Panasonic 12-32 on an Olympus E-PM2
Started Feb 15, 2015 | Discussions
traveler_101 Senior Member • Posts: 2,203
I am toying with the idea of picking up a 12-32 for my wife who shoots an E-PM2 . She prefers zooms and presently is using the 14-42 kit zoom. I think she would like the 12-32's pancake size and slightly wider FL. Does it have any issues on Olympus dories? And how do the lenses compare in terns of IQ?
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
Olympus PEN E-PM2
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Re: Panasonic 12-32 on an Olympus E-PM2
I use the 12-32 on my EPL5 with no issues. It compliments the camera very well.
The lens's OIS is far better than the cameras IBIS so make sure you have Lens Priority turned ON.
As for IQ, it is right up there with the best of the kit lenses and a bit better than the 14-42.
Read the thread on right side blur. This is not an optical flaw with the lens, rather I think it may be an internal focus point resolution issue. While it does exist, it is not really an issue and I have many fine photos from that lens.
One thing I do to avoid the issue is to use the small box focus and place the focus point over the main point of focus in the scene.
Allan
photofan1986
photofan1986 Veteran Member • Posts: 3,841
I had quite severe shutter s**** issues with this lens on my E-PM2 (now gone).
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
Ben Herrmann
Ben Herrmann Forum Pro • Posts: 21,163
I've got the 12-32 on my E-PL7
And what a wonderful combo it is. But more so, I find the optical qualities of this lens to be superb.
Right now I have personally found that among the various kit lenses among the various brands, this Panny 12-32 is among the best. Granted, it's not the fastest lens (what kit lens is?) - but you can put this lens up against many more expensive lenses and it can give most of 'em a run for their money.
The only other kit lens that stands shoulder to shoulder with the 12-32 is the remarkable Samsung 16-50 PZ zoom which has blown me out of the
So I highly recommend this lens with any of the Olympus cameras. Within it's focal range' it puts the Olympus 12-50 to shame (I had 2 of those 12-50's).
I wish Olympus could produce a mid-level standard zoom that covers a focal range of 12 mm to at least 50 or 60 mm that has superb optical qualities within an f3.5 to f5.6 minimum aperture range. I've found the Panny lenses to be superior at the lower price points.
Have a great one....
Bernd (Ben) W. Herrmann
North Carolina, USA
<a href=http://download.cnet.com/YouTube-To-MP3/3000-2071_4-75810474.html >link</a>
 Ben Herrmann's gear list:Ben Herrmann's gear list
Canon EOS M Fujifilm X-E2S Fujifilm X-T2 Fujifilm X-T20 Canon EOS M6 +4 more
(unknown member) Senior Member • Posts: 1,001
Are the issues gone or the PM2?
Re: I've got the 12-32 on my E-PL7
Do you use OIS or IBIS with this combo? I suppose the results will be roughly the same, unless?
CNY_AP Senior Member • Posts: 1,305
Shutter shock has nothing to do with the lens other than a "slow" lens causing the shutter speed to be in the range in which shutter shock is noticeable (around 1/60 to 1/200s is my understanding).  PM2 has a setting to reduce/eliminate shutter shock (adds a delay after the curtain or something).
On slrgear, this lens is very very sharp and tempts me to buy a used GM1 instead of a cheaper PM2.
Ben Herrmann
I use IBIS...I found it works superbly with the E-PL7. NT
North Carolina, USA
link
olybrit Regular Member • Posts: 147
No experience of PM2, but I have been using to make pocketable combo on my e-p5 for about 6 months.
No regrets and no intention of changing as yet. IQ is better than expected, including edges/corners.
Haven't noticed right side blur, but then I habitually use small central single focus point with this lens. Also tried IBIS and OIS- to be honest I haven't found any preference.
If you want to find fault, 2 arguably: no manual focus and smooth surface on narrow grip area  - fiddly for mounting/removing. Grip lines/lumps would be better, don't care about MF with this lens.
Hope this helps, cheers, Paul
 olybrit's gear list:olybrit's gear list
Olympus E-PL7 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +6 more
OP traveler_101 Senior Member • Posts: 2,203
Thank you all for your responses.
The lens would be a birthday present for my wife; she shoots I-AUTO, despite my efforts to encourage her to take more control of the camera. Thus the lack of manual focus on Olympus bodies is not an issue.
The two other problems that come up in this thread (shutter shake and right side blur) give me pause, however.
Luc de Schepper Senior Member • Posts: 1,211
I use the 12-32mm on my E-M10. It's really a great little lens and a very nice combo with the smaller MFT cameras. I wouldn't worry too much about the possible issues.
 Luc de Schepper's gear list:Luc de Schepper's gear list
Panasonic Lumix DMC-LX3 Fujifilm FinePix X100 Olympus OM-D E-M10 II Nikon Z6 Olympus OM-D E-M10 IV +19 more
ukeolo Regular Member • Posts: 187
I use the 12-32 with great results with em10 and pm2 (no issues). In the latter case make sure to have lens priority ois activated instead ob ibis. It is a sharp little lens.
photofan1986
The PM2. I replaced it with a GM1, much happier.
photofan1986
Not so sure. In a tiny and light lens like the 12-32, there are many floating elements. You can hear it by shaking the lens. That alone makes it more prone to shutter shock.
And the setting to reduce shutter shock on the E-PM2 does not do much good, I tried it.
Then again, I'm sure there will be people happy to live with this issue. As always, some seem no to see the issue. Good for them. But I just wanted to warn the OP that I would not have used a PM2 with this lens. Any other more recent Oly would do fine, though, thanks to effective the 0sec antishock feature.
+1
Neatly put, cheers, Paul
Can the shutter shock delay be adjusted longer?  If set long enough, clearly the shutter can't be causing vibration.  I'm tempted to buy a used PM2, but shutter shock is a concern (I prefer the GM1 overall, but it is more expensive and has the 1/500s shutter limitation).
I plan to use the PM2 or GM1 on my R/C airplanes and quad-rotor, replacing my trusty Fuji F20 (99% the same as the "legendary" F30/F31).  Paired with the 14mm F2.5 lens (2oz) seems ideal.
The GF6 is tempting too - $350 new with lens, no 1/500s shutter limitation, and it has the stop-motion / time-lapse feature that I need (PM2 would require an external timer, adding weight and complexity).
Allan Brown
SS is caused by the first curtain closing then opening to expose the sensor. On the EPM2, as with other cameras of this vintage, the delay only delays the time between pressing the shutter button and the first curtain sequence - thus, it may or may not make any difference. Making the delay any longer will have no effect.
The newer models with the 0 second delay place this delay between the first curtain sequences thus removing the vibrations - the delay is at a different time point.
I use the 1/8 delay on my EPL5 and seldom encounter SS.
Allan
Jeff Tokayer Veteran Member • Posts: 6,289
I still have, and use, the 12-60 SWD. Unfortunately it's only useable with the E-M1 (in the MFT world). I'm sure Olympus can re-purpose the lens design to become a great MFT lens.
My nickel, since the penny is now discontinued...
Jeff.
Makes no sense why they would put the delay there - my understanding was that the delay was after the first curtain and that the delay helped a lot.
photofan1986
In my experience, the delay did help on my E-M5, but not so much on the E-PM2.
