how to fix filter on my Oly 12-40
Started Feb 13, 2015 | Discussions
purpleray Senior Member • Posts: 1,261
Hi
Last week I dropped my Em1 with the 12-40 attached. See thread
http://www.dpreview.com/forums/thread/3793297
I thought I escaped with just a flying hood and scratched on my screen protector.
Due to my poor attention to detail, I have only just discovered my B&W UV filter is jammed just slightly askew.  One side has been forced out by a thread or two.  It is completely jammed.
I guess this might affect ultimate resolution of my photos.
How can I get the filter off without doing any damage?
Cheers
Ray
Olympus E-M1
BlueStarfish Regular Member • Posts: 277
Re: how to fix filter on my Oly 12-40
Hi,
I would take it to a camera shop and let them try, otherwise you have no choice but to use some force, in theory the filter should be made of softer metal and so any damage will be to the filter but there is no guarantee. If you have someone with a workshop you can try and cut it off using a dremel or similar but that is pretty scary but would do the job.
I would take it to a professional and let them try.
Good luck!
Scott.
 BlueStarfish's gear list:BlueStarfish's gear list
Olympus OM-D E-M5 Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Canon EF-S 60mm f/2.8 Macro USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +6 more
gnewsch
gnewsch Contributing Member • Posts: 510
Worst case you could always shatter the filter glass and then pinch the metal ring of the filter inside. That would exert the least force on the thread of the lens, but obviously would cost a filter.
 gnewsch's gear list:gnewsch's gear list
Olympus OM-D E-M5 Olympus E-M1 Olympus M.Zuiko Digital ED 14-150mm 1:4-5.6 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS Panasonic Leica Summilux DG 25mm F1.4 +11 more
OP purpleray Senior Member • Posts: 1,261
BlueStarfish wrote:
Hi,
Good luck!
Scott.
I was hoping there was a way but you might be right - I suppose a small cost relative to what could have happened.
Cheers
Ray
I'm a bit afraid of shattering more than the filter glass.
Thanks for the idea.
Ray
Chippy99 Senior Member • Posts: 2,182
purpleray wrote:
Hi
Cheers
Ray
I don't think there's any single "right way" to do this, especially having not seen it.  But from what you describe, if it were me, I'd try a "reasonable" amount of force to unscrew it - i.e. by hand and no more - wearing a pair of rubber gloves is a good tip as it greatly improves the grip you can get.
And if that fails, I would sacrifice the filter by dremelling it in a couple of places.  I'd try to cut the filter metal not right through - I wouldn't want to mark the 12-40 - but just enough to weaken it so that it will give when you try again to unscrew it.  If careful I would imagine you can cut through enough of the filter ring such that it gives when you try to unscrew it.
 Chippy99's gear list:Chippy99's gear list
Sony RX100 Leica Q2 Olympus E-M1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital 45mm F1.8 +4 more
raymb Regular Member • Posts: 494
Hi, get a shoe  with a course sole press the filter into the sole and try turning the lens body.
this will give you a better grip all around the filter.
i have used this method on a jammed filter before with good results.
good luck Ray
 raymb's gear list:raymb's gear list
Olympus OM-D E-M5 Olympus E-M1 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 12-40mm F2.8 Pro
Chippy99 wrote:
purpleray wrote:
Hi
Cheers
Ray
This is vote 2 for dremel.   I assume this is a tiny electric drill.   I'm sure someone I know will have one.  So this looks like a strong option.
Thanks for the advice
Ray
good luck Ray
I'll give it a go.
Ray
good luck Ray
I'll give it a go.
Ray
I wouldn't try that.
If a filter is stuck on normally then yes perhaps, but with yours since the threads are crossed, you would be putting extra pressure on the threads when you push down with the shoe.
I strongly recommend a pair of household rubber gloves instead - honestly, it's much better and you are far less likely to do damage. Just put a rubber glove on, and try to unscrew the filter.  If you can't then it's stuck too hard and I'd resort to cutting it off as I described.
lambert4
lambert4 Senior Member • Posts: 2,335
My favorite fix for such situations, is to remove lens.  Glue something long for leverage such as the flat edge of a butter knife or screw driver to the filter front using good super glue.  When cured twist it off easilly usually, and scrape the glue and filter off the lever, usually unscathed.
Here's to learning something new everyday, and remembering it the next.
 lambert4's gear list:lambert4's gear list
Nikon D500 Sigma 10-20mm F3.5 EX DC HSM Nikon AF-S Nikkor 70-200mm F4G ED VR Tamron SP 150-600mm F5-6.3 Di VC USD Nikon 35mm F1.8G ED +3 more
DeWitt Regular Member • Posts: 398
Just a thought from someone that this hasn't happen to, yet Since a high quality UV filter isn't exactly cheap, I would look for a solution that would save the filter if it is determined its threads are not already ruined.
An variation on the super glue suggestions already posted would be to apply super glue to the threads of a screw-in type cheap-o plastic lens hood (usually in the $2 - $5 range) and attach.  The lens hood would give plenty of leverage and if it worked you would still have a UV filter with a permanently attached hood.  (caution: the nuances of super glue use are sometimes a bit weird, so practice on something less important would be a good idea.)
Bob
DeWitt
www.rdewitt.net
s_grins
s_grins Forum Pro • Posts: 14,011
Unfortunately, I can't add more than one thumb-up to your favorite fix. Moreover, I'll try your method on my old legacy lens - it came from ebay with a filter that I could not unscrew (that is why this lens was very cheap)
If fo obvious reason I fail to unscrew this filter, I'll try to glue a tape and shatter the glass - shards will be fixed to a tape.
Thanks for idea.
S.
Camera in bag tends to stay in bag...
 s_grins's gear list:s_grins's gear list
Panasonic G85 Panasonic Lumix G 20mm F1.7 ASPH Sigma 30mm F2.8 EX DN Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +3 more
Bob
I don't think there's any problem getting enough leverage.  If you can't get enough leverage by normal methods and have to resort to glueing something on, then I think you risk damaging the lens itself by applying too much force.  I'd FAR rather cut the thing off before twisting on it that hard.
Extra3rd
Extra3rd Regular Member • Posts: 250
I don't have any advice - but this thread is thrilling.
Just update us on what you did? Cut, Drill or Shoe
The pressure is mounting to find out the final result.
Barry
 Extra3rd's gear list:Extra3rd's gear list
Sony RX100 IV Olympus E-M1 II Panasonic Lumix DC-GH6 +2 more
Skeeterbytes Forum Pro • Posts: 23,182
purpleray wrote:
Hi
Cheers
Ray
Ouch. The B+W filter I just looked at is constructed with a base ring holding the glass, which is in turn held in place by a retaining ring that screws in from the front. If yours is the same, it might be possible to unscrew the retaining ring, remove the glass and then the base. At least you wouldn't be risking shattering the glass. The one I looked at didn't have slots or depressions to fit a pin wrench, which would be ideal. Some filters and lenses have them.
If not, you might be able to use the trick I learned for removing lightbulbs from recessed ceiling fixtures--apply a suction cup and unscrew. Silicone seems to be the best material for the cup.
Past that, simply forcing it off may be all that's left. The lens is plastic and the filter is brass so they shouldn't bind as much as metal-on-metal would. I'd try grabbing the filter with a grippy rubber sheet like sold to unscrew stubborn food jars and turn. It will eventually come free. Whatever damage has already occurred. It may be a challenge to get another filter on, depending on how scarred the lens threads are.
Good luck!
Rick
Hi all
Sorry for the delay but I am posting from Sydney Australia.
I've tried the shoe -but no.  Also a silicon grippy sheet for opening cans - no.  There are no binding rings that can be unscrewed.  It's a thin filter for WA's.
Before I go and ring around for a dremel.
What do you think about penetrating oil - WD40 in Australia?   Would it get into the lens?
Another thought is graphite spray?  Again would it get into the lens?
What effect does the slight angle of the filter have?  I've looked at some photos and I cant discern any effect.  Though if I used some geometric pattern, I suppose I would see something.  What would I see?
Cheers
Ray
Manti44 Regular Member • Posts: 121
WD-40 is not just a lubricant, it is a SOLVENT! It could damage the coating on the lens if it got that far. I vote for the Dremel, in the hands of someone with experience, a steady hand and good close-up vision.
 Manti44's gear list:Manti44's gear list
Olympus E-M1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
Michael's Photos Regular Member • Posts: 361
Wrap a rubber band around the filter , hold it tightly, and unscrew it. Works for me every time.
ryan2007 Forum Pro • Posts: 12,001
purpleray wrote:
Hi
Cheers
Ray
This is at your own risk **
Take a snub nose plier and try to rotate the filter. Don't force it. If that does Not work you have to gently break the glass of the filter. You then have to snap the filter ring.
You may damage the threads of the lens, but the lens is generally usable. 50/50 at this point.
A camera store may do it for you, but the risk is great/liability.
Maybe a Google search will also find something for you
