WilbaW - Spider macro
Started Feb 10, 2015 | Discussions
lewynn
lewynn Senior Member • Posts: 1,298
Hey WilbaW,
Here's one of my macros spider shots. I used my 450D with a 60mm macro lens, f16, 1/160. The spider was pretty small and I cropped this one quite a bit. But regardless of the shot I tend to be always on the soft side. My ladybug shots lack that fine edge I see on stuff by imqqmi and others. I've gotten a little better results when I use my of camera flash but still nothing like I've seen around. I guess it's not that big a deal, when I get big hopefully I can get a big boy camera.
I basically use DPP to edit all my pics, I don't have photoshop or anything with stacking software.
Canon EOS 450D (EOS Rebel XSi / EOS Kiss X2)
lord vetinari Senior Member • Posts: 2,691
Re: WilbaW - Spider macro
Assuming this was taken with flash with the camera in manual mode ?
Try shooting at slightly wider aperture eg F11. You will lose some DOF but will potentially gain sharpness by both reducing diffraction softening and decreasing the flash duration which will reduce any motion blur.
R2D2 Forum Pro • Posts: 26,551
lewynn wrote:
Hey WilbaW,
As LV explains, you're losing some sharpness due to diffraction.  However most macros can handle a LOT of sharpening.
It looks like the photo might be a little front-focused as well.  I like to shoot bursts and pick the best.
I'd also look into diffusing the flash more.
And remove any filters if you're using one.
Good luck,
It takes a while to become proficient.
R2
Digirame Forum Pro • Posts: 41,857
That looks great.  I'm also bumping this up so that maybe Wilba will notice.
WilbaW
WilbaW Forum Pro • Posts: 11,643
Here's what I'd do to a good shot of a guy like that -
  • f/13. You can see some diffraction coming in from f/11, but it's very easy to deal with at f/13. I'd only use f/16 if DOF was the highest priority.
  • Flash at max. sync. shutter. You don't need much flash power for macro (I use a diffused 270EX II, see http://www.dpreview.com/forums/post/55195826). The duration of the flash is much shorter than the mechanical shutter, so it freezes motion blur better than the shutter ever can. You can use a flash off the body with a cable, radio triggers, or with the Canon wireless system on later bodies, or even the on-board flash with a home-made diffuser or ring thingy.
  • ISO 100. The flash gives you all the light you need, even at these tight apertures.
  • Get closer! I found images from the 450D quite limited in how far you can crop, so you need to fill the frame. Check out the Macro section of the unofficial Rebel Talk FAQ for tips on how to go beyond 1:1 (I'd go for extension tubes with the 60mm).
  • Look him in the eye. It's easy to get macros looking down on the subject (and that's fine if that's what you want), but they get dramatic if it looks face-to-face.
  • Try AI Servo with a single AF point, including the off-centre ones. It works fantastically well with a USM lens like the 60 and bodies like the 60D, 70D, and 7D, and should with the 450D but I can't guarantee it.
  • Shoot raw and work on your sharpening so you get the most out of the slightly soft images you'll be getting.
Have a go and show us your progress.
 WilbaW's gear list:WilbaW's gear list
Canon EOS 60D Canon EOS 7D Mark II
WilbaW
lord vetinari wrote:
Brian .V
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Great to see you here! I've been following you on Flickr for years and trying out your ideas, like the coke can diffuser and the bean pole.
Everyone - check out his work if you haven't already.
Check out the unofficial Rebel Talk FAQ.
