NX2000 & 16-50 PZ EXIF data
Started Feb 8, 2015 | Discussions
Petak
Petak Regular Member • Posts: 203
I have just purchased the new 16-50/3.5-5.6 PZ OIS for my NX2000 and found out that the camera does not record properly the lens info (lens model) in the EXIF. I have the latest FW on both the camera and the lens and the camera does record lens info properly with 20/2.8 and 20-50.
No big deal but a bit annoying since I can not use lens info for filtering in LR.
Samsung 16-50mm F3.5-5.6 power zoom Samsung NX2000
targut Regular Member • Posts: 456
Re: NX2000 & 16-50 PZ EXIF data
That's interesting. What is the version number of your NX2000 firmware?
 targut's gear list:targut's gear list
Samsung NX200 Samsung NX2000 Panasonic Lumix DMC-GM1 Samsung NX 30mm F2 Pancake Panasonic Lumix G Vario 100-300mm F4-5.6 OIS +4 more
Petak
OP Petak Regular Member • Posts: 203
nx2000 is 1.18
16-50 PZ is 1.20
mdavidp Senior Member • Posts: 2,436
That wouldn't bother me, but I guess you could try reinstalling updates, but be super careful.
I also have those lens combination and will check later my exit info.
Mike P
Update:
On my nx2000 with either of these two lenses the Exit shows the focal length of the lens used,
not the lens used.
Mike P
Petak
mdavidp wrote:
Update:
not the lens used.
Mike P
Thanks mdavidp. Yes, LR does show the actual focal length used for the respective picture, incl. when 16-50 PZ has been used, but does not display the lens model. The lens model is properly displayed when 20/2.8 and 20-50 are used.
Can you try other software or just dcraw or exiftool or some other small utility, it might be LR related?
Petak wrote:
nx2000 is 1.18
16-50 PZ is 1.20
I suspect a bug in the firmware
Petak
I have tried an online EXIF reader and the field where the lens model is otherwise specified does not appear at all.
