Sony a7II Settings for Astrophotography
Started Feb 8, 2015 | Discussions
mmalik
mmalik Regular Member • Posts: 283
Sony a7II Settings for Astrophotography:
Some of the highlighted settings (with few exceptions) were modified from their defaults for astro use; otherwise predominant number of settings are default
Mode Dial...
Start by setting the mode dial to M (Manual)
Note: C2 button on top is set to Live View zoom by default which can be helpful for focusing on a star
Sony A7II
Sony A7II
a7S, 7D II, 6D DSLR modifications
For more information: mike_malik@msn.com
 mmalik's gear list:mmalik's gear list
Canon EOS 6D Sony a7S Canon EOS 7D Mark II Sony a7 II Sony a7R II
Canon EOS 6D Canon EOS 7D Mark II Sony a7
mmalik
OP mmalik Regular Member • Posts: 283
Re: Sony a7II Settings for Astrophotography
Rear Dial...
Turn the rear dial all the way to Bulb mode
mmalik
Camera Settings...
Press Menu button to get to camera settings
mmalik
Custom Settings...
mmalik
Wireless, Application and Playback Settings...
mmalik
Setup...
mmalik
Once done, summary of the above settings will look like below.
Note: If needed, press DISP button (control wheel on the back) to cycle between following, and two more screens.
mmalik
Fn button on the back goes to following screen.
mmalik
Following timer remote... works well with Alphas (a7II/a7, a7S and a7R) for any length of long exposures, via Multi/Micro USB. Regards
Note: Camera shown is a7S
mmalik
Read about a7S mod here...
Read about 7DII mod here...
Canon 60Da Settings for Astrophotography...
bwana4swahili
bwana4swahili Contributing Member • Posts: 804
mmalik wrote:
Camera Settings...
I would suggest using Quality RAW+JPG to more easily review your subs.
I DISAGREE with having Long Exposure NR set to ON.  I highly recommend turning all forms of noise reduction off and handling noise reduction in postprocessing after aligning and combining your subs; otherwise, you will lose faint nebulosity and other stellar objects that can appear as noise to any in-camera noise reduction setting.
bwa
 bwana4swahili's gear list:bwana4swahili's gear list
Sony Mavica CD400 Olympus Tough TG-2 Sony RX10 IV Nikon Coolpix P1000 Sony a6000 +95 more
mmalik
While most experienced don't go for LENR, it is a useful feature for most.
FYI: LENR being ON is a default on a7II.
I use LENR quite often and quite like the results. Note: Bubble nebula posted here... was taken with LENR ON. Regards
JimKasson
JimKasson Forum Pro • Posts: 38,176
mmalik wrote:
Camera Settings...
I see no advantage to going above ISO 1000 with the a7II. You will get the same noise if you push in post, and more DR:
Details: http://blog.kasson.com/?p=8280
Jim
 JimKasson's gear list:JimKasson's gear list
Leica Q2 Monochrom Nikon Z7 Fujifilm GFX 100 Fujifilm GFX 100S Nikon Z9 +1 more
mmalik
I would agree with you Jim; I probably should have set a7II to ISO 1600 [at least for this thread] which is also a defacto astro standard.
What ISO do you suggest for a7S for astro, I am planning on doing a 'Settings' series on that as well. Regards
JimKasson
2000, Look at the yellow curve in the above post from me.
At the transition from ISO 1600 to ISO 2000, the a7S ups its conversion gain. You want the high-gain setting, thus 2000.
Jim
nathanhw
nathanhw Regular Member • Posts: 251
Very nice summary of settings.  Thanks for posting.
Question:  What, if any, changes would one make for a A7R?  Looking this over, I cannot see anything that should be different (though obviously IBIS is not relevant).
 nathanhw's gear list:nathanhw's gear list
Sony a6500
mmalik
Nathan, I don't see any difference in astro settings for all alphas (a7/a7II, A7S, A7R), minor ISO adjustments being one exception, which end up being personal preferences. So, yes set your a7R pretty much the same. Yes, IBIS is 'not' relevant to astro. Regards
bwana4swahili
Jim
ISO 3200, 6400 and 12800 work quite nicely with the A7S.
bwa
bwana4swahili
JimKasson wrote:
mmalik wrote:
Camera Settings...
Jim
Do you have similar data for the Sony A7R?  I have both the A7R and A7S.  I suspect the A7R is quite similar to the A7/A7 II, at least from my noise evaluation of Darks off both.
I normally shoot astro-imaging at ISO 1600-3200 with the A7R but have pushed it to 6400 on occasions with a major increase in noise.
bwa
thecat131 New Member • Posts: 10
Hi Brian
Thanks for posting the setting for astro with the A7II.
Question: Why do you suggest Live View Display off?
Thanks in advance
thecat131
 thecat131's gear list:thecat131's gear list
Olympus Tough TG-1 iHS Sony a7 II Sony FE 28-70mm F3.5-5.6 OSS
