Weather Sealing is a Gimmick.
Started Feb 19, 2015 | Discussions
mpgxsvcd Veteran Member • Posts: 8,094
14
Weather sealing is simply a warranty. It simply says that if you are using a weather sealed camera with one of "their" weather sealed lenses then they will honor the warranty if it was being operated under a limited set of conditions.
Weather sealing doesn’t guarantee that it won’t break due to weather. It just simply guarantees that they will cover the repairs if it does break under certain conditions.
It is completely up to the manufacturer to determine whether it was being used properly or not. They can easily deny your warranty claim if they feel it was not being used in a “Properly Weather Sealed Configuration”.
Basically, weather sealing is an absolute gimmick. They determined how many people would actually send their cameras in for repair after weather damage. Then they calculated how much it would cost to fix those few cameras and jacked the price of the “Weather Sealed” cameras up by that amount plus a hefty profit.
I use my non weather sealed E-PM2 on my telescope during the winter. It is typically left out at sun down in very humid conditions. Then the temperature drops below freezing and all of the dew freezes on the camera and on the screen.
I come back out 8 hours later and it is still chugging away taking pictures even though it isn’t weather sealed. Even the “not weather sealed cameras” are more durable than you think. I abuse it like this at least once a month during the winter.
Also remember that the camera is only weather sealed with a weather sealed lens on it. All other lenses will not qualify for the weather sealed warranty if anything weather related happens while you are using them. They are going to want to see both the camera and the lens for the warranty repairs to find out what failed. They won't just take your word for it that you were using a weather sealed lens.
How many of you have ever sent a non-weather sealed camera in for weather related damage that would have been covered under warranty if it had been weather sealed? I am guessing that number is very, very small.
I am guessing that most of the cases involving weather related damage are probably of the “I dropped my camera in the lake” and not the “it was very humid or drizzling” kind. Dropping it in a lake will not be covered under warranty no matter what lens is on it and whether it is weather sealed or not.
 mpgxsvcd's gear list:mpgxsvcd's gear list
Panasonic LX100 Panasonic Lumix DMC-GF1 Olympus PEN E-PM2 Panasonic Lumix DMC-GH3 Panasonic Lumix DMC-GH4 +5 more
Olympus PEN E-PM2 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GH3
Skeeterbytes Forum Pro • Posts: 23,186
Re: Weather Sealing is a Gimmick.
12
Confronted with two lenses of the same spec and price, one is sealed and one is not, which would you choose?
Rick
OP mpgxsvcd Veteran Member • Posts: 8,094
Rick
Basically, I would always chose the non weather sealed option. I don't think I would ever pay extra for a weather sealed camera or lens if I had another less expensive option that wasn’t weather sealed.
If I don’t have a weather sealed camera then I would never ever consider paying extra for a weather sealed lens if a less expensive non-weather sealed option was available.
In addition, if all of my lenses are not weather sealed then I would never pay extra for a weather sealed body if a less expensive non-weather sealed option was available.
The only time I would consider paying extra for weather sealing is if I knew it was always going to be used according to their requirements(ie: weather sealed lens and camera under their strict conditions). In addition I would have to have some reason why I thought the camera was likely to break under the conditions that were covered under the weather sealing warranty.
Please note that I own or will own 3 weather sealed cameras(GH3, GH4, EM-5 MKII) and a weather sealed lens 35-100 F2.8. However, I never intend to use the weather sealing warranty because I rarely use that equipment in adverse conditions. I use equipment that is very inexpensive(ie: E-PM2) in those conditions instead.
Lab D Veteran Member • Posts: 6,938
4 wheel drive is a Gimmick. Safety harnesses too!
29
I drive my 2 wheel drive car in the snow and rain therefore 4 wheel drive MUST be a gimmick. No need for it.
And don't get me started on safety harnesses! They are a gimmick too, and these guys had no need for them.  I am sure you won't want to pay extra for safety ropes and such either...
http://earthsky.org/earth/success-two-men-complete-historic-climb-at-yosemites-el-capitan
 Lab D's gear list:Lab D's gear list
Panasonic FZ1000 Nikon D600 Panasonic Lumix DMC-GH4
jhinkey
jhinkey Senior Member • Posts: 2,817
20
Just so much not right in this post . . . .
 jhinkey's gear list:jhinkey's gear list
Panasonic Lumix DMC-TS3 Panasonic LX100 Nikon D800 Sony a7R II Panasonic G85 +27 more
Voldenuit
Voldenuit Senior Member • Posts: 1,648
7
Rick
I'd pick the one with the best optical performance (not just sharpness, but also bokeh, coma, CA, contrast, other optical characterstics such as microcontrast, rendering, "look" etc).
If equal, I'd then pick the one with the best handling.
*Then* I would pick the weather sealed one, if it doesn't entail too many other compromises (size, weight).
 Voldenuit's gear list:Voldenuit's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +4 more
Klarno
Klarno Veteran Member • Posts: 4,239
Olympus has posted a weather sealing manual...
Olympus has published this PDF detailing what steps the user needs to take to ensure that the E-M1 is weather protected:
http://www.olympusamerica.com/files/oima_cckb/E-M1_Weather_Resistance_EN.pdf
It may be a warranty, but they've detailed the steps you need to take to preserve the warranty which makes the warranty a bit weaker.
 Klarno's gear list:Klarno's gear list
Sony Alpha NEX-6 Olympus E-M1 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus 12-40mm F2.8 Pro +9 more
rsmithgi Senior Member • Posts: 2,939
8
The original post is nonsense but I can curious if there was a point in writing it.
There are gaskets on the weather sealed cameras that are not on the non-weather sealed cameras.
 rsmithgi's gear list:rsmithgi's gear list
Olympus E-M1 Olympus E-M5 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 17mm F1.8 +5 more
Rfinley33 New Member • Posts: 13
I live in an area was dust can be a very serious issue.  Just ask my Cannon friends.
Paulmorgan Veteran Member • Posts: 9,499
Weather sealing is no gimmick.
Its an added feature of a more robust build, get any camera with weather sealing and you will generally find it can take more knocks and abuse, have a more durable shutter etc.
Would you call a long life Duracell battery a gimmick, they cost more and are more reliable than the basic batteries.
Chas2 Veteran Member • Posts: 3,715
Voldenuit wrote:
Rick
I agree with that which is how I ended up picking the 12-35 for my GX7.
Although the 12-40 is arguably a slightly better lens, I thought I would be much happier with the slightly smaller size and weight, and the 58mm filter size.  I think size and weight fall into the handling category.  The weather sealing was never a big swinger...and looking at the thin rubber gasket on the lens, I am surprised at what constitutes weather sealing.  I know that this is not the only seal, but it is the only main visible seal.
 Chas2's gear list:Chas2's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX7 Panasonic G85 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +12 more
Ok. So let us know what you think is wrong about it.
(unknown member) Veteran Member • Posts: 4,734
Gimmick? Well, at least not a concern
5
As you correctly point out, you have low odds of winning a warranty battle with a camera manufacturer about whether you over-tested the weather sealing.  But, with many years of experience behind me, I can tell you that it's not as important as a lot of people believe.
I shoot in the rain a lot - landscapes and cityscapes are gorgeous in the last few minutes of rain, when the rain is gone enough that it doesn't obscure or create distracting streaks.  Long experience has taught me that in less than an hour after the rain tapers, things start losing the fresh, lush, saturated look.  So, I've had every conceivable type of camera out in the rain - and fog, and freezing rain, and blizzard, and ice storm, and "wintry mix".  I shoot the pictures without concern for water hitting the camera, but keep my camera close to me and semi-sheltered in between shots, and keep the lens body, where the lens connects with the camera, and the top controls reasonably dry by wiping with a small towel or cloth every few minutes.  Once I'm done, I dry it off well once indoors.  I can be out for an hour or two before it completely stops, and in winter storms, three or four hours.
A couple times I've been shooting in ice storms where enough ice built up fast enough that AF stopped working, because the coat of ice locked the focus ring (which still rotated with AF) in place.  Broke the ice, shook it off, dabbed off the water, and kept going.
I have never had a problem with water damage to a camera.  Some weather sealed, some not.
I've also shot in sand storms - sometimes intentionally, but generally not (sand in wind hurts a lot.)  I keep the lens sheltered with a lens hood, and again shake dust off, brush it off, or shake it off.  Never had a problem.  I've seen the insides of a couple of my cameras when having a regular check up tune up, and I've seen powdery dust in both sealed and unsealed cameras.  That said - no failures.
For me, it's hard to imagine a situation where weather sealing would help, and where a non-sealed but well assembled tightly camera body would fail.  Kind of have to shoot hundreds of thousands of frames in the rain, like a pro sports photographer, but if you watch them, they've got "raincoats" for the camera and are drying them all the time.
More important to worry about lens quality, data file and sensor quality, and accuracy of AF and exposure.
Erick L Senior Member • Posts: 1,288
I used to hike with two cameras around the neck, an E-M5 and an E-PM2. Now I do tis with just the E-M5. The E-PM2 drowned in my own sweat (from t-shirt) but E-M5 hasn't, despite using it that way for much longer.
Erick - www.borealphoto.com
Daniel Ramli
Daniel Ramli New Member • Posts: 15
I remember watching Kai from Digital Rev reviewing the original EM5 + 12-50mm (weather sealed too). And he tested the weather sealing by pouring water onto the camera and camera continues to work. I guess it's not a gimmick. You should be able to safely use this camera together with a weather sealed lens in the rain.
This one time I was shooting at a wedding and a gravy accidently poured on my 12-40mm pro lens. I simply run a tap water onto the lens barrel and wipe it dry.
Please don't mistaken weather proof as water proof. I can't guarantee your camera will still work if you dipped it in a water.
 Daniel Ramli's gear list:Daniel Ramli's gear list
Panasonic LX100 Olympus OM-D E-M5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R
tjuster1 Senior Member • Posts: 2,241
5
I can tell you what is wrong with it: it's the horrible logic that goes like this:
"Because I have used a non-weathersealed camera under some wet conditions without problems, then all weathersealed cameras are a gimmick."
It's crap logic, plain and simple.
 tjuster1's gear list:tjuster1's gear list
Panasonic Lumix DMC-GM5 Olympus E-M5 III Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH +6 more
"a" camera, I'll give you that
One camera is a bad sample size for sure.  My opinion comes from shooting in rain and worse with a couple dozen different cameras, and from what my friends who shoot travel and journalism have experienced under conditions other than war zones.  You really, really have to abuse a camera in a way that most sealed cameras won't survive (which I know from the failure rate of bodies in war zones, and in those cases they are generally sealed cameras and lenses).  I'll bet there aren't two people who've posted in this forum in the last five years who have a great excuse (like being shot at) for ignoring basic camera hygiene.
But beyond that, you will never get a warranty claim through on weather sealing.  The disclaimers in the manuals pretty much say, despite us calling it weather sealed, if you act like it is and it fails it's not our fault.  It's like watches that say they are water resistant - if you forget and take it in a shower and it fails, that watch won't get replaced, unless it came with a stated "waterproof to XX feet" claim.
jim stirling
jim stirling Veteran Member • Posts: 7,356
Other than one incident a few years back where i submerged a camera in sea water which killed it stone dead { a low end Olympus DSLR } . I have never in 30+ years of photography had any damage or incident to any camera caused by any type of weather { other than batteries losing power quicker in the extreme cold } , whether the camera was labeled "weather sealed" or not . I am a major fan of landscape shooting and I have  shot in all kinds of weather from torrential rain { a not uncommon occurrence here in Scotland } to heavy snow I shoot all winter in temperatures as low as -20 { on the mountains in winter}. On holiday I have shot in the Sahara , the salty dead sea coast and so on.
I think generally speaking cameras even relatively lower end models are far tougher than we imagine. There are videos aplenty on YouTube etc of people doing extreme things to their high end gear { it is exactly these kind of activities the camera companies are covering themselves against } but the digital-rev video where they put two non-weather sealed cameras through more than they would ever be expected to survivehttps://www.youtube.com/watch?v=D1tTBncIsm8
Apart from the likes of the Nikon AW1 no camera is actually water "proof" they are just a bit more resistant to it than lesser models. All the companies use the same methods { tighter seams etc} and technology { if you can call a rubber O-ring technology  } . So all manufacturers are in the same boat which is why if you delve deep into the small print about what is actually covered by "weather sealing" you will find the same gotchas
 jim stirling's gear list:jim stirling's gear list
Panasonic FZ1000 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GH4 Nikon D810 +12 more
jim stirling
Daniel, You might be surprised what lower end non-weather sealed models can survive Kai tested a couple out here https://www.youtube.com/watch?v=D1tTBncIsm8
RealPancho
RealPancho Senior Member • Posts: 1,315
mpgxsvcd wrote:
Rick
He said, "same spec and price." See above.
Once more, with feeling, see above.
Frank
 RealPancho's gear list:RealPancho's gear list
Panasonic Lumix DMC-TS3 Olympus E-M1 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +6 more
