Canon 70-200 f/4 L IS with 1.4x or Canon 70-300 f/4-5.6 L IS or 300 f/4 L IS over Tamron 70-300 VC?
Started Feb 19, 2015 | Questions
OP dheerc New Member • Posts: 17
Re: test pics from all three:
I think my words threw you off. I was mentioning the Photozone results.
I've never tried the 70-200 with TC so far but yeah, without the TC, definitely I see a lot of difference between the two on my T3 and yeah, my Tamron could still be a bum as well.
Anyways, from all your suggestions and very detailed analysis, I've finally come to a conclusion. If the price difference between the 70-200 F/4 L IS and the 70-300 L isn't much, I am definitely going the 70-300 L way, else I will choose the former. I think putting finance as the final stake holder is a reasonable way to finalize two equally good products, don't you think?
Once again, to everyone who took time to explain all the details at every little focal length differences, I really appreciate your comments and feedback. Thanks a lot once again. (^_^)
 dheerc's gear list:dheerc's gear list
Canon EOS 1100D Canon EOS 6D Canon EF 50mm F1.8 II Canon EF 70-300mm f/4-5.6L IS USM Canon EF-S 18-55mm f/3.5-5.6 IS II +4 more
bronxbombers4 Veteran Member • Posts: 3,387
OK, that makes more sense. Yeah my 70-200 f/4 IS looked better than my Tamron when both lenses were bare. I had hoped the tamron might be some miracle (like the 17-50 that got me to seel my 17-40L) that would let me sell the 70-200L and keep the Tamron and get more range all for less money :), but nope.I had to go to the 70-300L to more or less do that (aside from the money aspect, which was even more haha ).
But the 70-200+TC was worse at 280mm than the Tamron at 280mm.
TCs make a big difference, on vs. off. Off, 70-200 definitely was better. On, it was worse. (compared to Tamron)
get the 70-300L
JLN74 New Member • Posts: 19
Re: Canon 70-200 f/4 L IS with 1.4x or Canon 70-300 f/4-5.6 L IS or 300 f/4 L IS over Tamron 70-300?
Why did you go from the 70 - 300 L to the 70 - 300 non-L, or is that a mis-type?
John N.
 JLN74's gear list:JLN74's gear list
Canon EOS Rebel T4i Tamron SP 70-300mm F4-5.6 Di VC USD Canon EF-S 18-135mm F3.5-5.6 IS STM
tatslau Regular Member • Posts: 298
Re: Tamron 70-300 VC can be good
dheerc wrote:
Hi,
I bought a Tamron 70-300mm f/4-5.6 SP VC Di towards the end of last year and I have been shooting water birds and small birds in general on my Canon EOS Rebel T3 (1100D) for quite some time.
Recently, I rented the Canon 70-200mm F/4L IS and I must admit that it has been a pleasure to use it and the IQ is simply splendid in its focal range. I really feel like ditching my Tamron for it but then knowing that whenever I use these lenses, I always zoom out to the 200 or 300mm (Canon and Tamron respectively) whenever I shoot, I really feel like getting the 70-200 now wouldn't be a great idea so, I thought of getting the f/4 L IS with the 1.4x TC. This was when I noticed the 70-300mm L lens. I did some internet research and some DxO mark pixel mapping and Optical sharpness on an APS-C camera and I found that the 70-300 L has a similar map as my Tamron, a little better for sure but not as good as the 70-200 f/4 L IS. During my research I also came across the 300mm F/4 L IS as well and thought that was attractive for its price but then again, weight considerations come in.
Weight wise the 70-200mm f/4 L IS is identical to my current Tamron but quality wise, they are very different! At 300mm, the IQ of the Tamron is poor; even in the overlapping range the Canon is hands down the winner.
So, my dilemma now is, which lens do I upgrade to? A 70-200mm F/4L IS with 1.4x (used copies of both are pretty attractive for their price on some forums!) converted to get me to about 280mm and then later crop the image ( which by the way, I must say, without the converter now, look amazingly detailed!)
I got this image at the 200mm end and cropped it to around 50-60% to get this:
I love the quality of this lens but then again, if the 280mm with the teleconverter is going to be as bad as my current Tamron, it isn't a worthy upgrade. On the other hand, the 70-300mm f/4-5.6 L IS's IQ looks almost identical but I did see that it became a little soft at 300mm. The 300mm f/4 L IS lens's IQ looks pretty fine, in my opinion but it's huge to carry around!
What are your opinions and suggestions in this regard ? Which one would you prefer with similar conditions that I have? I don't want to make the same mistake as I did with my Tamron again.
Thank you for your time and constructive comments.
The Tamron is very good @ 300mm f11, and it can even be good @ 300mm f5.6 if you do the trick I posted in the other thread:
http://www.dpreview.com/forums/post/56334662
Tat S Lau
