E-M1 Settings Help for Olympus Newbie
Started Feb 10, 2015 | Discussions
dickg1 Regular Member • Posts: 320
I am a long time m4/3 devotee, having used virtually every Panasonic Lumix camera from the venerable GF1 to my current GH3.
I have just acquired my very first Olympus camera - the E-M1, and while I'm impressed with many of the features etc, some of the settings (or lack thereof) are confusing.
First:  One of the prime reasons for getting the E-M1 is the "0" delay setting to counteract the evil "shutter shock" demons lurking in my beloved Panasonic 14-140II when paired with any of my Panny bodies.  So here's where the confusion comes in - with "0" delay set to "on" in the menu, which single frame shooting mode do I use - the "normal" one or the one that shows the "diamond" icon indicating the "0" delay.  I think I know the answer,but confirmation would be helpful.  The section dealing with these settings in the manual (pg55) is silent on this issue and doesn't even show this as an option!
Second:  With every digital camera I have ever owned, I have been able to half press, focus and recompose with the little green box (aka focus confirmation) staying solid until the shot is made.  No matter what I do with the E-M1, as soon as focus is achieved, the green box disappears.  Do I have something set wrong - or is that the way the camera works?  If the latter is the case, how do I set up my options to be able to focus and recompose, which is something I instinctively do in virtually every hand held shooting situation.
Thanks in advance to all you E-M1 experts out there
dickg1
 dickg1's gear list:dickg1's gear list
Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Olympus E-M1 Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH3 Panasonic Lumix G 14mm F2.5 II ASPH
highyoyo Regular Member • Posts: 139
Re: E-M1 Settings Help for Olympus Newbie
Just tested focus on my EM1 (SAF mode).
Focused, green box appeared and went away, continued holding shutter release button half way down, recomposed and focus seemed to be maintained.
Tried without recomposing and green box also went away right after focus locked.
Appears to be just the way it works.
If you haven't yet pulled the complete manual for the EM1 you can download a copy from here:
http://www.olympusamerica.com/cpg_section/cpg_support_product.asp?id=1648
It has more detailed information than the abbreviated instructions packaged with the camera.
 highyoyo's gear list:highyoyo's gear list
Olympus E-M1 Olympus 12-40mm F2.8 Pro
OP dickg1 Regular Member • Posts: 320
OK - so if I understand correctly -  half press, focus and recompose works just like any other camera except that the green focus box doesn't reappear when the camera is moved to recompose with the shutter still in "half press" mode.  I can deal with that.
What about the two different single shot shooting modes - any ideas on that?  I have been going over the full online manual for a couple of days and still can't figure it out, because the manual completely ignores the shooting mode with the "diamond".  In case you haven't noticed it - activate the shooting mode and scroll all the way to the right (9 positions) and you'll see what I'm talking about.
dickg1
OrdinarilyInordinate
OrdinarilyInordinate Veteran Member • Posts: 3,741
Yes to your first question.  Use the diamond marked drive modes to correspond with 0-second anti-shock setting.
 OrdinarilyInordinate's gear list:OrdinarilyInordinate's gear list
Nikon Coolpix A Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 23mm F1.4 R Fujifilm XF 56mm F1.2 R +4 more
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Anti-Shock
In Custom Menus set 0 second anti-shock....
Then choose a shooting mode that includes the diamond to make it active in the range up to and including 1/320 sec ......
Note that burst modes are greyed out, need to run along further to burst modes that have no diamond.
Focus.
The green box only appears while AF is happening, as soon as the lens settles at focus it disappears.
There are two focus schemes, one initiated by the shutter button with that disappearing green box.
The second scheme designed for the touch LCD operation, also initiated by Magnify function. That green box can be set from large down to a small 14x box and stays on the screen, in touch AF mode it can be slid around to most anywhere, in touch shoot mode you just touch on the subject to shoot. Good for tripods or when the camera just sits on a table.
A good settings page is at http://www.biofos.com/mft/omd_em1_settings.html
Regards.... Guy
Thanks guys for the quick responses:
That's about what I figured vis-a-vis the shooting mode, both as regards the "anti-shock" setting as well as the burst mode, but I really just needed confirmation.
TO GUY:  I'm not particularly enthusiastic about Olympus's Touch Screen, especially when compared to Panasonic.  Panasonic allows me to activate touch screen functions individually, so if I only want touch screen focusing but not touch shutter, I can turn the shutter off.  It appears that the Olympus touch screen use is "all or nothing", including touch shutter.  Am I correct here or have I missed something?
dickg1
Guy Parsons
dickg1
I use the area on the left lower side of the LCD (E-P5 and I use only the LCD, no viewfinder) to alter the settings from Touch AF to Touch Shoot to Off cycle through the 3 settings.
Regards..... Guy
Yes, you can select touch focus area, one-touch shot (focus+shutter), or disable touch screen, as described above (touch the little rectangular touch icon on the bottom left of the LCD to cycle through options.)
Thanks to all for the help!
Here's another one for you - in Custom Menu "D" there is a setting called "Lock" with the picture of a diaphragm.  There is no mention of this that I can find in the manual and while I suspect that it has something to do with locking in an aperture setting, I'm not sure exactly what it's supposed to do when set either to "On" or "Off"
dickg1
Garry Schaefer Veteran Member • Posts: 3,349
Some of your comments about the manual suggest to me that you may not have downloaded the new version of the manual which followed upon some of the significant changes made in version 2 of the firmware.
Garry
 Garry Schaefer's gear list:Garry Schaefer's gear list
Panasonic Lumix DMC-G3 Olympus OM-D E-M10 Olympus E-M1 II Olympus Zuiko Digital ED 50mm 1:2.0 Macro Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 +8 more
Jim Vincent Veteran Member • Posts: 3,034
Gear D - diaphragm lock on/off setting
The little text description that comes up in the camera's menu says it sets whether the depth of field preview will be locked when the button is released or not.
If you try it, it changes the depth of field preview button from a momentary contact (only on while pressed) or toggle (on until you press it again).
 Jim Vincent's gear list:Jim Vincent's gear list
OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 7-14mm F2.8 Pro Olympus 12-100mm F4.0 Olympus 100-400mm F5.0-6.3 IS
Ahhh! got it - thanks.
When I downloaded the manual from the Olympus website, I didn't see any option to access anything other than what was offered in the way of manuals for the EM1.  How can I tell which version of the manual I have?
dickg1
If you go to page 97 of the new version you will see 0 second anti-shock described. If not, you do not have the current version.
Garry
Guy Parsons
Manuals.
The last page at the bottom has copyright 2013 for V1 or 2014 for V2.
Manuals always available from http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/pen.cfm#body
Regards.... Guy
Re: E-M1 Settings Help for Olympus Newbie - Book Recommendation
Now that you have the manual, you might want something more readable that explains more of how to use your E-M1, gives examples and some reasonably good advice as well as explaining more about the functions.
Gary Friedman's E-M1 Book is inexpensive, in multiple electronic formats, and quite good.
More discussion about his book can be found in this thread E-M1 Book Recommendation
estorm
estorm Forum Member • Posts: 62
Thank you Guy. For the anti-shock setting, I just realized after reading your post that I only did the first part, but never noticed (and used) the 2nd part where I should select the single shot drive mode with the diamond! Thanks for the great tip!
- estorm
 estorm's gear list:estorm's gear list
Olympus E-M1 Panasonic Leica D Summilux Asph 25mm F1.4 Olympus 12-40mm F2.8 Pro Olympus 40-150mm F2.8 Pro
(unknown member) Veteran Member • Posts: 3,010
dickg1
I have a PEN and the focus box goes away also but I always thought that it is a visual clue that focus is achieved.
Godfrey Forum Pro • Posts: 29,636
dickg1 wrote: ...
With the E-M1, in the EVF you see the AF area pointer when focus is being acquired. Once acquired, at least with display mode 1 enabled, a green focus confirmation indication appears in the lower left corner as long as focus is held. The AF area pointer disappears after the focus is acquired to allow a clearer view of the subject for framing.
I have my E-M1 set up with AF/MF assigned to toggle with the Fn2 button. That way, if I'm going to make repeated exposures of the same subject, I can half-press the shutter release to lock in the focus setting, tap the Fn2 button to push the focus to manual (it holds its setting), and then shoot as many exposures as I want at that setting. If I'm using spot or centerweighted metering, I can then meter separately using the half-press. I can also make critical focus adjustments manually. For me, it's very fluid in use this way.
G
Again - thanks to all
dickg1
