XA1 in very low light at Hi ISO (1)
Started Feb 5, 2015 | Photos
KKJohn
KKJohn Senior Member • Posts: 1,138
(1) first series of shots testing XA1 at 12800 and 25600 ISO with various lenses. mostly taken at an annual Buddhist Festival in Northeast Thailand, at a sacred pagoda supposedly storing the Buddha's breast bone. All shots hand held, ie, no tripod, tho some help to steady my shaky old hands with posts, trees or whatever structures were available.
(2) different ISOs from 1600 to 6400 and different lenses- XC16-50, XC 50-230, XF35, XF60.
Interested in comments as to merits of photos and whether the hi ISOs detract too much. Not interested in too much negativity from pixel peepers, as I know many DPR photogs will find these awful. But IMHO they look pretty good on my 27" iMac screen but haven't as yet printed any of these.
a spire with the full moon peeking thru
devotees making merit to Buddha with incense, candles and flowers
view across the lake with jogging track at Khon Kaen University
a runner resting after her jogging exploits in very early morning while still cool. Fill flash used.
water in a drainage ditch with light reflections
 KKJohn's gear list:KKJohn's gear list
Fujifilm X70 Fujifilm X-A1 Fujifilm X-T10 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +2 more
Comment & critique:
Fujifilm X-A1
KKJohn
OP KKJohn Senior Member • Posts: 1,138
Re: XA1 in very low light at Hi ISO (2)
large candle with Buddha statue in background
large Brass gong with nice play of light
a small brass frog on sale in the festival market beside the temple
a devotee looking up at the Pagoda
old woman and grandson putting coins into containers as offerings to the temple monks
devotees walking clockwise around pagoda three times
pagoda That Panom
top of Pagoda with XC50-230
Pagoda with moon
entrance to Pagoda
Gavin Stapleton
Gavin Stapleton Senior Member • Posts: 1,150
I love the image quality from the X-A1, but I call it quits at ISO6400.
Nice shots, Gav.
 Gavin Stapleton's gear list:Gavin Stapleton's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix DMC-GX7 Fujifilm X-A1 Fujifilm X-T100 Fujifilm XF 18-55mm F2.8-4 R LM OIS +14 more
with lots of gear but no idea Regular Member • Posts: 240
I tend to agree with what Gavin has said re iso. I think the X-A1 is a fantastic little camera and pleased to see you are enjoying it. I'm pleased that Fuji have upgraded it and I hope they continue to do so. Thanks for the thread.
 with lots of gear but no idea's gear list:with lots of gear but no idea's gear list
Canon EOS 500D Fujifilm X-E1 Fujifilm X-A2 Fujifilm XF 35mm F1.4 R Fujifilm XC 16-50mm F3.5-5.6 OIS +2 more
KKJohn
Thanks for your opinions, guys. Yes, think I should stick to 6400. In nearly all cases where I used the higher ISOs, I could have used 6400, with better results. But fun trying out to see what the XA1 is capable of. One thing I did notice with all the lenses used, particularly the 60, in the very low light where there wasn't enough of a contrast between light and dark, the XA1 really struggled to get the AF focus, even in spot mode, and often just couldn't get the focus at all. I tried MF and probably will try that again in a similar situation. What do you think? By the way, I generally shoot JPGs, as I don't have PS and my Lightroom version doesn't support the RAF from Fuji.
My first Fuji was the X10, which I dearly love, but no way it could have even attempted those higher ISOs, even 6400 was beyond it's capabilities- 3200 max. It seems to me that the XA1 @ 6400 is same, or better, than the X10 @ 1600. Yes or no?  Anyway, glad I have the XA1, and will enjoy for a long time, I'm sure. Don't think I need to upgrade to the XA2, but maybe/hopefully in the future Fuji will bring out a XA3 or 4.
Now saving up to add another prime lens or two, to go with my 35 and 60- would like either a wide angle like the 14 or a longer macro like the 90, maybe both if Fuji has a sale. I feel happy with the XC zooms which cover the ranges I need, and quality good enough for my non pro purposes, tho only in reasonably good light.
Charles2
Charles2 Veteran Member • Posts: 6,810
Re: XA1 in very low light at Hi ISO (1)
The standout shot in the first post is the second photo - but the noise really distracts. However, with the raw file a good photo for a print can be made.
A bit of noise reduction and such on the posted JPG, done with Picture Window Pro
Lyle From Canada Senior Member • Posts: 1,512
I didn't find the most distracting at all. To each their own I guess.
Gavin Stapleton
I find the low light AF on the X-A1 a real bummer. What I've found helps is setting it to multi point AF, or making the flexible single point AF box bigger. The smaller the AF box the harder a time it has, so spot focus must be even worse (I've never used spot focus).
