FZ1000 Olympus E-30 Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix DMC-GH4 +13 more
Sorry, I have to strictly contradict, here. The  PMs and PLs certainly had their weeknesses, but from PL3/PM1, their S-AF was just incredibly fast and precise.
(unknown member) Veteran Member • Posts: 3,010
C-AF isn't he best for sure. I have the same camera and question. S-AF works better and a viewfinder helps but it's not going to help enough t make you happy. I'm looking to upgrade but I'm staying with Olympus. I'm waiting to see how the new firmware for the E-M1 works and what the AF performance of the EM5 Mk2 is. I looked at DSLR's but I would have to give up too much advantage in size and weight to be happy with one.
I don't think so. Shot a lot of great sighthound pics with the 40-150R and the 75-300- If the light is right, they both are well suited for fast action.
Rick
Sorry Rick, but how can you recommend the 50-200 MKI for action. As I see it, it's focusing far to slowly for good keeper raztes. The SWD version will deliver far more pleasing results.
Rick
Works for me and I'm trying to accommodate the OP's budget. Yes, SWD is better but not necessary. For a couple hundred more then yes, an SWD is a good choice but optically they're basically the same.
Rick
My first concern is slow apertures--the kit 40-150 is too slow for good subject isolation with team sports. The other concern is that good light is frequently unavailable as the day wanes, as the season turns to winter and as cloud cover gathers. It's the difference between putting the gear away and continuing to shoot.
Rick
Those photos agitate my GAS.
They're fabulous! And wow, you'd have to have really good field access to pull that off in addition to really good photographic chops. (Have attended the US Olympic Track and Field trials and there you can't get anywhere near the field without full press credentials.)
p.s. You could kinda, sorta do those with the diorama ART filter and WA lens, but probably not to that extent.
Rick
Yes, I understand. But one of my reasons for opting for FT/µFT was to get less subject isolation. From my point of view, it's nice for portraits but boring for anything else. A slight touch is fine for me but I don't want more. Therefore, I recently even added an FZ1000 with 1" sensor to my gear.
That's true. And the same applies to indoor sports. But in the right conditions, 40-150R anf 75-300 can be great action lenses.
